3D Printed Watch Winder (ATtiny85+Stepper)
10,605
66
43
About: 3d printing, electronics, programming, automation. Currently studying automation engineering at Politecnico di Milano. The profile picture is some years old. Maker of RapidoTreno: https://appworld.blackberry...
A friend of mine recently bought a watch winder to keep his automatic watch charged when he is not wearing it. I wanted one too, but these device are rather expensive!
I then figured out how to make one on a tight budget: the total cost is less than 15$ (pla filament included)
As I had already experimented with ATtiny's I thought I could use it to drive a commonly-available cheap stepper, the 28BYJ-48. It is usually sold with a handy pcb featuring the "driver", a simple ULN2003 darlington array, some connectors and leds for debugging purposes. Most importantly, this motor can spin with just 5 volts, so we can use the same power supply for both the motor and the microcontroller, thus keeping the circuit very simple (read: cheap).
The idea behind these gizmos is rather simple: they slowly spin the watch some minutes per day, keeping it charged. The one I made, specifically, rotates for 10 minutes every hour.
  • Why 10 minutes? Because I've looked up some documentation regarding automatic watches and that's plenty of time.
  • Why 10 minutes every hour and not 240 once a day? Well, the latter means that once you end spinning you need to wait 18 hours before moving again. To measure time (in order to wait) in a microcontroller without any additional hardware you have to count. Why bother counting BIG numbers in a 8-bit architecture when you can just split the whole process through the day, handling much smaller time values, with no practical difference at all? (KISS principle ftw)
Here's the bill of materials:
  • ATtiny85 or a Digispark board
  • 28BYJ-48 with driver board, you can find these ones on ebay
  • 8 pin socket (optional)
  • Decoupling capacitors, I've used 10uF and 0.1uF ones (you don't need the 0.1 one on the digispark)
  • Spare wire
  • Glue
  • Soldering tools
  • Perfboard
  • 5v regulated (switching) power supply - any 5v USB battery charger will do
  • Usb cable
  • Something to program the ATtiny with (Arduino as ISP, USBtinyISP...)
  • 3D printer and some filament
I've written the code running the ATtiny85 in AVR C. Let's start with that.
Step 1: If You Have a Digispark
Digisparks, those little attiny85-based gizmos that you can program via usb! If you have one of them, you can use this guide to program it, otwherwise carry on with step 2, it will work anyway. Notice, however, that the Digispark code doesn't currently support the sleep mode, so your circuit will draw a few milliamps even when the motor is idle.
Download the Arduino source file from my Github, open it, install the digispark package following the official guide and upload the code. You're done!
Step 2: Program the ATtiny85
Head to https://github.com/SimoDax/watch-winder-attiny85/... and copy the code. It will make the winder spin counterclockwise. If you want it rotate the other way change the line
PORTB = lookup[i]; into PORTB = lookup[7-i];
Make a new AVR C project in Atmel Studio, select ATtiny85 as device, paste in my code, build it and flash the avr following these steps:
If you want to use Arduino as ISP you need to turn a UNO board into a avr programmer following this guide (I assume the Arduino IDE is already installed on your system). Now go back to Atmel Studio, click on Tools > External tools...In the window that shows up click Add and paste these strings in the title, command and arguments fields:
Title:
AVRDUDE 85
Command:
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.exe
Arguments:
-C"C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf" -v -pattiny85 -cstk500v1 -PCOM19 -b19200 -Uflash:w:"$(ProjectDir)Debug\$(TargetName).hex":i
In the last string look for "-PCOM19". This specifies the serial port the Uno is connected to. On my pc it's COM19, you can check yours in the Arduino Ide, under Tools > Port (there may be many ports listed but only one will have "Arduino/Genuino Uno" written beside, use that one). Change 19 in the parameter to match yours. The final result should be like in the second picture.
Now we're ready to compile & upload the source code: click Build > Build solution, connect the Uno (if you have disconnected it) and click on Tools > AVRDUDE85. A console window will pop up. DO NOT DISCONNECT ANYTHING WHILE AVRDUDE IS RUNNING!
Three progress bars made of #s should appear, one after another. Once you see "avrdude.exe done. Thank you." you can close the terminal. The source code has been uploaded to the attiny. Disconnect the Uno and remove the attiny from the breadboard.
Step 3: Make the Circuit
The circuit is fairly simple, as you can see (also you may notice I'm not good at fritzing). I added two decoupling capacitors, 10uF and 0.1uF respectively. Roughly said, the former smooths out the voltage across the whole circuit, while the latter is "shielding" the microcontroller. These caps are needed because the motor can produce a lot of noise across the power line, and since this is shared with the microcontroller we don't want it to reset due to voltage fluctuations.
If you're wondering why there are no diodes against back-emf don't worry: they're inside the uln2003 ic :)
You can copy my circuit layout or make your own, I tried to use as little space as possible by keeping all the components close and making a sort of +5v and GND parallel rails. Note that to be effective the .1 uF cap should be placed as close to the microcontroller as possible. If you're not familiar with capacitors, be careful and do not invert their polarity! The marked, shorter leg is the negative one!
I've chosen a cheap 5v usb battery charger as power supply (be sure it's regulated!), and I've cut off an extremity of a spare usb cable to solder it to the circuit. I've designed a hole on the back of the base to pass the cable through it. The whole thing draws about 200 mA when the motor is spinning, and virtually no current (ok, some microamps) when idle, since the code I've written sends the microcontroller to sleep while waiting.
I haven't used a socket but I've soldered the ATtiny directly, however I do not recommend this. Use a socket. Really.
There's no on/off switch, I don't think this thing really needs one and I don't mind sporadically plugging the usb cable from the charger. You can edit the .stl and add a hole on the base to insert one, if you want.
Now that you've soldered everything I suggest to apply some sealing glue on everything that may cause a short circuit when the whole thing will be pushed inside the base (I covered the bottom of both boards and the uninsulated wire parts), so you don't need to worry if the thigs get messy when you stuff them inside the winder.
Step 4: Print the Winder
You can find all the stl files here on thingiverse. I printed mine with 0.2 mm resolution, 60 mm/s and 20% infill, supports enabled, no raft.
The lateral wings on the central holder are chamfered because this way the printer doesn't need to make supports to print this piece.
If you want to edit the model to fit your needs don't worry: here you can dowload the Fusion 360 file (or other formats if you don't use Fusion)
I'm currently working on making a similar model without the outer cylinder, since while assembling it I noticed it doesn't look bad at all with just the rotating part, to check the latest file version follow this link
Step 5: Assemble!
Pull out the exceeding part of the usb cable, put the circuitry inside the base, use some cyanoacrylate or resin to glue the stepper in place, insert the rotating cylinder on the motor shaft and glue it through the other side of the hole. Mount the outer cylinder.
Now glue a disc of transparent plastic (or plexiglass, or even real glass) to the cover piece and insert this one on top of the winder. I have yet to find a cheap solution I like for this step, I could skip it but I want a bit of protection from dust. Anyways, the diameter of the transparent disc has to be between 80 and 82 mm: I've added some extra spacing in the design to make up for imperfect cuts.
I've also designed a piece to put the watch on before inserting it in the winder, so even if you have a small watch it should be stiff and not moving around. The lateral wings on this are chamfered because this way the printer doesn't need to make supports to print it.
Step 6: Enjoy!
Now you've made your very own watch winder! Go tell your friends!
Design Now: 3D Design Contest 2016
Runner Up in the
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    43 Discussions
    maljg
    Question 1 year ago on Step 2
    Electronic components have arrived and now trying to program Attiny. When you say create new AVR C project does it matter what you call it as you didn't specify in instructions. Thanks
    1 answer
    Simo_Daxmaljg
    Answer 1 year ago
    No, call it whatever you want
    antonio_scalone
    1 year ago
    Love this project! Simple yet elegant. Most automatic watches charge with a clockwise and counterclockwise movement either. How would you change the script to have the motor spin in both ways??
    Simo_Daxantonio_scalone
    Reply 1 year ago
    Hi,
    This project is far from perfect, as cheapiness was the main goal, but thank you, I'm glad you like it!
    As for the movement well, if you need to need to reverse the spinning direction just change the line
    PORTB = lookup[i];
    into
    this way the array containing the steps is read backwards.
    I don't see the need to spin both ways once you know the direction your watch uses to charge itself, it'd just make the code messier - do you want to keep the same charging time? Double it? Or reverse the direction every other cycle? There are many options. I'd stick with either cw or ccw solution
    wissmann.fSimo_Dax
    Reply 1 year ago
    greate it works now clock wise ! Thx Felix
    antonio_scaloneSimo_Dax
    Reply 1 year ago
    I think you are right. Changing the spinning direction once in a while would look nicer but mostly useless once the proper charging direction has been set (clockwise or counterclockwise) according to the manufacturer recommendations. The simplicity of your code is definitely a plus! Knowing how to change the spinning direction will let me to adapt the project to any watch! Once again...thanks!
    maljg
    1 year ago
    Sorry, its me again. Trying to build the AVR C project as described and I am using Atmel Studio 7. I copied the code as stated and hit 'build' but it is showing 14 Errors. Took a screen shot, any ideas?
    Simo_Daxmaljg
    Reply 1 year ago
    You pasted in the line numbers too, remove them.
    maljgSimo_Dax
    Reply 1 year ago
    Hi,
    Sorry, but as I said I am completely new to this and nothing abut coding and very little about electronics but your project looked so cool and I need a watch winder. Have now compiled your code without any errors but there were some warnings, see Pic. anything to worry about?
    Simo_Daxmaljg
    Reply 1 year ago
    It's fine, don't worry
    maljgSimo_Dax
    Reply 1 year ago
    Thanks for th reassurance. Have finished 3D print and looking good. Just waiting for electronic components to arrive. Thanks for your help.
    maljg
    1 year ago
    Still printing out and hit one snag, when printing the Central-Holder my 3D printer seemed to think the wedge shaped lugs were not connected to the main body and printed them out not attached but on their own support structure. Guess its just a blip with my slicer software or the way my printer interpreted the code. So had to 'glue' them on. Also, in the first picture on the first page it looks like there is a metal plate down inside the body, what is this?
    Simo_Daxmaljg
    Reply 1 year ago
    There's no metal plate, it's just the rotating part rendered with a different colour
    maljg
    1 year ago
    I am 3D printing the parts as we speak and have ordered some of the components via the links but when I click on the 10uF link it links to a ATtiny85 component in Ebay. I am completely new to electronics so I need help as to a) what this component might look like and where I might source it in the UK. Can anybody help please.
    Simo_Daxmaljg
    Reply 1 year ago
    Whoops, links fixed. You could buy them on ebay.co.uk if you want to avoid an international shipping or, more conveniently, go to a local electronics store and you won't pay any :)
    By the way, the 10uF is an electrolytic one, it's cylinder-shaped, the 0.1uF depends, the cheapest is a ceramic one, it looks like a small coin with legs.
    maljgSimo_Dax
    Reply 1 year ago
    Thank you for your quick response. I don't mean to be picky but I thought you might want to know that now both capacitor links now go to the same thing.
    Simo_Daxmaljg
    Reply 1 year ago
    Yep, you can but both from that same link
    maljg
    1 year ago
    H, sorry to be a pain but this is all new to me. Just installed Atmel Studio. Clicked on New - project but can't find ATtiny85 on drop down list. What am I doing wrong, please?
    nelman
    1 year ago
    I like the simple design of your winder! I'm printing one right now. What do I need to change in the code so that the motor rotates 360deg CW, pause for a few milliseconds then rotates 360deg CCW? TIA!
