3D Printed Laser Engraver
129,839
1,255
45
Hi folks!
I built my own laser engraver and want to share it with you in this 'ible'! I made it with the help of my 3D printer.
I saw this one http://www.banggood.com/500mW-Desktop-DIY-Violet-L... and thought i could print the acrylic parts. This is why i made it.
My working area is:
X 265mm
Y 345mm
But it depends on the aluminium profile you´ll buy.
My parts are:
Frame
- 2x 440mm
- 2x 320mm
X axis
- 370mm
Step 1: Get the Parts
What you will need:
1. 3D printer ;-)
2. PLA (any other material will work i think) http://www.amazon.de/NuNus-Filament-MakerBot-Maker...
3. Aluminium profileshttp://www.ebay.de/itm/150956267616?_trksid=p20578... (i used the 6mm groove. You can also try 5 mm groove, then you maybe don´t need the roller .stls)
4. Slot nuts and inner squares
4.1 Slot nuts
You´ll need 6 slot nuts. I bought them here http://www.ebay.de/itm/161168970108?_trksid=p20578... but i think you can also print them.
4.2 Inner Squares
To connect the frame parts i bought them here http://www.ebay.de/itm/281585620876?_trksid=p20578... maybe you can also print them. 8 pcs.
5. Screwsand nuts (buy them at your hardware store)
12x M6x25 (To fit the feet and the side parts of the x axis you´ll need)
12x M5x20 to attach the bearings to the moving pats
3x M5x45 to connect x-axis moving parts
4 screws fot the slut nuts (i used M4)
2x M2 to fix end stop to y axis foot
Some M3 to fix the motors
6. Bearings
You´ll need 13 peaces http://www.aliexpress.com/item/chrome-steel-bearin...
7. Rod (length depends on your build)
1x http://www.ebay.de/itm/181470570665?_trksid=p20578...
8. Pulleys and belt (you need three pulleys or print them)
http://www.banggood.com/2-x-GT2-Timing-Pulleys-+-2...
http://www.aliexpress.com/item/2pcs-Lot-GT2-Timing...
9. Maybe endstops
2x http://www.banggood.com/10Pcs-KW12-3-Micro-Limit-S...
10. Laser heat sink
1x http://www.banggood.com/12mm-Laser-Module-Heat-Sin...
11. NEMA 17
2x http://www.aliexpress.com/snapshot/6619097103.html...
12. Coupler
1x http://www.banggood.com/3Pcs-5x5mm-Motor-Jaw-Shaft...
13. Wiring
http://www.banggood.com/5M-1_27mm-20P-DuPont-Cable...
14. Fan
1x http://www.banggood.com/Heatsink-12V-0_1A-2-Pins-C...
What else will you need?!
- screw driver
- double sided tape
- a drill makes it much easier sometimes
- cable fixers at the moving parts http://www.ebay.de/itm/100-Stuck-Selbstklebe-Recht...
Step 2: .stl Files and DXF
I first printed some parts vertical, but the motor holes were some kind of comressed then. It is much better to print them horizontal...
http://www.thingiverse.com/thing:819755
The dxf files are made by user stevedee78 all credits to him...
Step 3: Assembly
I will post some editorials here later.
At all it is very much self-explaining, but here is it in short. If you have questions i´ll do my best to answer them.
1. assemble the parts with the bearings
2. screw the motors on the parts
3. put the x part on the axis
4. add the side parts of the x axis
5. assemble the frame
6. put the x axis on the frame
7. screw the feet
8. screw the laser parts on it
Step 4: Electronics
All the credits go to ianmcmill for his great support so far.
I got all my instructions from his 'ible'. https://www.instructables.com/id/Frankenstein-Laser...
I didn´t get the laser working yet, but will try to and then publish it.
Step 5: Videos
I hope you like it! In that case please vote for it in the contest!
Step 6: SAFETY
Always wear goggles in an adequate wavelength!
KEEP YOUR EYES SAVE!
4 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
  • IoT Challenge
    IoT Challenge
45 Discussions
dapiguy
4 years ago on Introduction
I seriously need someone to provide a link for the aluminum profiles for purchase in Canada or the US. I can't find a place that's as cheap as yours, and I really want to make this!
Chrome98dapiguy
Reply 3 years ago
inventables
https://www.inventables.com/technologies/aluminum-extrusion-20mm-x-40mm-clear
gneedeldapiguy
Reply 4 years ago on Introduction
Check out the Extrusion from REV Robotics. It is designed for linear motion like what is described in the instructable, and doesn't require special nuts for the slots.
It is available here http://www.andymark.com/product-p/am-2901.htm
Rebelxxx
1 year ago
I wonder how easyDriver boards are able to run NEMA17 steppers. I thought you need grbl shield to be able to run NEMAs. What voltage is enough to run your NEMAs? Mine requires 24V ... (salvaged these from old multiFunctional Canon device) ...
RD7
2 years ago
How much torque does nema 17 stepper motor need?
Chrome98
3 years ago
can anyone tell me how you accomplished the belt clamp? I have 2 types of slot nuts and neither will even fit in the slot with the belt under. I also tried just a nut - same thing. How did you do it?
tobias.sobkowiakChrome98
Reply 3 years ago
Ask the company where you buy the profiles where you can get the right slotnuts...
Chrome98
3 years ago
I believe your spec for the bearing mounts screws is incorrect. they should be 30mm not 20mm. Could you please correct your requirements so that the next person to build that doesn't have a variety of screws on hand won't have to make a trip to return and purchase the correct screws. Thank you.
Chrome98
3 years ago
Could you please provide a printed parts list with quantities needed of each piece? Thank you very much.
stevedee78
Hi could I get the following files to STP, PRT or DXF?
Seite_ohne_motor.stl Seite_motor.stl X_Achse_Beides.stl
I wanted to mill the parts.
Hallo könnte ich die folgenden Dateien in STP, PRT oder DXF bekommen?
Ich wollte die Teile fräsen lassen.
