3D Smartphone Hologram Beta Type
33,397
423
15
About: Thank you instructables!!
You might have seen earlier instructables such as 3D projection pyramid they all contain the hologram design as pyramid.But in this tutorial I am going to shown you how to make a full screen covering 3 slide 3D projection this is clear and bright.See a video of it working :-
Step 1: Things Required to Make It
To make hologram you need :-
  1. Clear plastic box or sheet (sweet box will work)
  2. Marking pencil or marker
  3. Ruler
  4. A pair of scissors
  5. Smartphone
This is all you need for this.
Step 2: Measuring the Smartphone
Take scale and measure the screen dimensions of your smartphone .The screen dimensions of my Xperia m dual are 5 cm * 9 cm .It depends upon your smartphone size.
Step 3: Pieces Measurement
My phone's length of screen vertically was 9 cm so after every 3 cm I will Join a piece as it is 5 cm wide so make every piece 5 cm wide. Now you need 9 cm plastic stick that would act as base for it (joining) and the last piece should be opaque covering the three vertically standing pieces.
Step 4: Cutting the Pieces
Using the marker mark the dimensions over plastic sheet and using a scissor or a blade cut them out .Use a paper for the last piece.Now we have total 6 pieces.
Step 5: Joining
With hot glue or some other strong glue join the pieces .Make sure that the angle between the vertically standing piece and screen should be of 45 degrees for every piece.
Step 6: Joining the Roof
Use duct tape or epoxy to join the paper to the plastic sheet cover the top portion only .And now your hologram is ready !
Step 7: Searching Videos on Youtube
I think this project would be loved by all of you and kids especially .This is a fun project involving virtual images .Some youtube videos suitable for this hologram are :-
  1. Click here 1
  2. Click here 2
  3. Click here 3
You might love it.Keep enjoying with this hologram .
Thanks!
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    15 Discussions
    MechanicalMashup
    2 years ago
    Here is a fun twist on this:
    https://www.instructables.com/id/Peppers-Holographic-Watch-Built-in-Minutes/
    BiCkOnE
    3 years ago
    This weekend's project, thanks!
    CubeKnight
    3 years ago on Introduction
    Wow, do you think it might work with acetone sheets? This is one of the coolest things I've seen.
    It can work but if they are not so much strong then you need to support them using sticks! thank you too much friend! best of luck for your project!
    I don't know the exact measurements! sorry but I would prefer you to use old plastic boxes or cellophane paper that is strong enough to be stable on screen!Best of luck for your project!
    htempah
    3 years ago
    nice project. I made the pyramid version. I'm yet to try this model out.
    Doc Penguin
    3 years ago
    this is even more authentic that tje projection pyramid. Thank you very much
    Akshay Jha
    3 years ago
    Looks intresting nice work . I have voted for you & thanks for sharing
