3D-printed Fumeextractor
1,615
45
About: DIY, 3Dprinting,Concrete, Electronics, Maker http://www.kims3diy.com
Hi everybody! You know that soldering is bad for your lungs? Thats why i will share my design of this fumeextractor!
Step 1: You Will Need the Following Things.
Tools:
Solderiron - https://goo.gl/SE2Kiz
Cutting Plier - https://goo.gl/HxB7kO
3D-printers - https://goo.gl/OHhp14
Things:
Carbon filter - https://goo.gl/hXXzlO
9V adapter - https://goo.gl/BCA48r
9V-PSU - https://goo.gl/3RBQqJ
140 mm fan - https://goo.gl/uETtti
M3 screws, 4 pcs of 45 mm or 8 pcs of 4x20mm depending on what fan you buy.
The 3d-printed parts:
http://www.thingiverse.com/thing:2023366
Step 2: 3D-print the Needed Parts
I printed ABS and i printed it with 20% infill. Worked great for me.
Step 3: Assambley
Make sure you mount the fan at right flowdirection, tight the 4 m3 screws.
Step 4: Assamble the Front
Tight the last m3 screws.
Step 5: Carbon Filter
Use a scissor to cut the edges of the carbonfilter and insert it in the frame.
Step 6: 9V Adaptor
Use the cutting plier to peel of some isolation from the wires and tight the screws.
(Red+, Black-)
Step 7: You Are Good to Go!
Enjoy guys! Thank you for watching my instructable.
Please check out my youtube channel and subscribe.
    • Epilog X Contest
      Epilog X Contest
    • Pie Contest
      Pie Contest
    • Paper Contest
      Paper Contest
