3D-Printed Spray Paint Stencil
About: Engineer, Clemson grad, writer, maker of random contraptions for fun and profit.
This video will take you through how I made a logo stencil on my 3D printer using a DXF stored from another project. The process is fairly straightforward if you understand modelling and generating print files.
The trick comes at about 0:50 in the video, where I draw lines to connect the unfastened parts together and make them into solid parts using the offset command. Since this is extruded on top of the rest of the stencil, spray paint can get into every blank spot while still holding things securely.
Step 1: Items Used
I used the following with this build:
If you enjoyed this build, you can check out/subscribe to the rest of my YouTube clips here. I make all kinds of ridiculous things, so it's worth poking around!
Note: Amazon links are affiliate.
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
