6 Watt Amplifier Using TDA2614
2,224
23
7
A good quality of sound is provided by this amplifier.It is powered by a dual regulated power supply which makes the circuit easy for building it uses LM7812 and LM7912 and a transformer of 12-0-12 Volt 5 Amp
Supplies:
Step 1: Building on Breadboard
The TDA2614 Is a SIP9 Packaged IC Which is a breadboard friendly package it is easy to build circuits from this type of IC
Step 2: Power Supply
It uses dual regulated power supply circuit uses 7812 and 7912 ic.the power supply circuit can be builded from the datasheets of this voltage regulators it is powered from a 12 volt centre tapped transformer use of capacitors is important they work as filters use of regulator ic gives a good filtered power at the output which gives a noise free sound at output
Step 3: Input to Amplifier
Use a 20K Pot to control sound.i have used Nokia Bluetooth Headset to provide input to the amplifier use a 1uF capacitor before connecting the input to the amplifier ic using a 1uF Capacitor gives good output
Step 4: Output
here at the output i have used a 30 Watt Woofer and 40 Watt Speaker
Step 5: Components List
1 x TDA2614
1 x LM7812
1 x LM7912
2 x 1000uF Capacitors
2 x 220uF Capacitors
Screw Connectors (Optional)
2 x LED (Any Color)
2 x Resistors (1K)
Heatsinks
Breadboard
1 x 20K Pot
1 x 1uF Capacitor
Jumper Wires
Step 6: Circuit Diagram
Circuit Diagram
Use the circuit diagram as a refrence to build the Amplifier
For Any Queries And Suggestions Please Comment Or
Like My Facebook Page
CIRCUIT TODAY
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    7 Discussions
    PammiS3
    1 year ago
    Looks like the TDA2614 is obsolete now, do you have a device that can perform the same results?
    TrendZee
    4 years ago
    I made it
    it works good sound quality
    TrendZee
    4 years ago
    awesome!!
    CircuitToday
    4 years ago
    this is my first instructable please comment and help me to improve
    CircuitToday
    4 years ago
    The circuit diegram will posted soon
