3D Router: When a CNC Machine Is Overkill.
142,104
1,489
115
About: My name is Suso Caamanho. I like doing all sorts of stuff related to musical instruments, woodworking, computer science, electronics... On my website you will find more information, projects, plans, photos...
The idea arose after dealing with the difficulties and loss of time in preparing for certain CNC jobs. Sometimes I spent more time preparing for the CNC than the work itself. With this manual router, you can make holes or mill very fast. A 43mm Clamping Collar makes it very versatile and you can change the milling tool to drill very fast.
There are certainly lots of wooden router table and CNC router plans floating around in cyberspace. What makes this project noteworthy are the feature set and the cleverness of how it’s all put together and designed for maximum versatility. This router table can be used as a 3-axis drill press, sanding station, a 2D router, and you can do simple shapes 3D milling via a reference model. Using a series of accessories, you can also cut circles, straight-cut squares, and cut to a 2D reference model.
The uses of this tool are varied. I am a guitar maker and my plan consists of devising several templates of guitar bodies and necks to be made with the 3D Router, without switching on my CNC. Besides, it can also be used for other woodwork tasks. I have tried to make a design which can be easily built, with rather simple and cheap. Check out the Youtube video.
  • Overall dimensions: 800mm high, 740mm width and 700mm depth.
  • Useful dimensions: 425mm in X Axis, 535mm in Y axis and 185mm in Z axis.
What You'll Need:
  • Woodworking tools
  • A sheet of 18mm thikness plywood (2500x1250mm)
  • 32 ball bearings (608)
  • 5 Lineal meters L perfil of steel (1mm thikness)
  • 500mm steel piper, 10mm exterior diameter and 8mm inner
  • A lot of M8 and M6mm metric screw
  • A lot of M8 and M6mm Washers
  • A lot of wood screw
  • Number 23 Metal spring 140 x 22mm
You can also check out my website! www.paoson.com
Epilog Challenge:
This tool would be very useful for Luthier jobs, to engrave truss rod covers, pickguards, picks and other guitar parts, even to engrave my logo.
Youtube Video
Step 1: Designing the Project.
I have designed the project in Autocad, a 3D model which I made several construction layouts for. Plans are available on my website. Parts of the layout can be life-size printed; you can paste them on the plywood and cut, or just use the plans as a reference and then measure, as I usually do it.
Step 2: Starting the Project.
Using my homemade Router & Saw table to start this project. Making this tool requires great precision and considerable experience in woodworking. Cuts should be perfectly straight and square. They must be axis parallel and well aligned, to avoid bumps on bearings, otherwise, the tool will start vibrating.
https://www.youtube.com/watch?v=srq9sA9lfxM
Step 3: Assembling Table and X Axis.
Finish cutting, sanding and prepare all the pieces according to plans. Then, start assembling the axis metal profiles (L-shaped). They must be made of iron or steel. I've used aluminum, but, as it is softer than the bearings, a groove can be made on the metal profiles, which after long term use may cause width . You can glue it or screw it preventing the screws from touching the bearings. Use a rule to leave them paralell and straight.
https://www.youtube.com/watch?v=es6nkWRrCfY
Step 4: Finishing X Axis and Beginning Y Axis.
Once the X-Axis bench is assembled, start with the bearings of this Axis, as you can see on minute 2.45, we must enlarge the 8mm hole in the direction and areas that are marked on the plans to adjust bearings to the metal profile, to prevent width. Use dowels to reinforce some parts that require more strength.
https://www.youtube.com/watch?v=6yZo7YMXnG8
Step 5: Continue Assembling Y Axis.
When the Y axis frame is assembled, before starting with the Z axis, needless to say that this frame should be perfectly square so as to faultlessly slide along the arms of the X axis. So far, we have done most of the work!
https://www.youtube.com/watch?v=3qS4HVTwCD8
Step 6: Finishing Y Axis.
Assemble the bearings that go along the Y axis frame and test the Z-axis bearings before mounting this part on the machine. Cut and test the Z axis spring.
https://www.youtube.com/watch?v=C27xt1JFRi0
Step 7: Starting Z Axis.
Continue with the Z axis, assembling all parts. The 43mm Clamping Collar should be very exact, do it with the right drill bit or a CNC. Make sure the milling machine is well fastened because it might come off with the vibration.
https://www.youtube.com/watch?v=a8Hxy83jzKM
Step 8: Assembling Z Axis and Accessories.
End the Z axis with the actuating lever and other accessories such us the elevator control, fast clamping sleeves and the axis brakes, whish are also made from 18mm plywood. We must also finish the guideway and the worktable.
https://www.youtube.com/watch?v=caS1N_kuu2M
Step 9: Ending Z Axis, 2-3D Followers and Circles Follower.
This is the end of the 3D Router project. Finish the Z axis and the 2 and 3D followers. The parts that fasten these followers must be very firm and secure. Use glue and screws.
https://www.youtube.com/watch?v=ae8Lgmv_slw
Step 10: Electric Guitar Body on the 3D Router (part1)
Before starting this project, I install a block on the Z axis in order to mill from the rear, without having to pull the lever, which is very useful for certain pieces of work with the 2D Follower. I made the templates in a CNC for the 2D contours y for the 3D top of the guitar. If you do not have a CNC, I recommend that you order them from someone who has them. They could also be made by hand but, if it is done accurately, some good templates may be used to duplicate a job at any time! In this situation, we could also use a real guitar as a template. I made two bases of 700x350x10mm on MDF in order to hold and locate the pieces to be worked on.
Step 11: Electric Guitar Body on the 3D Router (part2)
The bearing of the 2D Follower must have the same diameter as the router bit, or install a smaller bearing if you are looking for a bigger milling cutter than the one in the template itself. The depth of each pass on Z axis depends on the material and the work tool. As you can see in the video at 2'50 min, the 2D Follower can be used from ahead or from the back. Personally, I prefer from the back because I feel more at ease with the template.
Step 12: Electric Guitar Body on the 3D Router (part3)
I lower all the elements of the Y axis, bringing the milling cutter close to the piece to be worked on. Then, I adjust the height of the touch probe in order to use the 3D Follower. As I am going to lower the cover by passing several times on Z, I first leave the milling cutter at a slightly higher level than the touch probe. In the last pass, these heights must be identical. As with the 2D Follower, I prefer milling from the back because I feel more at ease with the template and it is less dangerous.
Epilog Contest VII
Runner Up in the
Epilog Contest VII
    • Epilog X Contest
      Epilog X Contest
    • Paper Contest
      Paper Contest
    • Build a Tool Contest
    115 Discussions
    RockerTony
    3 years ago on Introduction
    Sir, you are a fargin' genius! You're not just a guitar builder you are a full blown certified mechanical whiz-bang engineer! I build guitar amps 'cause I'm good at electronics, but suck at woodwork, which is why all my builds are in a prefabbed metal cage, like a lunchbox type amp. I don't think I could build this even with all your drawings. I am jealous of your talent! ;-) Oh yeah, and I voted for you!
    fitz.pockRockerTony
    Reply 3 years ago on Introduction
    I couldn't have said it better than RockerTony, and I don't even know what fargin means. What an awesome project, Paoson. Hope you get hired as a consultant at a major tool company, and next year we will all be able to buy one at Home Depot!
    bigbigdavebigbigdave
    PS - To my fellow Instructablees, sitting mouth-agape after seeing this, make sure to vote in the upper right corner. I don't care what contest this is in the running for, it should win, IMHO.
    alcurb
    Excellent project. I only wish you had provided the plans at no cost.
    Gartholameau
    Incredible! Can I have one of the 50 prototypes you made before coming up with this final mechanical marvel? :-) This is beyond impressive and is well into the realm of wood art.
    thanks, i ordered your plans before you replied. i guess when you send them i'll see what i can do with them. thanks again
    What a nice solution for many basic workshop tasks! I have to build similar gizmo out of alu extrusions! I built a small CNC but there it just stands collecting dust... This is the way to go!
    Phil_S
    Very nice.
    Arms work just as well as steppers, nice use of bearings and angle profiles.
    Must have taken a few hours with pencil and paper - but, please mind the MDF dust and some ear plugs wouldn't go amiss. An old vacuum cleaner rigged up on a rope from the ceiling would keep a clean and safe bench.
    Otherwise, 5-stars for ingenuity and bringing it to completion.
