A 3D Printed Front End Loader
6,465
71
18
About: High quality 3D printable designs to whet your appetite. Enjoy the greatest joy of #3DPrinting!
My new heavy machinery vehicle, similar structure to to the Excavator I've uploaded since July:
And this time I've simplified some structure of the arms. Reduce some freestanding bolt as possible. But both retained playability.
Step 1: My Loader Mainly Assembled With Three Colors
My black filament ran out while printing the blade, so I used a green instead.
Here is a graphic of color classify: You can place the same color sets together in one plate.
Step 2: Exploded Directions:
Step 3: Top & Side Grilles & Smoke Pipes
Step 4: Cabin
Assemble the two retroreflectors on the cabin.
Set the seat.
And steering wheel as well.
Step 5: Terraces and Ladders
Connect the two side terraces with ladders, cylinders. (The terraces should be yellow)
Insert into the side bulges on the body.
Step 6: Beam
Assemble rear lamps and number plate on the beam. Add it to the tail.
Then cover the cap.
Step 7: The Pressure
Bolt-on the pressure.
Insert the pressure stick and connect it to the fore boom. (All the size of the nails/nuts are same)
Connect the blade next.
Step 8: Main Body Assemble
Directly insert the main body into the front body. (Then cap the body nut)
Step 9: Wheels
Put Axles into the hubs.
Insert inner axle at the other side.
Then assembled wheels.
Step 10: Finish
Quick assembled bulldozer, if you think it not chanllenging enough here are some packages more complicated:
http://www.shapetizer.com/design/23506110061005920... http://www.shapetizer.com/design/9960507031095332...
If you like it, follow us on twitter or facebook to find more funny 3D printed stuffs:
https://twitter.com/Shapetizer
https://www.facebook.com/Shapetizer-44161327934874...
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    18 Discussions
    ShapetizerBikeHacker
    Reply 3 years ago
    Definitely, took a reference to the real loader and learned the structure.
    ShapetizerLay3rD
    Reply 3 years ago
    There are no .STL files, but you can only get it printed on https://www.shapetizer.com/design/655110504403046753.html.
    bill_brown
    3 years ago
    I do not mean to be nit picky. But bulldozers use tracks not tires. What you printed is a front end loader.
    Shapetizerbill_brown
    Reply 3 years ago
    Oh, really? I didn't make a distinction, thanks for your advise, I'll change the name.
    RoboStack
    3 years ago
    Very nice work! I will say that this vehicle is actually called a wheel loader and not a bulldozer. ?
    ShapetizerVerticees
    Reply 3 years ago
    Thank you, Verticees, all owe to a good printer.
    This is great. My son would love it if I could just print out new construction toys for him. Thanks for the idea.
