A Clock From Pallet Wood Blocks
1,842
43
5
This time I’ll show you how to make A Clock from Pallet Wood Blocks
How I did it - you can check by looking DIY video or you can follow up instructions bellow.
For this project you will need:
Materials:
Old clock or clock movement mechanism;
Pallet wood blocks;
Wood glue;
Wood screws;
Wood finish;
Tools:
Circular saw;
Clamps;
Drill and bits
Jig saw
Step 1: Old Clock
I had, this old ugly looking, scratched all around wall clock. It's functioning fine, but how it's looking - isn't acceptable for me any more. So I decided to take out movement mechanism and make my own design wall clock, by using some pallet wood blocks.
Step 2: Preparing Wood Blocks
Measured and cut pallet wood blocks in half, to get proper block height for my clock.
Step 3: Working With Wood
Measured movement mechanism shaft length and cut same thickness peace of block from clock centre. Next, marked and cut out a hole, where movement mechanism will be hidden.
Step 4: Movement Mechanism
Found a center point, and made a hole for clock shaft.
Mixed some epoxy to glue movement mechanism in place. When epoxy was dry enough - glued cover back with wood glue.
Step 5: Wood Blocks in Progress
Center peace is done, now is time to prepare other blocks for final assemble. For that, it's need to remove part of wood from back side of each block. In this way I’ll get some space to attach fixing board. To make it safe and easy - I made a simple jig. Corner blocks was cut in 45 degrees angle. Side pieces - cut at one block side. Used chisel to remove cut wood.
Step 6: Final Assemble
From 12mm plywood prepared back board to attach all wood blocks. First was glued center piece, after that attached all others.
I want that between blocks will be 7mm gap, so I'll used 7mm spacers. Final assemble process is quite simple, use spacers and clamps to fix block in preferred place, pre-drill and screw it in place.
Step 7: Appling Wood Finish
And last step - it's time to put some finish on. I used transparent finish look beeswax oil.
I really like how it takes out all wood texture, all dark spots, splits and time marks. All that was created by nature. It doesn't matter, how hard you will try, to repeat this color and texture mix - I'm pretty sure, you can't. That's why, this look is so unique!
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    5 Discussions
    ravijag
    9 months ago
    Made one for myself
    IMG_20180722_114615.jpgIMG_20180722_114623.jpgIMG_20180722_114623__01.jpgIMG_20180722_114633.jpgIMG_20180722_114643.jpg
    ravijag
    9 months ago
    Good looking clock. Building one for myself with slight modifications.
    Whitney Fabre
    10 months ago
    This is so simple but I love the look of it. Also, good idea just using an old clock rather than buying new clock parts.
    AlexT306
    10 months ago
    I love the minimalistic style you have going on. This clock looks great - good luck in the contest! Voted.
