3D Printing for Two-Part Silicone Molds
3D printing is a great process for producing parts of high complexity. Any part is no more costly to make than the next, generally speaking. Still, 3D printing is not always the best method for producing multiple copies of these parts, as the process can be slow and the material options are somewhat limited.
To expand the possibilities available to us, we might look at processes with a much longer history - mold-making & casting. Instead of printing our desired object directly, we can use 3D printing to produce either the mold itself, or, as we will cover in this Instructable, augmented positives (contra molds) with which we'll make a 2-part silicone mold.
A few notes before we begin: the sample part here has no undercuts - features in the shape that will prevent its removal from either half of our mold. If we wanted to cast something with complex undercuts, that would require a different molding strategy, but that's for another Instructable! Secondly, this Instructable will illustrate the software workflow using Rhino, but you can achieve similar results using the software you're most comfortable with. This Instructable assumes a basic level of modeling proficiency and the ability to produce files for 3d printing. If you're curious about how you might go about this project in another modeling package, just leave a comment and I'll try to suggest something.
Lastly, a big thanks to Hannibal Newsom for providing the sample 3d model of the component for casting.
Let's get started!
Step 1: Establish Parting Line
A parting line is where two portions of a mold meet. Our goal is to draw a parting line such that neither of our molds sees any undercuts. We can generate a parting line very simply using Rhino's Silhouette command.
Move into an orthographic view that matches the orientation of your intended mold - in my case, the top view - and select your part (see image). Run Silhouette to generate the parting line in the active view. Run the Join command and clean up the resultant curves to arrive at a continuous parting line (see second image).
Step 2: Establish Mold Boundary
We need to establish the perimeter of our mold. Most silicone rubbers recommend a mold wall thickness of 1/2" - 3/4", so our mold boundary will need to have approximately that distance from our part. Using the Rectangle command, draw the edge of the mold, leaving the necessary space between it and your part.
Step 3: Create Mold Surface
Now draw a line perpendicular to both your parting line and to your mold boundary line. You can do this automatically by running the Line command, selecting the Perpendicular option, then the 2Curves option, and finally clicking the two curves near where you'd like the line to be drawn.
Then create the mold surface with a 2-rail sweep. Using the Sweep2 command, select, in order, your parting line, the mold boundary curve, and your perpendicular line, and press enter. You can typically accept the default options for the sweep dialog box. This will build the mold's surface between the parting line and the boundary as seen in the image.
Step 4: Adding Registers & a Pour Spout
In traditional mold-making, we'd include additional features by molding them from clay before casting our mold. Since we'll be 3D printing our positives, however, we can add features like registers and a pour spout now.
Registers help ensure consistency and accuracy with each cast by aligning our mold halves precisely each time. A tapered pour-spout will act as a funnel for our casting material, making it easier to pour into our mold.
Begin by using the Sphere command, drawing a sphere centered on the surface of the mold in one of the four corners. My registers were made using spheres with a 1/2" diameter. Then use the Mirror command to copy the sphere to the remaining corners of the mold as seen in the images. Be sure to mirror them using the midpoints of the mold boundary edges as the lines of reflection. This will ensure that the opposing sides' registers line up correctly.
Then, using the Pipe command, create a tapered pour-spout. You can re-use the perpendicular line you created for your sweep surface from the previous step. My spout began with a diameter of 1" and tapered to a diameter of 1/4".
UPDATE: Thanks to Instructables user cansupe for catching that the pour-spout is not located at the highest part of the mold. This will lead to trapped air during the cast. I noticed that the part did end up with some air bubbles in these locations. Were I to make a mold for production, I would include two spouts, one at the peak of each of the ridges to either side of where the pour-spout is located in the shown model.
Step 5: Extrude and Make a Copy
Using the ExtrudeCrv command, you can create the sides of your contra mold. Your mold doesn't need to be particularly deep, as it is the depth of the silicone you will pour on top that will be the thickness of the final mold.
Now take the entire part you've been working on and drag out a copy. Congratulations - the first half of your mold is finished, and the second half should come together even more quickly.
Step 6: Flip Your Part to the Opposing Side
Rotate your part to so that the side opposite the face you've been working on is now visible. Ensure that your axis of rotation is along the midpoints of your mold boundary edge - this ensures that your registers align properly.
Step 7: Trim Registers & Extrude
Use the mold surface to trim the registers, then use the trimmed registers to trim the mold surface (see pictures for reference).
Now extrude this half of the mold's boundary edge to make your second contra mold.
Step 8: Join, Boolean, & Export
You now have all the geometry you'll need to print your contra molds. You'll likely need to join surfaces, boolean parts together, and export to a printable format. Depending on the software you've been using, the specifics of this can be slightly different. I've included some links to resources below.
Rhino:
Video by Kyle Houchens of McNeel (makers of Rhino) - lengthy, but excellent
Guide by Facundo Miri for McNeel Miami
Maya/Mudbox:
Instructable by Jesse Harrington Au
Blender:
Instructable by user PS118
Sketchup:
Instructable by Ryan Matthews
123D:
Instructable by user sath02
Step 9: 3D Print
You can make your parts with whichever 3D printing technology you prefer or have access to. Here, I've used a plaster powder printer to make my contra molds.
Step 10: Build Mold Boxes
Build a box that surrounds each of your parts. You want to ensure that the walls are tall enough to account for all the silicone that you will pour on top. In preparation for this, mark off on the side of your mold the height that you will need to pour to (about 1/2-3/4" above the highest feature of your part). Try to ensure that your box is as tightly assembled as possible - silicone is expensive and will leak out otherwise!
As a note, I didn't adhere my part to the bottom of the mold in any way because the part was very tightly held by the sides of the boxes. If this isn't the case for your part, you might consider fixing your part in place with glue, tape, or screws. Otherwise, the silicone can seep underneath and lift your part, ruining the mold.
Step 11: Pour Silicone Molds & Wait
For my rubber molds, I'm using Smooth-On's Mold Star 15 SLOW two-part silicone product. I chose it for the good experience I've had with it in the past, and its pot-life is very forgiving (50 minutes, as listed). This gives me plenty of time to make sure I've got a properly mixed product without worrying about the material setting up.
Follow the manufacturer's directions for whatever product that you end up using, of course. For technique, you want to pour a thin stream from several inches above your part, concentrating on its lowest point. This helps ensure that the silicone seeks its own level as it rises up and over the model, while displacing air to reduce the presence of bubbles as much as possible.
After you pour both halves, give the silicone a few minutes, checking back occasionally to make sure that there are no leaks in the walls and that your part is held securely to the bottom of the mold.
Step 12: De-Mold
After the cure time (I always double whatever the manufacturer lists, but that's probably being overly-cautious), remove the walls of your mold. You may need to apply some force as the silicone will likely grip any porous material (like plywood) it comes into contact with.
NOTE: I did not use a release agent on my contra mold. I was concerned about the possible weakening of my raw plaster part due to the release agent. I hope to do another mold test, this time with a glue-infiltrated plaster part and seeing how a release agent affects de-molding. This would hopefully result in re-usable contra molds. I will update this Instructable if I can test that modification.
Remove the printed parts from the silicone molds. Depending on the material you used for the print, this may mean sacrificing your prints. But, if all has gone according to plan, this shouldn't be a big deal because now you can...
Step 13: Cast Until Your Heart's Content
You can hold your molds together one of several ways: rubber bands, velcro straps, a wooden mother mold (box that holds your molds together rigidly), or some other way. Mix whatever material you plan to cast - plaster, concrete, resin, etc. - and pour into your molds. You've opened up a world of rapid production and material possibility for yourself.
Any comments or feedback about this Instructable is greatly appreciated. Please leave a note in the comments. Thanks for reading, and happy casting!
    • Pocket Sized Contest
    • Epilog X Contest
      Epilog X Contest
    • Tape Contest
      Tape Contest
    14 Discussions
    sk8er6
    2 years ago
    thank you for going though the process of making these molds. Definitely will save me a few bucks and time. Looks a much cleaner result than clay I might add.
    pdeloreyAngDugyot
    Reply 2 years ago
    The print was made in a gypsum-like material with a plaster powder / ZCorp-style 3d printer (see step 9).
    ValC1
    3 years ago on Introduction
    Fantastic instructable!
    I am going to try this.
    IanJ1
    4 years ago on Step 13
    You could make the mold box part of the printed geometry. The walls wouldn't have to be very thick, so it wouldn't add too much printed material. It would be a little harder to demold since you can't take the walls apart, but you wouldn't have to reassemble the box every time you wanted to make a new mold. Also it wouldn't need to be square. The outline of the mold could match the outline of the part, offset by 1/2". That way you wouldn't waste silicone filling the corners of a square box surrounding a round master.
    pdeloreyIanJ1
    Reply 4 years ago on Step 13
    Absolutely - though there are some good reasons you may not want to. Since the box was screwed together, it comes apart and back together in about 2 minutes and makes de-molding much easier than it would be if the walls were permanent features. It also increases the likelihood of accidentally damaging the part during de-molding.
    Still, your thought that it might result in some savings on silicone is a good one. Those savings would just need to be measured against the added difficulty of de-molding, potential for damage, and the marginal added time and expense of printing the walls in addition to the rest of the part.
    dogbrand
    4 years ago on Introduction
    Isn't it possible to cast the material into 3D printed mold insted of making silicon molds first?
    I'm planning to cast Shore 60A urethane rubber into a 3D printed mold. First I'm going to degaus the rubber and than gravitationaly cast it. Do you have any similar expiriance? Any advices?
    pdeloreydogbrand
    Reply 4 years ago on Introduction
    Absolutely - it's just that for a mold that you plan to use many times (50-100+), the silicone will provide for much easier de-molding, reducing overall cycle time. Silicone's flexibility also allows for slight undercuts if your part happens too have them.
    As for your project, I've never had access to degassing (and haven't taken the time to hack a setup together), so I can''t speak to that, but as for casting, just make sure you use adequate mold release as urethane rubbers are notoriously sticky. Also, depending on the type of printing you're doing to make your mold, latent moisture could be a consideration. Urethane rubber is very sensitive to moisture. As long as your mold is bone dry and you adequately prep your mold, I think you should be fine.
    pdeloreySpaceman Spiff
    No experience with injection molding personally, but typically those molds are machined from metals to account for high part volumes. My guess is that the silicone would not be rigid enough for the kinds of tolerances that injection molding is used to achieve. Maybe look into rotational casting and the mold-making associated with it if you want to get those types of parts.
    cansupe
    how did you manage to fill the top parts with a sprout that's not on the highest point of the mold? didn't you trap air in there? it feels like air should have been trapped :/ makes me wonder why so many of my old molds failed, if it wasn't the sprout level thing ..
    pdeloreycansupe
    Good eye, cansupe. That was something I actually did see in places on the finished cast, and something that I should correct for a production-level mold. I'll make sure to include a note in the instructable about this detail. Thanks for the catch!
