A Lego Clock Case
14,897
35
11
About: I'm an experimentalist, a scientist and I have a tendency to do things just for the sake of doing them, or to find out what they're like. I love life, show me something I can feel good about. I've got an ...
How to rebuild a digital clock into a Lego case.
I did this because the current kitchen clock needs a new battery & as a consequence, is always showing cowboy-time. I needed a new one, that plugs into the wall.
Supplies:
Step 1: Take the Old Clock Apart
You need a digital clock, a screwdriver, a sharp knife, and to state the obvious, Lego.
Remove all the screws & pull it apart, taking care that none of the internals are damaged as you do this.
See pictures for details on the internals.
Seems I got one of these:
http://www.argos.co.uk/webapp/wcs/stores/servlet/Search?go.x=4&jspStoreDir=argos&catalogId=651&referredURL=http%3A%2F%2Fwww.argos.co.uk%2Fwebapp%2Fwcs%2Fstores%2Fservlet%2FSearch%3FstoreId%3D10001&langId=-1&searchTerms=255%2F0431&referrer=COJUN&storeId=10001&go.y=11
Step 2: Rebuild With Lego
The exact design depends upon the bits you have, this sequence of photos shows the build around these guts.
Step 3: Switch On
In order to use the buttons for setting the time, I had to lift the hatches and press with a Lego stick.
The display looks better in poor light because I've removed the green filters. However, I could chop the outer filter add it back, if this is too difficult to read too often.
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    11 Discussions
    Jezza Bear
    12 years ago
    I got it, cowboy time 9.48am is the same as 3.18am, all you have to do is turn the analoge clock 180 degrees and you have the same time :-p
    Jezza Beardestroyer2
    Click the picture of the clock above, at the moment it reads 9.48 turn the clock upside down and it will read 3.18.
    Also cowboy time Ten to Ten, if you repeat it over and over again it sounds like a horse galloping :-)
    Cheezpaperlemonie
    Oh haha I thought instead of using a 12/24 hour clock it used a unique time system in which there were only 10 hours displayed on the clock.
    After reading urban dictionary, I finally understand.
    lemoniecarbon
    Reply 12 years ago
    Sorry it's a really poor joke. Cowboy time is ten to ten, I can't explain it in writing (need singing and having watched the opening titles of The Lone Ranger).
    Calltaker
    12 years ago
    OK, I really really really like this one. I think I may actually have to try it. Funny thing is, i was just thinking recently that I have to replace my current alarm clock as it is not as reliable as it was when I got it about 6 yrs ago. It is a CD player alarm clock, so if I do this, I will have to document it and post it. ~C
