5 Minute Thumbsaver
7,762
59
13
As seen on Youtube, here's the Thumbsaver!
Only, a more modest version... Cheaper, too!
This is another no-brainer, that will save you a lot of grief, a nail setter, for nails, of course, and other fasteners.
It's just a question of finding some tube, and then in 4 or 5 Steps:
-File
-Plug
-Glue
-Bend
-And cut, (if needed)
Supplies:
Step 1: Materials and Tools
Simple, simple:
Materials:
A Tube,
A Magnet
A Glue tube, like UHU, or any other
Tools:
A Metal file,
A tube cutter, Or Hacksaw,
And a rod of some sort.
Step 2: Filing
The Metal file only has to file a V-shaped groove, like this:
Step 3: Place With Rod
Position the Magnet at the bottom of that V-Groove, with the help of a rod, plucked from the other side of the tube.
Step 4: Gluing
On the inside part of the tube, where the nails won't touch it, apply some glue.
Step 5: Bend
Then, bend it to your liking, I had this piece of tube already bent, by accident! :)
Step 6: Cut
If needed, cut the tube to size, and Voil√°!
Done.
Step 7: How It Works
The thingamajig works by setting the nails or other fasteners, into the V-Groove, pointing the nail, and have at it with the Hammer, without fear of nailing your thumb.
Easy!
For nails large and small, the smaller ones, remember to have the part that sticks back well positioned.
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    13 Discussions
    Nancydd
    3 years ago
    Awesome! Thank you, i will be using this from now on.
    EdgarNancydd
    Reply 3 years ago
    I'm glad you've liked it! :D
    AnubisAndIsis
    3 years ago
    Perfect . . until you need aluminum or other non-iron nails. For that, split a dowel with a notch in it, put a rubber band down close to the split to pinch it just enough. :-)
    twighahn
    3 years ago
    Rubber magnet, aluminum tube, file
    CraftAndu
    3 years ago
    Great idea! Though I Think I would not have enough patience for this.
    EdgarCraftAndu
    Reply 3 years ago
    Thank you!
    You know, it's just filing a V-slot onto a tube, plug a Magnet, and glue it. Hot-glue will make it last forever.
    EdgarCraftAndu
    Reply 3 years ago
    Ok. You'll probably only need it for those pesky little nails, smaller than your finger's thickness, or for nailing outside, with gloves.
