6 Person Ping Pong Table
634
Gather up all your friends so you can have a good game of Ping Pong. If you can have 2,4, or even 6 people play. Instead of waiting for a long time and being bored watching two people play, you can join the fun with all of your friends.
Step 1: Materials
  • 2 pieces of 3/4"x4'x8' Particle Board- Lowes
  • 2 pieces of 2"x4"x8' pressure treated wood- Lowes
  • 1 quart of Blue paint- Lowes
  • 1 sample pint of white paint- Lowes
  • 2 Rolls of 1" painters tape- Lowes
  • 4" paint roller- Lowes
  • 1" paintbrush- Lowes
  • 1 Paint tray- Lowes
  • 72" net- Amazon
  • 6 paddles and 3 ping pong balls- Amazon
  • 1 circular saw
  • 2 saw horses
  • 1 T-square
  • 2 clamps
  • 1 Tape measure
Step 2: Cutting
The size of the Particle Boards is still 4'x8' so they will have to be cut down to 4'x6'. After you will need to cut the Particle Board into half an octagonal shape.
Step 3: Painting
You need to use the 1 quart of blue paint with your paint tray and roller to apply the paint across the two pieces.
Step 4: Masking the Lines
After the blue paint dries, you will use the 1" tape to mask the outline for the 1/2" lines that will divide the playing field.
Step 5: White Lines
Paint the white lines in the parameter of the tape. Make sure that you only brush one way so you don't leave streaks.
Step 6: Remove Tape
After 1 hour you can remove the tape around the white lines that divide the playing area.
Step 7: TIGA Net
Last you need to install the uprights to the table and slide the net over the uprights. Make sure the net is centered between the edges of the table.
Step 8: Playball
Have fun with all your friends playing ping pong.
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
