4*4*4 LED CUBE
8,397
47
29
A SIMPLE 4*4*4 LED CUBE USING ARDUINO NANO
Supplies:
Step 1: Get the Materials
Step 2: LET's Make the Cube
make a rough layout in cardboard or wood
drill 5 mm holes using 5 mm drill bit(here i am showing 5*5*5 JIG)
Prepare the LED's
before soldering test all led's with multimeter
use pliers and make a 90° bend in cathode (- ve)
and again bend 90° (see the pictures)
keep repeating this until all of your 64 LED's are prepared
insert 16 led's in jig and solder all anodes together
each layer consists 16 led's with a common anode(+)
make 4 layers like this
now solder cathodes together(first coloumns cathode solder to the first coloumn cathode of second layer )
finally we get 4 anode layers and 16 cathode coloumns
Step 3: Circuit Diagram
from bottom
LAYER 1 CONNECT TO ARDUINO PIN A0
LAYER 2 CONNECT TO ARDUINO PIN A1
LAYER 3 CONNECT TO ARDUINO PIN A2
LAYER 4 CONNECT TO ARDUINO PIN A3
COLUMN 1 TO ARDUINO PIN A4
COLUMN 2 TO ARDUINO PIN A5
COLUMN 3 TO ARDUINO PIN D0
COLUMN 4 TO ARDUINO PIN D1
COLUMN 5 TO ARDUINO PIN D2
COLUMN 6 TO ARDUINO PIN D3
COLUMN 7 TO ARDUINO PIN D4
COLUMN 8 TO ARDUINO PIN D5
COLUMN 9 TO ARDUINO PIN D6
COLUMN 10 TO ARDUINO PIN D7
COLUMN 11 TO ARDUINO PIN D8
COLUMN 12 TO ARDUINO PIN D9
COLUMN 13 TO ARDUINO PIN D10
COLUMN 14 TO ARDUINO PIN D11
COLUMN 15 TO ARDUINO PIN D12
COLUMN 16TO ARDUINO PIN D13
Step 4: BASE FOR CUBE
make a cardboard base
Step 5: PROGRAMMING
HAPPY MAKING
THANKS
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    29 Discussions
    RAJESH-MrXSonnierJ96
    Reply 8 months ago
    voltage is not important hear.5v is suffiecnt to power
    FiaC
    1 year ago
    Link video program is failed
    Can you refresh new link
    MatejR4
    Question 11 months ago
    How did you solder coloums together I have problem with because my cathodes are not bend in exact same shape .So i have hard time to figure out how to get it together.
    1 answer
    huuduc52
    1 year ago
    It's very clear to do. Thank you very much. But may I have a question I don't have Arduino Nano, so can I use Arduino Uno?
    SudheeK
    1 year ago
    Good one..nice
