3d Print Clay in 2 Colors
447
8
how to print mixed porcelain in 2 colors
Step 1: Choose the Materials
to mix the clay, we have to choose the same kind of porcelain (high or low firing temperature) to avoid fails during the firing.
Step 2: Mixing
I use a Wasp clay kit to print in clay with a delta printer.
to prepare the clay, I usually mix the porcelain with 5% distilled alcohol. alcohol is better then water in this case because it evaporates quickly and allow to make the base of the 3d printed part solid in few minutes and prevent the collapse.
Step 3: Pressuring the Tank
Wasp clay kit, work with a pressure and mechanical system.
the tank have inside the clay and a piston and work with 4 to 6 bars of pressure.
the pressure create a kind of vortex in the tank and in the exit tube the 2 kinds of porcelain are mixed casually
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    wilhelm feichter
    1 year ago
    das finde ich eine tolle idee, ich habe noch keinen keramik 3d drucker
    Bin aber auf der suche. gratuliere
