3D Printed Water Motor
20,973
238
20
About: Hi, I'm Johan Link, a 18 years old student living in Switzerland. I love robotics, computers, 3D printing, photography and skate. https://www.thingiverse.com/JOHLINK/about
This is a water motor, connect a water pipe to the motor and then it works. It's very simple. I made this, because I wanted to make a mecanical project with fusion 360.
If you like my Instructable, don't forget to vote for me in the contests. :) Thanks!
Step 1: How I Made It?
I am a beginner with Fusion 360, I wanted to make a difficult project to train myself at Fusion 360. It tooks me 3 days to draw this object.
Step 2: How It Works?
It 's a simple concept, there is a gear inside the motor, when the water flows the gear turns and a gear system lowers motor speed and increases torque.
Step 3: How to Make It?
If you want to make it, you can download the stl files, and you can print it.
Use Nut with seal, it's important. All the bolts have a diameter of 4 mm.
I print this with the K8200 printer, and I use Cura to generate the G-code.
My Print settings:
  1. Bottom/Top thickness 0.6mm
  2. Fill Density 20%
  3. Platform adhesion type: none
  4. Support type: Don't use support!
  5. Use PLA or ABS.
If you want to modify this design you can download the Fusion files with this link: http://a360.co/2sOvVtE
hope you enjoyed reading this instructable. :)
I am 16 years old and I speak french, excuse me if I made errors of English in this instructable.
Explore Science Contest 2017
Second Prize in the
Invention Challenge 2017
Runner Up in the
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    20 Discussions
    pgm8693
    3 months ago
    Would make a very good class project.
    deluges
    1 year ago
    Neat. It'd be useful to power one of those swinging automatic sprinklers or whatever they're called
    bsims1jackreno11
    Reply 1 year ago
    Holy smokes! Y'all just invented an unlimited free energy machine the government doesn't want you to know about.
    delugesbsims1
    Reply 1 year ago
    bsims1 CIA Agent 1°97372910° you have been compromised please destroy your phone asap and meet Daryl at point alpha fox
    MikeT215
    1 year ago
    Does this have enough torque to turn a small generator (like the kind you would find on a bicycle for headlights)?
    Johan LinkMikeT215
    Reply 1 year ago
    When there is a lot of water pressure, you can easily run a small generator.
    towellm
    1 year ago
    This is a great project. You've included several fundamental concepts of physics seamlessly in one simple mechanism, excellent work. This could be the start of a very effective, programmable lawn sprinkler or other useful device. Your turbine is using a mix of viscosity and momentum that you can more precisely control without much modification to your current design. You have most of an impulse turbine. Consider improving your design to (1) create controlled momentum and (2) take advantage of that momentum in a controlled fashion. Google "Pelton Wheel" and "impulse turbine".
    ElectroFrank
    1 year ago
    Nice machine. Would energy transfer (efficiency) be improved if the the water went all the way round the top, instead of the short cut across the bottom of the chamber ? (Like a turbine in a dam ?)
    Small technical point: your gearing increases torque, not power (and reduces speed). Gearing always reduces power, because of frictional losses.
    Johan LinkElectroFrank
    Reply 1 year ago
    I can't answer your first question (I have no idea, sorry) ;)
    You're totally right about the technical point. I misspoke.
    bfulton3
    1 year ago
    Really nice project! I don't think you get to call yourself a fusion 360 beginner anymore ;)
    rich.altmaier
    1 year ago
    Is the water chamber watertight? Is there any leaking? Does it leak if the exit is capped?
    Johan Linkrich.altmaier
    Reply 1 year ago
    The water chamber isn't watertight. The first prototype I made was watertight, but the water chamber was full of water and this prevented the turbine from turning properly. So I drilled 3 holes on the back of the water chamber. (You can see these 3 holes in the last image of step 1).
    samern
    1 year ago
    Very nice! Love it. Reminds me of my experiments with a Tesla equivalent.
    DejayRezme
    1 year ago
    Oh I was wondering why the water shovels are the "wrong" way around, but it's not a pump, it's a motor to creates rotation!
    ancienthartgm280
    Reply 1 year ago
    Ohh, my vote for that as well please. :D
    Johan Linkgm280
    Reply 1 year ago
    Thanks for the comment, I've just add a video in step 2 :)
