A Fun Rubber Band Bird Call
19,513
16
8
About: http://www.webfun.org http://www.dometents.com http://www.gripclips.com http://www.relieftents.com http://www.primitiveways.com http://www.woodenbikes.com http://www.bobgillis.com
A Bird Call using rubber bands (cordage and grass can also be used). Use a green branch, With a knife split the branch and remove a bit from the center of each half so you can blow through it. you can also remove the bark if you want.
Step 1: Name This Instructable
Use one band to hold a cut wider band at one end of your branch. Cover hole with your mouth and blow. Pull on rubber band or grass blade to change notes.
    • Jewelry Challenge
      Jewelry Challenge
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    8 Discussions
    WaffliciousX_D_3_M_1
    ye you have to put the broken rubber band along the stick; I do this exept with my thumbs and grass.
    MatinX_D_3_M_1
    Reply 11 years ago on Introduction
    Not sure what happed to the photos. Seems like Instrtuctables may have dropped them? For now please go to: <a rel="nofollow" href="http://primitiveways.com/pt-quail-call.html">http://primitiveways.com/pt-quail-call.html</a> to see them.<br/>
    Matinthe rubber band
    Reply 12 years ago
    Make one; hold the slit to your mouth; blow through the slit while pulling on the cut end of the larger rubber band that extends from the end that is not secured the small band. The more you pull: the higher the whistle you get. You should be able to make a wide variety of bird call and other sounds. It is quite effective and fun.
    clint eastwood
    12 years ago
    cool im the first one to comment on this project
