8 Life Hacks With Steel Wool
136,152
322
95
About: A community of family fun, DIY, How-to videos, and Homemade creativity. We hope you can get inspired to make new projects, and possibly learn a little along the way.
8 Life Hacks with Steel Wool
[WATCH VIDEO]
Steel wool has been around for over 100 years and is commonly thought of as a polishing or sanding tool. But we have found several more uses for steel wool.
We have tested these ideas with success. I hope you can benefit from some of these awesome life hacks.
All of the following hacks are used with the Ultra Fine #0000 grade of steel wool.
Hacks Included:
1. Catch Animal Hair
2. Fix a Loose Screw
3. Wash your Windshield
4. Remove Black Heel Marks
5. Mice Barrier
6. Start a Fire
7. Clean old Tires
8. Clean Sneakers
If you would like the video version of this Instructable and the embedded video does not appear, here is an alternative link.
Find other awesome projects at www.specificlove.com
Lifehacks are great techniques, tricks, shortcuts, or novelty ways to reuse, repurpose, recycle, and upcycle certain products in uncommon ways to make life easier.
Use of content for personal projects is at your own risk. We are not responsible for any damages that could occur.
Supplies:
Step 1: Catch Animal Hair
Catch Animal Hair
If you have a dog or cat, there is a good chance a bunch of hair will go down the drain the next time you wash them.
This is an easy fix if you have some steel wool.
If you unroll a piece of wool and roll it back up long ways, you can now wrap it around your drain.
The fine mesh of fibers will allow the water to pass by, but it will catch the animal hair.
This will help to keep your drain free flowing.
When you are done, just gather the steel wool and hair and toss in the trash.
Step 2: Fix a Loose Screw
Fix a Loose Screw
If you have loose screw in a hole, there is an easy way to tighten the bond.
First remove the screw. Then take a thin layer of steel wool and wrap it around the screw.
Then reinstall the screw.
The screw should now have tighter tolerances and hold better.
Step 3: Wash Your Windshield
Do you have bunch of water marks and imbedded dirt on your windshield?
Have you ever tried steel wool?
Make sure you are using Ultra Fine #0000 grade for this hack.
If you wet your windshield and wet the steel wool, you can gently use the wool to clean your windshield.
I did this on my own car and it worked great.
Step 4: Remove Black Heel Marks
Have you ever walked across a nice floor only to realize that you left a black heel mark?
Here is a simple way to fix it.
Use a wet piece of steel wool and gently rub the flooring and the black heel mark should disappear.
Step 5: Mice Barrier
Mice Barrier
If you have pipes entering your house, then that is a great place for mice to get in.
To help prevent that from happening, just take some steel wool and place it in all of the gaps between the pipe and the wall.
Mice do not like the taste of it in their mouths.
Step 6: Start a Fire
Start a Fire
Have you ever needed to start a fire and did not have any dry matches?
Then it is a good to carry some #0000 steel wool and a 9-volt battery.
If you gently rub the connections of the battery on the steel, it will burn the wool.
This will even work if the wool is damp.
Then place some dry paper, dryer lint, dried leaves, etc on the sparks to create a fire.
Step 7: Clean Old Tires
Clean Old Tires
If you have some old tires that have lost their luster, you can use some steel wool and WD-40 to return that shine.
Just spray the WD-40 on to the steel wool and give the tire a good rub.
Then thoroughly wash the tire to remove any residue.
The original shine of the tire should be returning.
Step 8: Clean Sneakers
Clean Sneakers
Do you have a good pair of sneakers, but they are just too dirty to wear in public?
Here is a great way to clean them.
Using some steel wool and some plain (non-gel) toothpaste, gently rub the white bottoms of your sneakers.
The dirt and grime should come off relatively easy.
Make sure to wash all of the residue off before wearing.
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    95 Discussions
    GWSC
    1 year ago
    You left out the most useful application of all. Use steel wool and kerosene to remove surface rust from just about anything that has been plated. Bicycle rims and spokes, steel table legs, tyre rims, old bumper bars etc. Depending on the surface rust it can end up looking almost brand new.
    StretchD
    1 year ago
    Thank you for the instructable. While there may be (some) better ways to do some of the tasks as I have seen in other comments they are off topic. I feel that the topic is on uses and life hacks for steel wool. Yes Steel wool is quite versatile. Many of the comments do mention some valid points like rust marks and galvanic reaction.
    So use with caution.
    I have successfully used Stainless steel wool (course pot scourers) to block potential mouse holes. It also makes a versatile backfill when patching holes around pipes before using filler. -Watch out for rust marks if you are not using stainless steel.
    rclacovaraStretchD
    Reply 1 year ago
    Don't forget about brass wool. It is useful when steel wool might rust.
    novielo
    2 years ago
    i don't think it will work for mice...
    I had a tool chest in the shed with steel wool in it.
    One day i found a mice nest in the bottom part of the tool chest.
    The nest was made out of.... Steel wool they took from the other drawer :)
    Najn_artenovielo
    Reply 1 year ago
    LOL, mice eat anything. I've seen bags of laundry detergent that were ate through by mice.
    UncleEdnovielo
    Reply 2 years ago
    The steel wool has to be crammed into the crack or hole very tightly. I can see their stripping off pieces from a pad of steel wool--or even from the loose ends sticking out of the hole in the picture in the article. I wouldn't think steel wool would be comfortable to sleep on, but I'm not a mouse.
    Steel wool crammed in cracks and around pipes also stops small insects, according to our exterminator.
    Was1xUncleEd
    Reply 2 years ago
    You are right enough on this. Other sites and pest control suggest cramming steel wool in the cracks. If they do chew on it, it goes into their digestive trachs and the little buggers die later I am told. (I know, sounds cruel, but they ARE rodents.)
    SirCooksalotWas1x
    Reply 2 years ago
    Digestive tract. I'm the language police. Woot-woot-woot. Pull ovah.
    Drake88UncleEd
    Reply 1 year ago
    Steel wool fragments easily, and when eaten/chewed by mice(or rats) cause sores in the mouth, throat, stomach, and digestive tract. Most mice and rat poison uses a chemical used in human medicine - warfarin. It is a long known blood thinner and in high does can cause ulcers and sores in the digestive tract. Combined with the blood thinning action, the pests hemorrhage and die due to internal bleeding. Not pretty, but they ARE a major pest in human habitation around the world.
    novieloUncleEd
    Reply 2 years ago
    it sure was comfortable enough to raise a new family of 5 new mini mice :)
    Funky Divernovielo
    Reply 2 years ago
    Who also didn't have to worry about clogging their drains after bathing :D
    tbt10fUncleEd
    Reply 2 years ago
    Metal pot-scrubbers work better for this application, as it is much harder to pull pieces of it off.
    GrumpyOldGoatnovielo
    Reply 2 years ago
    I had a camp trailer with a mouse problem.
    After smoking them out with cedar smouldering at one end and a computer case fan pushing out the other end, I stuffed steel wool into some spray foam then sealed it with more spray foam.
    No more mice, but plenty of chew marks until I put a small piece of galvanized duct over it.
    Najn_arte
    1 year ago
    Steel wool gets rusty real quick. I wouldn't put it anywhere in the bathtub. Anyways, good ideas. I may try to make a fire with the steel wool.
    browneaction
    2 years ago
    I ruined the glass of a fish aquarium before by cleaning the algae with steel wool. It seemed like a good idea at the time but it creates fine scratches in the glass; which in turn attracts alga and becomes harder and harder to clean. The scratches the steel wool makes become quite noticeable over time
    rocketridebrowneaction
    Reply 1 year ago
    Glass varies greatly in its hardness and abrasion resistance. Another major issue with surface abrasions on glass it that even un-tempered glass has much of its strength in its surface layer. Break the surface layer and the glass is substantially weakened.
