A Dozen Red Origami Roses
339,021
1,198
109
About: Engineer
A unique twist to the traditional giving of roses on Valentine's Day. Handmade origami roses are everlasting and inexpensive to make.
Step 1: Inspiration
Looking for a unique way to convey my love, the idea of paper roses popped into my head. A quick Google search and it turned out it wasn't such an obscure idea.
The first result returned Bloom4ever a company that specialises in hand-made roses, and they were even nice enough to include a How to fold origami roses guide. The site lists dozen rose bouquets for $80.
Step 2: Equipment and Materials
Only the most basic craft stationary is required, these include:
  • Scissors
  • Ruler
  • (Craft) Glue
  • Pens/Pencils
The most important material is the paper, unable tot find any origami paper, I had to settle for coloured A4 paper, and this turned out for the better. I used 80gsm A4 paper, as i didn't already have it, I purchased 100 sheets of red and green for $6.50 AUS. You may be able to borrow some coloured paper from your school or work, 1 sheet of coloured paper is required for the rose and 1 sheet of paper is required for the stem and leaves. You should experiment with different paper sizes and thickness to find what best works for yourself.
Other materials include:
  • clear transparent wrap (Cellophane) - to wrap the bouquet, around $2 from any Newsagency.
  • 1mm diameter wire - to make the rose stems, nice to have but not a requirement.
  • ribbon - to tie the bouquet or roses.
Step 3: Folding the Rose
This rose was designed by origami theorist Toshikazu Kawasaki.
Start with a sheet of A4 paper, and cut the paper into a square. I used a 17cm square as I found 21cm (width or A4 was too large), and 13cm (recommended by bloom4ever) was too difficult to fold.
I will not go through each folding step as there is numerous resources already available:
I used the bloom4ever instructions for the most part. Even though step 25 is broken into steps, I could not work out how to perform the 'twist' maneuver.
This YouTube video saved my life, big credit to the producer.
I have included my own version of the tricky part. It should also help.
Make as many rose heads as required.
Step 4: Stems
I found some 1.86mm copper wire lying around that could be used for the stems. The advantage of copper wire over a paper only stem is that the copper can be bent allowing for better arrangement of the individual roses in the bouquet.
The copper wire was first straightened by pulling on the wire with one end in a vice. Once straightened the wire was cut into 30cm lengths. Each wire was then rolled with green paper and the end glued. It is possible to make stems without the wire by only rolling paper.
I needed a simple method of attaching the stems to the rose heads. Each wire end was bent into a shape that allowed the rose heads to simply be twisted onto the wire. Glue was then applied.
An idea that I think would look good, is to make the rose heads from silver metalic paper, and keep the stems as copper or silver.
Step 5: Leaves
After Googling rose leaf for ideas, basic leaf shapes were cut out of green paper. Each leaf had a little stipule allowing it to be glued to the main stem. There were two leaves per stem, glued in an alternate pattern.
Once the glue dried, the leaves were slightly bent through the centre axis and shaped to give a more appeasing look.
Step 6: Making the Bouquet
A dozen roses were bunched and arranged together to form a bouquet. the stems were securely tied together with red ribbon.
Clear transparent wrap was used to wrap the bouquet and again fastened with ribbon.
A simple card was made to accompany to flowers.
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    109 Discussions
    Copyu
    3 years ago
    That's really cool!
    I saw someone, decades ago, making 'roses' using crepe paper that was stretched to make very 'realistic' rose petals over a paper-clip and I was looking for a link to that. I love your origami version, though. Thanks!
    [PS: In Japan, "Valentine's Day" is for the girls to give the guys a present (usually of cakes or chocolate) and we have "White Day" on 14 March, for the guys to respond with flowers, candy, lingerie, jewellery, etc, so this is timely for me.]
    crank_girl
    3 years ago
    I made an origami wedding bouquet and origami buttonholes but wasn't particularly satisfied with how the flower heads joined onto the stems. Your way seems sturdy so I'll give it a go. Thanks for sharing!
    star_empyre
    7 years ago on Introduction
    heh i'll probably try your 'ible for this year's valentine's!
    thanks for the great ideas c:
    kirbygirl46cutekitten
    they're right about the kittens LOL, have you ever seen "josie and the pussycats"? "PUPPIES TURN INTO DOGS WHO GROW OLD AND DIE!" but i agree, i would love these. it's beautiful
    pedlacutekitten
    i hate cats and kittens are worse they will become cats.Still want me to make roses for you?
    codongolevcutekitten
    that would suck for the guy.... spent all his time making roses and now he's gotta clean up his girlfriend...
    natsheh
    thanks, i made some, i love roses. this needs patience. it took some time making the roses so i just put them in a glass bowl. the next step is making stems and puting them in a proper vase.
    =3cwix09
    Reply 8 years ago on Step 3
    I think he is using the standard rose.
    cwix09=3
    thanks equal sign three..
    but valentines day was a couple days ago lol....
    i figured it out though! :D
    =3cwix09
    Lol, I never look at the dates/times. I'm sorry D: But good job at figuring it out. Took me 6 months to finally figure out how to "Square off" the rose. O_O :D
    cwix09=3
    "O_O" is right
    holy cow lol
    i thought it took me along time to get it
    like 4 and a half hours toiling away at it lol
    persistence is key!
    brooklynlord
    Come on.....
    It's not that hard (or maybe i'm just good at folding).
    I did a jewelry rose:
    http://www.bloom4ever.com/jewelry_rose.php
    Didn't even need a video. Just follow the instructions
