3D Printed Wall Mounted Hat Display
546
8
5
With more and more hats piling onto my desk, it was clear I needed to find a solution to my growing hat disorganization. After looking around online for other hat holders, I came across two options: a hook, which hangs your hat down rather than displays the front, or an inefficient and expensive display system that isn't particularly made for home use. Unhappy with these options, I started to design my own hat holder to be printed off of my 3D Printer.
Step 1: Initial Designs
Throughout the design process, the hat holder took many different shapes and sizes. I began with a stackable design, instead of a wall-mountable design, that would allow multiple pieces to slide together, holding multiple hats. I quickly realized that the balance problems and wasted material created a poor product, so I began slimming it down before even making a physical prototype.
Step 2: Finalizing the Design
Starting with the inefficient base in the last step, the design quickly grew shorter and slimmer. At each step of these designs, I printed a prototype to see and feel what needed to be improved for the next iteration (more on the 3D printing later).
Step 3: Final Design
After 8 different versions of the hat holder, I settled on this one. It was the perfect balance of snugness and looseness that held the hat securely while allowing easy access to remove the hat without harming it.
Step 4: 3D Printing
Using my Monoprice Maker Select v2, I printed the hat holder with the following settings:
.2 mm Layer Height
15% Infill
50 mm/s Speed
10 Line Brim
It should take about an hour to print.
Step 5: Installation
Materials:
I used a small set of screws and plastic anchors from Walmart: for example
Any screwdriver
Any drill
1) Start by drilling a hole in the wall, inserting the plastic anchor into the wall
2) Place the screw through the hole in hat holder
3) Using a screwdriver, tighten the screw and fasten the hat holder to the wall
Step 6: Finished!
Fold the backside of any hat in and slide the hat on by the button as shown.
Now you can securely attach a hat to the wall while being displayed outward!
If you want to create this yourself, the file can be found here:
ipt for Inventor:
ipt
stl for 3D Printing:
stl
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    5 Discussions
    StewieWorks
    4 months ago
    Really cool design! Love the hats too! Go Bears and Cubs :P
    jessyratfink
    4 months ago
    Well done! Thanks for sharing and including your stl files :D
    Penolopy Bulnick
    4 months ago
    Nice idea! Can you just pull the hat off when you want it or do you need to be careful when taking it off?
    bri.batlinerPenolopy Bulnick
    Reply 4 months ago
    It is designed to just be pulled off without a thought, so you do not need to be careful.
    DIY Hacks and How Tos
    4 months ago
    That is a really nice design. Probably the best system for displaying hats that I have seen.
