90V 60W Solar Panel
1,011
14
4
About: We design and create batteries, electric vehicles and DIY electronics. We research, develop and document our creations to inspire others. Our mission is to bring resources to people all over the world and ...
In this video we show how we built the high voltage solar panel we custom made to charge the 72V 2kWh li-ion battery installed in the Nobuo-01 electric Kart.We used 14 protected 6Vmp cells connected in series. For bigger installations in series you need to add bypass diodes in each cell (or panel in series) in order to avoid a shaded cell become a resistor.In our case we used a PWM solar controller but if the voltage of the finished panel is appreciably greater or lower than you battery voltage you need to use a MPPT controller*info: https://www.facebook.com/evmadrid1
Step 1:
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    4 Discussions
    tytower
    2 years ago
    But if you have a high voltage panel at say 90 volts what controller can you buy to handle that? Most are only built for 20 to 40 volts max?
    EVMadridtytower
    Reply 2 years ago
    There are configurable solar controllers for a more broad voltages, prepared for 60V, 72V and higher voltage batteries. Look for them with nominal voltages as 60V, 72V, 84V solar controllers
    tytowerEVMadrid
    Reply 2 years ago
    Been looking for two years without sucess . Thats why I asked. Can't point me at any can you?
    EVMadridtytower
    Reply 2 years ago
    this unit is a very simple PWM Solar charge controller, but high quality made, it admits up to 78V maximum charging voltage and it is completely configurable for different chemistries (you can adjust LVC, HVC, etc) and admit timmer for auto-off and temperature compensation and flood charging for SLA batteries also.
    http://www.ebay.es/itm/SL03-10A-36V-48V-60V-LCD-Screen-PWM-Solar-Charge-Controller-Battery-Regulator-/131557904775?hash=item1ea1765187:g:Nd8AAOSw3ydVph6o
