3D Printed Motorized Boat
2,722
13
4
About: I am a novice cad designer and I own a modified cube 3, modified r1+, and a modified SD4. I design things in tinkercad and fusion 360. I also am into programming and most recently arduino. More projects comi...
I designed this motorized boat awhile back on Tinkercad.
Supplies:
Step 1: Supplies I Used
Step 2: Tools I Used
  • 3D printer
Step 3: Design
I designed this boat in Tinkercad. I started my design by lining up 3 cylinders. Added wedge to help it cut through the water. I designed a case for the motor and the inserted into the boat. I made a spinner by inserting a rotated rectangle into a cylinder flipping it then adding a hole to put it onto the motor. I uploaded a AA battery holder from thingiverse http://www.thingiverse.com/thing:331394. I cut off the screw holes so that it would fit well in the boat.
Step 4: Assembling
  1. Insert motor
  2. bring wires out the hole
  3. Insert cover
  4. Put sealer around cover
  5. Screw in cover
  6. put o ring onto motor
  7. Put spinner onto motor
  8. add contacts to battery holder
  9. Insert battery holder
  10. Connect wires to battery holder
  11. insert battery
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    4 Discussions
    brettt3
    2 years ago
    this made me smile. I might make one to excite my nephew and niece about building things. Great job!
    Jayden17brettt3
    Reply 2 years ago
    Thank you, I would recommend the one with the quarter holder in the front the normal one tips a little far back.
