A 3D Printed Quadruped Robot
43,612
569
44
About: Hello, my name is Toglefritz. That’s obviously not my real name; my real name is Scott, but on the Internet I use the nom de plume, Toglefritz. I like to make things and I like to share my work with others. ...
This Instructable will show you how to build a quadruped robot from scratch using 3D printed parts and off-the-shelf electronic components.
Robot Design
A quadruped robot is a robot with four legs. There are any number of ways a four-legged robot can be designed. The robot we will be building in this Instructable has four legs arranged symmetrically around the body.
Each leg is actuated by three servos: one for forward/backward movement, one for up/down movement, and one to bend the leg in the middle. This gives the robot three degrees of freedom, allowing it to move in any direction.
The robot is also equipped with a NeoPixel LED ring that functions as the robot's eye. This part is used mostly for aesthetics, however it is also useful for making it easier to identify the front side of the robot since it is symmetrical. Giving the robot a kind of "face" also gives it some anthropomorphism.
All of the design work for the quadruped was done in Autodesk Fusion 360.
Motion
Since the quadruped can articulate each of its four legs with three degrees of freedom, it has a highly flexible range of motion.
Robot Construction
The quadruped is constructed mostly from 3D printed frame parts and readily available hardware. The electronics used to power and control the robot are normal (albeit high quality) hobby servos and Arduino-compatible microcontrollers.
Robot Control
The robot is controlled with a wireless third-party Playstation 2 controller.
Step 1: Gather Your Parts
We will need the parts below to complete the build, along with some general-purpose materials like solder and hot glue.
Electronics Parts
Lynxmotion Botboarduino
Quantity: 1
SSC-32 Servo Controller
Quantity: 1
Hitec HS-645MG Servo
Quantity: 12
Wireless PS2 Controller
Quantity: 1
16 LED NeoPixel Ring
Quantity: 1
5V 10A Power Supply
Quantity: 1
Barrel Jack Adapter
Quantity: 1
AA Batteries
Quantity: 2
F/F Jumper Wires
Quantity: 20 (1 pack)
Mechanical Parts
M3 Heat-Set Inserts
Quantity: 36
M4 Heat-Set Inserts
Quantity: 12
M3 Self-Tapping Screws
Quantity: 96
M3 x 10mm Screw
Quantity: 32
M2 x 8mm Screw
Quantity: 24
M4 x 12mm Screw
Quantity: 8
M3 x 50mm Screw
Quantity: 4
6 x 13mm Ball Bearing
Quantity: 4
M2 Nut
Quantity: 8
Step 2: 3D Print the Frame
The frame for the quadruped robot uses a total of 38 3D printed parts. All of the files for printing these parts can be found in the GitHub repository I created for this project.
PartQuantityImage
Chassis Top1
Chassis Bottom1
Coxa Top4
Coxa Bottom4
Femur Frontplate4
Femur Backplate4
Tibia4
Coxa Cover8
Femur Cover Left4
Femur Cover Right4
Some of the 3D printed parts for this build are quite challenging to print, and some of the parts are very large; you will therefore need a fairly high-end 3D printer to make all the parts. My 3D printer did not have a large enough build platform, so I used 3D Hubs to get my parts made and I had a great experience with the service.
Why a 3D printed frame?
One of the reasons for using 3D printed parts for this quadruped build is that the 3D printed frame is extremely light weight. Keeping the robot's weight low is extremely important. In order to avoid spending a fortune on servos for this project, the TowerPro MG996R servos we will be using
Parts of a Arthropod Robot Leg
Throughout this Instructable, I will be referring to the leg parts and servos according to their position and function on the legs. The quadruped robot uses an arthropod leg design with the parts of the leg named after the leg bones on an animal. Likewise, the servos are named according to the leg segment they actuate.
[leg part label]
Step 3: Install Heat-Set Inserts Into Covers
In order to partially conceal the quadruped's leg mechanisms and improve the aesthetics of the robot, the femurs and coxas have decorative covers. The covers are simple 3D printed plates that mount onto the leg sections. The covers will mount to the corresponding leg assemblies using M3 machine screws. Rather than trying to force the screws to thread into the 3D printed covers, or try to design the covers with a captive nut, we will create metal threads for the covers using heat-set inserts.
Heat-set inserts are simple parts, but they will allow the cover pieces to be attached and detached with ease. To install the heat-set inserts, we will need a soldering iron, a pair of hemostats, and a way to hold the 3D printed covers steady. For this last piece of equipment, I am using a great helping hands tool from QuadHands.
To install the heat set inserts, warm your soldering iron to 230o C. Then, with the 3D printed part clamped in place, hold the heat-set insert with the hemostats just over the hole. Press the heat-set insert into the plastic part with the soldering iron. The heat from the soldering iron should melt the plastic, allowing the heat-set insert to set into the part. Try to work quickly to avoid applying too much heat and deforming the plastic surrounding the holes.
Install heat set inserts into both hols on each of the 16 cover pieces.
Step 4: Install Heat-Set Inserts Into Chassis Top
Next we will install heat-set inserts into the top chasis part the same way we installed the inserts into the cover parts in the previous step. Four M3 heat-set inserts will be used to mount the robot control board to the chassis later on, and four M4 heat-set inserts will be used to connect the top and bottom chassis parts.
Install the heat-set inserts into the top chassis part using the same technique as we used in the previous step. You should be getting fairly good at installing the inserts at this point, having just installed 32 inserts into the cover parts.
Step 5: Install Heat-Set Inserts Into Femur Backplates
By this point you are probably an expert at installing heat-set inserts. Later on, we will be using an M4 machine screw to form the hinges for the femur-tibia joints and the coxa-femur joints. We will install M4 heat-set inserts into the Femur Backplate parts so we can install the machine screws later on. Using the same technique we employed for the cover pieces and the top chassis piece, install the heat-set inserts into the protruding bosses on the Femur Backplates.
Step 6: Remove Horns From Servos
Before continuing the build, we need to take the preparatory step of removing the horns from all the servos. We need to do this for two reasons. First, the servo horns will connect to various other parts using M2 screws. However, the holes in the horns are actually smaller than 2mm. We will therefore need to drill the holes to a slightly larger size.
The second reason we need to remove the servo horns is because they will be installed onto the tibia parts and the coxa parts first, and reconnected to the servos second.
Step 7: Mount Servos to Femur Frontplates
The next step in assembling the quadruped robot is to mount the servos onto the 3D printed Femur Frontplate parts as shown in the animation below. The shafts for the servos (note that the horns are removed at this point) should be closest to the ends of the Femur Frontplate parts.
We will attach the servos to the Femur Frontplate parts using M3 self-tapping screws made specifically for plastics. These screws have especially sharp threads and the threads are very corse. This design means the screws will be able to easily cut threads into the plastic and the screws require very little force to drive in, which means there is little risk of breaking the 3D printed parts by attaching other components using these screws.
Step 8: Attach Backplate to Femur Frontplates
With the servos attached to the Femur Frontplate, we will complete the femur assembly by attaching the Femur Backplate part. The Femur Backplate connects to the Femur Frontplate with eight M3 self-tapping screws. The two holes in the center of the Femur Backplate parts will be left open for connecting the cover pieces later on.
Step 9: Drill Out Servo Horn Holes
In the next few steps we will be mounting the servo horns onto the tibia and coxa parts. We will fasten the servo horns onto the 3D printed parts with M2 screws. However, the holes in the servo horns are actually smaller than 2mm. Therefore, we will drill out the holes to expand them to 2mm so the screws will fit.
Using a 2mm drill bit, carefully drill out two diametrically opposed holes on each of the 12 servo horns.
Step 10: Center the Servos
The only feedback mechanism available for the quadruped robot to figure out its posture is the positional feedback of the servos. In other words, the robot's controller only knows the angle of each servo. From this information alone, the firmware must be able to determine the position of each leg. It is extremely important that, when the servos are at their center position, the coxa and femur are co-linear, and that the tibia and femur are perpendicular, as shown in the rendering below.
We will go into more detail about building the quadruped's legs later in this Instructable. For now, we just need to make sure each servo is at its midpoint before assembling the robot.
To center the servos, you will need an Arduino, a breadboard, and a power supply. Because it is convenient and easy, I used a breadboard power supply from SparkFun to power the circuit. The trick to centering the servos is that, because the servos we are using for this build are quite powerful, the Arduino cannot drive them directly. Instead, the servos will be powered from the power supply. There is one critically important part of wiring the servo to the Arduino. The servo ground, power supply ground, and Arduino ground MUST all be connected together. The Arduino itself can be powered via its USB port.
The Arduino sketch to center the servo is extremely simple:
#include <Servo.h>
Servo servo1;
void setup() {
servo1.attach(9); // Connect the yellow servo wire to the D9 pin.
servo1.write(90); // Set the servo to mid-point.
void loop() {
servo1.write(90);
delay(100);
Step 11: Mount Tibias
Next we will mount the tibias to the femurs. This is done in two parts. First, we need to attach the servo horns to the tibias. Second we will attach the femur assembly to the tibia.
The servo horns will attach to the left side of the tibia using M2 screws. Insert the horns so that the shaft goes through the large hole in the tibia.
Once the servo horns are all attached, insert the femur assembly into the space between the mounting arms on the tibia. Press the servo shaft into the servo horn and secure it in place with a screw. On the opposite side, screw an M4 x 12mm screw into the heat-set insert on the back side of the femur assembly. The head of the screw acts as a bearing for the femur-tibia joint.
Step 12: Attach Coxa Covers
Now we will begin assembling the coxa, which we will do in the opposite order we are using for the femur. The first step is to attach the cover pieces to the coxa. Simply place one of the cover pieces on each side of the part, and attach it in place using two M3 x 10mm screws inserted from the inside of the coxa.
Step 13: Mount Servos to Coxa Tops
With the covers in place, the next step in assembling the coxa is mounting the servo. The servo mounts to the coxa the same way the servos mounted to the femur. Place the servo into the coxa top piece with the wire going through the gap in the front two standoffs. Fasten the servo in place with four M3 self-tapping screws.
Step 14: Mount Coxa Bottoms
To complete the coxa assembly, we will mount the bottom cover onto the coxa top. Simply attach the part with four M3 self-tapping screws. Be careful not to tighten the screws too much because you can crack the 3D printed parts rather easily.
Step 15: Attach Coxas to Femurs
Now to join the coxa and the femur/tibia. The process of connecting the coxa to the femur is basically the same as the process we used to connect the tibia to the femur. First we will connect the servo horns to the coxa mounting legs, and second we will connect the coxa itself to the femur.
With the servo horn mounted, connect the femur/tibia assembly by securing the servo to the horn with a screw, and then insert an M4 x 12mm screw on the back side to form the hinge.
Step 16: Connect Femur Covers
At this point, the quadruped's legs are almost complete. The only parts remaining are the left and right femur covers. The femur covers look very similar to the coxa covers we installed earlier, but they are larger. When viewed from the top of the leg, the covers with the slightly taller standoffs go on the left side. The covers attach to the femurs using M3 x 10mm screws.
Step 17: Mount Bearings Into Chassis Bottom
The coxas will be mounted to the chassis on ball bearings to provide low-friction movement since each leg has only a single servo to move the coxa joint. Insert a ball bearing into the bosses on each corner of the Chassis Bottom piece. The bearings fit snugly; you will need to apply pressure to the bearings until they fit into place. Depending upon the dimensional tolerances of your 3D printer, if the bosses are too tight for the bearings, it can be helpful to heat the plastic using a heat gun prior to pressing the bearings into place.
Step 18: Attach Servo Horns to Chassis Top
The servo horns that connect the coxa servos on the legs to the Chassis Top piece connect to the bottom of the part on each corner. On the top of the Chassis Top piece, you will notice that the two smaller holes are countersunk. Insert an M2 x 8mm screw into each of these holes. The heads of the screws should be flush with the 3D printed part. Then, place a servo horn onto each corner and fasten it in place with an M2 nut on the end of each screw.
Step 19: Program the Botboarduino
Of course, in order for all of the servos, 3D printed parts, screws, heat-set inserts, and the assemblies we've created with them to function as a robot, the microcontroller must be programmed. Controlling the robot is certainly not a trivial task, either conceptually or in terms of the computational requirements for the microcontroller. However, it is not too difficult to roughly understand the process the microcontroller goes through to translate commands issued by the user, to a series of servo angles necessary to execute those commands.
The entire process of controlling the robot is just a whole bunch of trigonometric calculations. I have written a couple of articles about the types of calculations used to control legged robots, and if you want to understand exactly how the robot works, you can give them a read. Otherwise, you can simply follow the instructions in the rest of this step to upload the quadruped control code to the Botboarduino.
Programming the Botboarduino
The Botboarduino is derived from the Arduino Duemilanove, so we will use the Arduino IDE to upload the quadruped control code sketch just like you would with any other Arduino board. Head over to the Arduino website and download the IDE if you don't already have it.
Next you'll need the code for the quadruped robot. I store the most up-to-date version of the code in a GitHub repository. Simply download the .zip file from GitHub and extract it to a working directory on your computer.
Before opening the quadruped code in the Arduino IDE, copy the contents of the libraries folder into your Arduino libraries directory. With the libraries installed, open the quadruped in the Arduino IDE.
Before connecting the Botboarduino to the computer, there is a bit of adjustment needed for the board to work that is specific to the Botboarduino. On the Botboarduino, near the power input screw terminals, there is a pin jumper used to select between USB power and external power. In order to program the board, the jumper must be set to the USB power option. Note that after programming the board, we will need to set the jumper for external power instead.
Finally, connect the Botboarduino to your computer. In the Arduino IDE, select Arduino Duemilanove as the board type and make sure the correct COM port is selected. Then, click the upload button.
Step 20: Mount Botboarduino Onto Chassis Top
Now that the quadruped code has been uploaded to the Botboarduino, we can get back to assembling the robot. The Botboarduino mounts into the quadruped Chassis Top with the M3 heat-set inserts we installed earlier. Ultimately we will be building a kind of stack of electronics inside the quadruped Chassis with the Botboarduino on the bottom, the controller receiver in the middle, and the SSC-32 servo controller on the top.
To mount the Botboarduino, first, place a 6mm nylon standoff into each of the threaded inserts to make a bit of space for the Boatboarduino. Then, place the Botborduino on top with the USB port and power input screw terminals facing the back of the robot (the side opposite the small fin which will be used for the eye). Fasten the controller in place with four 10mm nylon standoffs.
Step 21: Solder Wires to NeoPixel Ring
The NeoPixel ring does not come with any wires or connectors, so we will need to add a way to connect the NeoPixel ring to the Botboarduino. We will solder three wires onto the NeoPixel ring: one for power, one for ground, and one for the signal input. There are a total of four solder pads on the NeoPixel ring though; the Data Out pin will be left unconnected.
So, solder a black wire to the Ground pad on the NeoPixel ring, a red wire onto the Power pad, and a yellow wire onto the Data Input pad.
Step 22: Mount and Connect NeoPixel Ring
With wires attached to the NeoPixel ring, it is time to mount the ring onto the quadruped Chassis Top piece. On the front of the piece, there is a circular fin. Using hot glue, attach the NeoPixel ring to the front side of this fin. The orientation of the NeoPixel ring is not particularly important.
To connect the NeoPixel ring to the Botboarduino, first connect the black wire to ground and the red wire to 5V. I like to pass the wires underneath the Botboarduino and then back up to connect to the pins for cable management. Then the yellow signal wires connects to GPIO pin 3.
Step 23: Connect Wires for SSC-32 Connection
Because we will be placing all of the electronics into a kind of stack inside the robot, there are some wires we need to add now that will connect to other components later on; this will prevent the pins we need to connect from being obstructed by other parts. The first set of wires will eventually connect the Botboarduino to the SSC-32.
The Botboarduino communicates with the SSC-32 over a serial connection; so there are two wires that form the serial connection, plus a ground connection. Place a wire on the ground pin closest to the standoff closest to the set of four jumpers. Then, for the actual serial communication, place a yellow wire on GPIO pin 13 and a red wire on GPIO pin 12.
Step 24: Mount and Connect PS2 Controller Receiver
The robot is controlled by a third-party Playstation 2 wireless controller from Lynxmotion. The receiver for the controller will be mounted above the Botboarduino on one of the nylon standoffs already in place. Before attaching the controller receiver to the bundle of electronics inside the robot, we need to connect the controller to the Botboarduino.
There are a total of six pins on the controller receiver.
PS2 Controller PinBotboarduino Pin
DATconnects toGPIO 6
CMDconnects toGPIO 7
ATTconnects to8
CLKconnects to9
GNDconnects toGND
5Vconnects to5V
Step 25: Add Power Wires
A single power supply delivers energy to both the Botboarduino and the SSC-32 servo controller. The power supply connects directly to the SSC-32, a setup we will wire in the next step, and then the SSC-32 and Botboarduino power systems are tied together. In this step, we will add a pair of wires to the Botboarduino that will later connect to the SSC-32.
On the Botboarduino, there are two power input screw terminals: one labeled VS and one labeled VL. Connect a black wire to the VL negative screw terminal and a red wire to the VL positive screw terminal. For now the wires will just be left dangling.
Step 26: Connect Power to SSC-32
Now there is a wire attached to the Botboarduino waiting to deliver power to that board from the SSC-32. The SSC-32 will have two power wires connected to it. First, connect a black wire to the negative terminal of the barrel jack adapter and a red wire to the positive terminal.
On the SSC-32, there are three power input screw terminals: VS1, VL, and VS2. There are also three pin jumpers, two on the VS2 side and one on the VS1 side. It should be set up this way out of the box, but make sure all three pin jumpers are connected. This setup basically ties the servo power system and the logic power system together so that both systems can be powered by a single power supply.
Connect the wires from the barrel jack adapter to the VS1 screw terminal using the same polarity as we did on the adapter.
Now connect the wires from the Botboarduino in the previous step to the VS2 screw terminal, matching the polarity. Now the power system goes like this: the power supply delivers power to the left side of the servo power system on the SSC-32, one of the jumpers links the left and right sides of the SSC-32 so both receive power, the second jumper delivers power to the logic circuits on the SSC-32, and finally, the right side of the servo power system on the SSC-32 passes power to the Botboarduino.
Step 27: Mount SSC-32 Servo Controller
Next, we will mount the SSC-32 to the rest of the electronics stack inside on the Chassis Top piece. You should already have a set of female headers on top of the Botboarduino and PS2 controller. Place the SSC-32 on top of these headers with the screw terminals over the screw terminals on the Botboarduino. Fasten the SSC-32 in place using four M3 nylon screws.
Step 28: Connect Leg Sub-assemblies to Chassis Top
This is the part of the build where I start to get excited because the finished shape of the quadruped robot is finally emerging from the pile of parts with which we began this Instructable. The quadruped's legs are complete at this point and so is the Chassis Top and the electronics parts connected to it. In this step, we will connect the legs to the Chassis Top part.
For each leg, use medium pressure to press the coxa servo shaft into the servo horn. It is very important that the leg be placed at a 45o angle to the edges of the Chassis Top. In other words, it should extend straight out the corner of the Chassis Top. Secure the legs in place with the servo screws.
Before the Chassis Bottom is connected in the next step, the relativly large and heavy legs are only supported by the servo horn. Therefore, care must be taken when working with the robot to avoid breaking the servo horn.
Step 29: Connect Servos and Botboarduino to SSC-32
With the legs connected to the body, the servos need to be wired to the SSC-32 servo controller. The SSC-32 can control up to, as the name implies, 32 servos. On the SSC-32 board, the servo connections are arranged in sets of four along the edges of the board. Each row of three servo connection pins is identified with a number. The servos connect to the SSC-32 according to the table and image below:
Servo PositionSSC-32 Pin
Rear Right Coxa (Horizontal)0
Rear Right Femur (Vertical)1
Rear Right Tibia (Knee)2
Front Right Coxa (Horizontal)8
Front Right Femur (Vertical)9
Front Right Tibia (Knee)10
Rear Left Coxa (Horizontal)16
Rear Left Femur (Vertical)17
Rear Left Tibia (Knee)18
Front Left Coxa (Horizontal)24
Front Left Femur (Vertical)25
Front Left Tibia (Knee)26
Step 30: Attach Chassis Bottom
Finally there is but one more part to attach to the robot and then it will be complete! The Chassis Bottom part has a slightly flatter shape on one side. This side is the front. Place the Chassis Bottom piece onto the legs so that the pegs on the bottom of the coxas slip into the ball bearings on each corner of the Chassis Bottom. To fix the Chassis Bottom in place, use the M4 x 50mm screws inserted through the Chassis Bottom and threaded into the M4 heat-set inserts we installed in the Chassis Top earlier.
Step 31: Control Your Quadruped
Congratulations! Your 3D printed quadruped robot is now complete. The only thing left to do is turn it on and take it for a walk.
To turn on the robot, simply plug it in to the power supply. Be a bit careful when you do this because it is likely the legs will jerk suddenly as they are first delivered power and the Botboarduino initializes.
The Botboarduino can be armed or disarmed for motion using the PS2 controller. To arm the robot and enable it to accept your commends, press the start button on the PS2 controller. The Botboarduino will confirm it is armed with a single beep.
After that, review the diagram below for the quadruped's control setup.
Have fun with your new robot! Your new quadruped can even thank you with a bow.
Credits
Epilog Contest 8
First Prize in the
Epilog Contest 8
Design Now: 3D Design Contest 2016
Second Prize in the
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
44 Discussions
themakerrob
10 days ago
Fantastic design! As neat as the aesthetic is, it seems the design would suffer from inherent inefficiencies, since the body weight is suspended (and must be maintained), and it would be impossible to maintain any sort of locomotive momentum. Unfortunately, there is nothing that can be done about those things and maintain this spider like aesthetic. To solve those problems the weight would have to be re-positioned 'over' the legs, so that the structure was carrying the load, instead of the servos.
However, it seems there may be a way to hedge your bets none the less! If instead of driving the legs directly, if you used a cable/pulley design, you could amplify the torque of the motors and reduce load. Even better, is you could use springs to preload the pulley system, so that the robot had more of a natural 'buoyancy'. Basically the springs would eat up most of the energy to actually lift the robot, and the servos would only have to provide a little power in order to either raise or lower the robot. Of course, the problem with this, is that spring force would have to be cover come in scenarios where the robot weight was not in effect. Such as lifting a single leg off the ground. The hope would be that the net amount of time under those conditions would be much less than just the standing time. I don't think this would be as efficient as having the weight over the legs, but I think you'd probably see a pretty sizable improvement in efficiency, and by extension make the idea of battery operation more feasible.
Great work though. Really enjoyed seeing it.
Nics3451
Question 21 days ago
First off, this robot is amazing. If I need my robot to be able to stand upon its hind two legs (doesn't need to be able to walk - just stand) do you think I could manipulate this design to do that or do you think I need a completely different approach? Grateful for any advice. Thank you.
docman100
Question 4 months ago
What’s the minimum size to print the parts?
1 answer
JohnT4docman100
Answer 3 months ago
Since the 3D printed parts are sized to accomodate components like servos, and boards.. print them at a 1:1 scale or else it won't fit those components.
RicS90
1 year ago
Hi, can you tell me which cheaper servos can we use successfully in this project?
Toglefritz
2 years ago
Hi Aidan17m,
There are several challenges for powering the robot with a battery. Weight is one issue. Another challenge is selecting a battery that is capable of delivering the large current needed by the servos. Each of the HS-645 servos can use up to 350mA under load. This means that the robot can, in theory, use up to 4.2A of power. Batteries like those found in Xbox controllers or ordinary alcaline batteries are designed to power very low current devices. To keep up with the robot's power requirements, you need a more specialized battery.
That said, some quadcopters, which are very high current machines, do use removable cartridge-style batteries that could be easily changed or charged on a stand. It may be possible to use LiPo batteries like those used for quadcopters to power the quadruped robot.
PetjaToglefritz
Reply 1 year ago
Hi Scott! Can I replace Botboarduino by Arduino Uno and SSC-32U USB Servo Controller by this controller:
https://www.aliexpress.com/item/New-Version-32-Channel-Robot-Servo-Control-Board-Servo-Motor-Controller-PS2-Wireless-Control-USB-UART/32272674301.html?spm=2114.search0104.3.2.zSsNWS&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10068_10209_10084_10083_10119_10080_10082_10081_10301_10110_10136_10137_10111_10060_10112_5360018_10113_10155_10114_10154_10056_10055_10054_10182_10059_100031_10099_10078_10079_10210_10103_10073_10102_10169_10120_10189_10052_10053_10142_10107_10050_10051-10120,searchweb201603_5,ppcSwitch_5&btsid=6496779e-2223-48a7-a860-592fbb807ab3&algo_expid=71139dee-3dfa-4b94-8044-4f21b7d2b2b9-0&algo_pvid=71139dee-3dfa-4b94-8044-4f21b7d2b2b9
AlessandroG2
1 year ago
hi Toglefritz, can i use TowerPro MG996R instead of Hitech like in your pictures above?
HenrikF8AlessandroG2
Reply 1 year ago
Yes you can, I used these Servos successfully. The horns supplied with these servos are not optimal though.
LeOgre
1 year ago
This design is really awesome! I just finished building mine and am now in the middle of putting it into operation.
I think HenrikF8 is right about the Serial Connection. The code gives RX and TX as Pins 10 and 11 on the BotBoard. Using these pins, the BotBoard and the SSC32U are talking to each other.
However, on startup, and pressing start on the PS2 controller, the legs cramp into strange positions and when trying to move forward, the legs do strange movements as well. I set the servos to neutral as instructed and connected everything accordingly.
Has anyone successfully build this robot and could tell me what the robot is supposed to do with the legs at powering it up and then when pressing start on the PS2 controller?
Thank you!
Olaf
HenrikF8LeOgre
Reply 1 year ago
I used this config in Jeb_Code.h to get it to move as intended:
// Servo inverse direction
//xan: Make this dynamic in the config file
const bool cCoxaInv[] = {1,1,0,0};
//cRRCoxaInv, cRFCoxaInv, cLRCoxaInv, cLFCoxaInv};
bool cFemurInv[] = {1,1,1,1};
//cRightRearFemurInv, cRightFrontFemurInv(1), cLRFemurInv(1), cLFFemurInv};
const bool cTibiaInv[] = {0,0,0,0};
//cRRTibiaInv, cRFTibiaInv(1), cLRTibiaInv(1), cLFTibiaInv};
HenrikF8
2 years ago
Hi and thanks for this fantastic instructable. I have one question though, You state that the Serial connection between Botboard - > SSC32U should be connected to Pin 12-13 Whilst the code(Quad_Cfg.h) States that it should be connected to 10/11(// Connections to SSC-32 servo controller
#define cSSC_OUT 10 // Output pin for (SSC32 RX) on BotBoard (Yellow)
#define cSSC_IN 11 // Input pin for (SSC32 TX) on BotBoard (Blue)).
Am I missing something here? Adn also, Might be good to include that the Baud needs to be set @ 38400 for the SSC32U, Default seems to be 9600.
ZoeD17
2 years ago
does any body know how much the over all cost for this is?
HenrikF8ZoeD17
Reply 2 years ago
All-in-all I paid(roughly) $100 for Arduino + Servo-controller, $200 for servos, $30 for PLA-filament, ~$70-100 misc, And I'd surely forgotten something so.. Say between $400-500?
jgarciaforteza
2 years ago
Wow, great project documentation! The level of detail and quality are impressive. The design looks pretty robust as well as aesthetically pleasing (darn cool!). The only thing is the battery, and unfortunately walkers with servos tend to be power-hungry. Anyway, good job and thanks for sharing!
Drake2312
2 years ago
so i was wondering is this robot capable of climbing say some stairs and if it is not would it be possible to modify the frame and coding to change it from a quadruped to a hexapod so that i can alter the tilt of the robot to lift the front legs up to walk up stairs or independently move the legs such as lifting the front two legs up onto the step then the second pair then the front onto the next step followed by the final pair and so on
Aidan17m
2 years ago
hey toglefritz, i downloaded autodesk fusion 360 but i cant seem to download and access any of your github files
Paperclip72
2 years ago
Woah, this looks awesome! Could you add a video of it moving, and how big is it?
Exotechmaster55
2 years ago
do you think it would be possible to add a camera to where the led ring is so if i were to modify it to run off of a battery i could see where it was going without following it?
ToglefritzExotechmaster55
Reply 2 years ago
Hey Exotechmaster55,
I think putting a camera on the robot would be a great idea. I was actually considering equipping the robot with an FPV system like those used for flying quadcopters. It is possible to get such a system quite inexpensively: https://hobbyking.com/en_us/quanum-complete-fpv-bundle-set-w-goggles-5-8ghz-32ch-video-tx-rx-cp-antennas-and-camera-pnf.html.
Since these FPV systems are designed for use on RC aircraft, they are designed to run off battery. I am sure it would be relatively straightforward to run the camera system off the robot's battery.
