3D Printed Wine Bottle Carousel
318
9
About: My name is Duncan Smith and I am a designer and maker using 3D printing to create awesome products for the home and office. Check out my website for more 3D printing builds or downloadable STL files.
This build is a complement to the Wine Glass Shelf build, you can see that here. This build is almost completely 3D printed with the exception of one hardware piece. With a simple finish and assembly, you can enjoy a rotating wine bottle carousel.
Step 1: ​What You Will Need
Materials:
3D Printed Carousel
3D Printed Base
Lazy Susan Turntable Bearing
Primer
Bronze Spray Paint
Clear Coat
Glue
Sanding Paper
Tools:
Orbital Sander (optional)
Any/all necessary protective equipment.
***Links provided are affiliate links if used to purchase something may provide Adylinn Studio a small commission.
Step 2: 3D Printed Parts
The print time for the carousel is quite extensive at its current design so I would not feel comfortable recommending 3D Hubs since the cost would likely be too high to justify.
For those of you who do have a 3D printer, I recommend the following settings:
Carousel (decent surface quality to limit amount of sanding needed)
Filament choice not really important
0.2mm layer height
25-30% infill
Support required
Raft recommended due to minimal surface contact
Base
0.2mm or higher layer height
15-20% infill
No Support
Brim optional
Step 3: Finishing 3D Prints
  • Remove raft and support material.
  • Sand carousel to the desired smoothness. Start with 220 or 320 grit and move up until you have a nice smooth part without visible print lines.
  • Wipe the sanded parts with a lightly damp cloth or paper towel.
  • Apply even and light coat of primer.
  • Allow enough time for primer to dry, then sand lightly.
  • Once the parts are dry, evenly apply light coat(s) of bronze spray paint.
  • Once the parts are dry, evenly apply light coat(s) of clear coat.
I will sometimes use a healthy amount of spot putty to help with print lines on parts that are difficult to sand. I will typically do this after the final sanding and before the primer.
Step 4: Assembly
  • Glue the turntable bearing onto the carousel and base respectively. Alternatively, you can fasten the bearing with screws.
  • Insert wine bottles and enjoy your Wine Bottle Carousel!
Step 5: Wrap-up
Thanks for checking out the Wine Bottle Carousel 3D Printed build! If you enjoyed it, I post monthly builds using 3D printing on my website, https://www.adylinn.com/builds/.
    • Organization Contest
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest
      Paper Contest
