3D Printed Kitten Wheelchair
4,670
40
54
About: I am an automation engineer but I will give anything a go. I don't know if you call if pessimism or just being an engineer, but I look for problems everywhere, then I look for some weird, left field way to s...
Meet Peggy, this little kitty was rescued by some friends of mine. When she was found the lower portion of her rear legs were gone (sorry about the image).
She was not born without them but the cause of the loss remains a mystery.
I was asked to design a wheelchair for Peggy to keep her mobile and keep the stumps off the floor (as they can easily get infections) until she reaches the ripe age of 1 when she can get some prosthetics fitted.
There were lots of options but I decided to go with a 3D printed seat designed to be adjustable.
Step 1: The Design
I took a number of measurements from Peggy in order to determine the base size for the model.
Ultimately, as she grows the 2 options were to make larger chairs or to make this one as adjustable as I could to keep up with her.
I designed the seat section in Fusion 360.
I started out by creating a boss that covered the full area of the finished seat.
Then a dish was removed using the revolve tool to make a space for her belly.
I then removed some scoops for her legs to hang over and catch the rear of the seat, this was done over 2 sketches to create the correct shape.
I created a profile for the top and bottom of the seat.
I push cut some hex holes to act as a guide and to provide a flat surface for the mounting bolts (see this later)
I also created a hex retainer for the lateral adjustment nut and bolt.
In order to ensure that the model was completely symmetrical, I cut it in half, deleting one side and then mirrored the model.
Lastly I radiused all of the edges to ensure it would be comfortable.
Step 2: 3D Printing
I don't own a 3D printer so I sent it out to my local 3D hub.
The guy there gave me some advice on material and in the end, we agreed upon Protopasta Carbon Fiber PLA.
This gave a good balance of weight and strength.
Step 3: Assembly
The initial assembly shows the unit fully closed up, as Peggy grows, the wheelchair will get wider and taller.
The 2 bolts coming from the bottom of the seat carry 2 nuts and attach the seat to the base.
The base is a small plastic project box with wheels taken from some cheap shoe mounted wheel things (the name escapes me) but these were only 10 Euro per set.
I initially made a nylon strap with a plastic buckle but it just looked too big so I switched over to a velcro strap.
This was fitted to the seat by first melting a hole in the side of the seat with a hot drill bit, this prevented me cracking the seat or drilling in too far.
It then used some automotive upholstery rivets, these little plastic guys go into the hole and have 3 legs, you then force a pin down the inside which spreads the rivet and locks it in place, then just trim off the excess on the pin.
Step 4: Finished Wheelchair
I added some rubber matting from the top of my toolbox for cushioning. This stuff is also super non-slip.
The whole unit weighs just over 240g.
Step 5: Trials
We gave Peggy a little time to sound out the chair.
Then strapped her in for a little trial.
There was some initial worry but she did move about on it.
There is a long way to go with training her to use the wheelchair and to stay on it. She is quite skinny and has managed to slip out. Her owners are going to have a look at further attaching the chair to her harness in order to keep it with her.
You can follow her progress and adventures on her facebook page
This is my first aid for a disabled animal, so if there are any tips or suggestions I am open to them, just stick them in the comments. Also, Peggy will need prosthetics around this time next year so please follow her page and donate if you can when the time comes. Thanks!!!
Plastics Contest
Second Prize in the
Plastics Contest
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    54 Discussions
    Wow excellent. Keep an eye on her Facebook page for when the fundraising starts. Thank you so much
    I've been thinking about your wheelchair a lot - and I am unsure on the posture, given the plan to use prosthetics later. Any idea how many hours a day the kitten is in the chair? She'll need to use those legs as stumps as much as possible, to teach these muscles how to move well, given her young age.
    Hadn't thought of that. She won't be in it all the time and can move at quite a rate without it but the stumps are still quite raw and she has gotten an infection. It's a balancing act that her owners and the vet will work out
    Jan Cousineau
    1 year ago
    I joined her page, please let me know when you'll be accepting donations towards her prosthetics, i'd love to donate.
    Thanks for the tip. This is just a stop gap fix for peggy until she can have implants fitted, she needs to be a year old first
    Chey505
    1 year ago
    Peggy is so lucky to have you and your friends to love. .... And visa-versa. :) Great job! Best to you all.
    Izzy47
    1 year ago
    Thank you for your kindness to this defenceless little kittie God Bless you
    chideki
    1 year ago
    May God bless you for this beautiful job, to help and to serve, no matter who is! Best regards!
    Jan Cousineau
    1 year ago
    You're wonderful, thank you for helping this sweet little kitty get around. The world is a better place because of people like you.
    Thanks for the lovely comments. I'm not sure when her owners will start collecting but keep an eye on her Facebook page. Thank you for taking the interest
