A "No Nails" Raised Bed
44,423
263
85
About: I am a Marine Engineer in the RNZN (41 years done in various navies) and am looking forward to retirement!!! so I can do more messing about with tools
We are slowly trying to become self sufficient at our property and have a piece of land that has poor access for the mower etc and is covered in rough grass, so I have decided to put in a raised bed and grow root vegetables (potatoes, kumara etc). See before and after pics
The raised beds seem to be much more successful for growing and I have already built several (photos are included in this I'ble) but this is the first one that I have properly documented.
The basic construction is the same for all the ones I have done, just small details/shapes/sizes etc have changed
The whole thing is made from 6x2 H4 timber (or 150x50 if you are metric) and I used 6m lengths to minimize the cutting
These can be made with no nails allowing them to be deconstructed if required, I am going to use a few nails as these are going to be in for good and make the whole thing more stable.
EDIT For all those commenting that H4/ pressure treated lumber is toxic, please read the text
1. The whole thing is lined with plastic to prevent any chance of chemical transfer
2. Arsenic is no longer used in pressure treatment (and hasn't been for many years)
3. Studies have shown that toxic transfer is a MYTH!!
4. I didn't build out of cedar as it is eye wateringly expensive in NZ
EDIT2 if you really want to know the dangers (or lack thereof of using Pressure Treated Timber in raised bed go HERE www.naturalhandyman.com/iip/infxtra/infptforraisedgardens.html
Step 1: The Wood
I ordered a dozen 6m lengths of 6x2 rough sawn H4 timber (H4 means that it is treated for in ground use, mine are above ground but it means they wont rot any time soon)
I got this on sale at NZD $3;60 per metre + tax (so about $4 a metre) so $288
I decided that as there was space I would go for the easy dimension of 6m x 3m, so I cut a couple of the lengths in half with my compound mitre saw
Step 2: Layout
So I laid the wood out in the area I am going to build, just to get an idea of the dimensions.
It is also a lot easier to build in situ rather than build elsewhere and dismantle/reassemble
As yuo can see the grass in this area is pretty rough ( I will dig this out later) also the area isn't flat so I will do some jiggery pokery when building.
I took the opportunity at this point to move all the wood over (as I was feeling strong)
Step 3: Notching the Timbers
So for a "No Nails" construction there has to be some way of joining the wood., you could try the powers of positve thinking, but it is much more reliable to notch the timbers.
I marked out the position 100mm from the end amd then set my circular saw to a depth 1/4 of the timber width (ie 1.5 inches or 38mm) In reality set it a fraction more than 1/4 to ensure sufficient depth ( I went for 40mm)
I then made several parallel cuts and removed the waste wit a chisel, on completion the bottom of the notch was cleaned out by sideways movement of the circular saw (you can use a chisel but power tools are quicker!)
Step 4: Rinse/Repeat
So carry on and notch the other side the same way and both sides of the other end, repeat on all the other pieces
As you can see I checked the notch width with a piece of scrap 6x2
You may find it easier after the first couple of pieces to partially assemble the next laye and transfer measurements upwards for accuracy of assembly
Step 5: Start Assembling
Now you can either cut all the pieces and then assemble or as I do cut them as you are going as sometimes there needs to be a bit of adjustment and it's better to do it as you go along.
As you can see the area is a bit slopey so I will level it on bricks and take care of that when I fill it
Step 6: Carry on Going!
the top "short ends need a piece of 6x2 cut in half lengthways but the same principle applies
Step 7: And That Would Be It
To all purpose at this point it is complete, ready for filling etc but a few finishing touches make it more practical
Step 8: Nice Extras
It is always nice to have somewhere to sit at the edge of a bed when weeding, planting etc, so a piece of 6x2 on its side makes a convenient perch.
This was the only place I used nails in the whole build, to secure this on the top.
The corners all have half lap joints to make it all a bit neater, again just cut out by making 1" deep cuts with the circular saw and cleaning out with a chisel
Step 9: Finished and Ready for Filling
I will line the inside walls with plastic (old feed bags) to minimise the chance of rot, however being H4 it shouldn't rot in any case.
Then will have to fill it, I estimate it will take 9 cubic meters of soil -- another day I think, at least I have a big pile of top soil close by!
The whole construction took a little under 4 hours to build, could have been a lot quicker with a helper to lift some of the bits (and if I didnt keep putting tools down and forgetting where)
Check out my other I'bles for different takes on raised beds--- I have built a few now!! There is also one pictured above which is a slightly more complex design - but same principles apply (this one is 6m x 6m)
Once filled I use weedmat and macademia nut shells as a mulch as we are on tanl water and thus want to keep watering to a minimum
This mulch along with the plastic lining mean that even at the height of summer we only have to water once a week
Also when filling I do alternate layers of the sandy soil we have, then topsoil (3 inch deep layers) topped off with about 4-6 inches of good quality compost or manure ( I get Alpaca poo by the truckload from a neighbouring Alpaca farmer--(don't know where he gets it from though!! :-) )
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    85 Discussions
    puggirl415
    3 years ago on Introduction
    Love this project. I was at my garden today and my raised bed is rotting to bits. I love the idea of spending several days making this project with just hand tools. If it gets too hard I can always break out the circular saw:)
    buck2217puggirl415
    Reply 3 years ago
    Please use power tools. Its really hard work else. Plus with power tools you can bugger things up much more efficiently. ;-) (see my shed I'ble for fun with powertools)
    puggirl415buck2217
    Reply 3 years ago on Introduction
    You're probably quite right about that. It sounds romantic making something with hand tools. I was inspired by your instructable and by this video on making a lot of things with hand tools.
    https://www.youtube.com/watch?v=lV3WTfA5i24
    Global092
    Hi All
    Have been reading the posts and yes while treated timber may no longer be toxic and the boxes are lined with sheet plastic(good idea) - I still like the idea of untreated timber. Has anyone thought to use old pallet timber for their smaller boxes as it is generally "1" and not the thinner 25mm and if used in the shorter lengths is quite strong. Happy building.
    puggirl415Global092
    I thought this was a good ible about pallet wood. It may clear up issues regarding what if any chemical treatments wooden pallets go through.
    https://www.instructables.com/id/The-Pallet-Bible-A-Guide-to-Finding-Inspecting-and/
    Cheese QueenGlobal092
    You are avoiding treated lumber but you are willing to use pallets that may have been used to transport who-knows-what during their lifetime? Many pallets are not only treated with toxic chemicals when manufactured but are reused multiple times. You have no idea what you may be introducing into your garden with pallets, but you're okay with that.
    Good luck with that "gotta avoid treated wood!" logic.
    Some of the pallets you see getting delivered (with stuff on them) to smaller businesses around here (NJ) are generally bare, untreated wood. The kind out back of Home Depot or Acme are definitely treated, though. I think the treated ones are going to get picked back up by the deliverer and the bare ones are "your problem now." Just my $0.02.
    gonads81
    3 years ago
    Nice instructable! I plan on using this in the next few weeks. Just on the comment about arsenic no longer used to treat timber. I live in Australia and just bought 3 meter lengths of treated pine sleepers. it has CCA H4 printed up the side. arsenic is still used. What is absorbed into the plants is another thing.
    buck2217gonads81
    Reply 3 years ago
    wow aussies still using copper chronium arsenic - tell me why skippy!!
    DIY-Guy
    Author: Beautiful project, thank you!
    Everybody else... have you noticed all the FUD (Fear Uncertainty & Deception) coming from people who refuse to understand what they read in plain english?
    The references are given, the facts stated, the logic is clear, and yet some people insist that there is danger when there is no problem in the design or the chemistry.
    It's as bad as the pro-vaccine people ignoring the deaths and hospitalizations caused by vaccines, except the other way around with this concept.
    I hope someone will think deeply about the previous sentence. :)
    Kathys SmokinDIY-Guy
    I was surprised to see the number of comments beating the same explained and defined horse. I hope buck2271 isn't so discouraged by that he stops posting I'bles because he shares good work.
    DIY-GuyKathys Smokin
    Agreed! Buck2217 Please know that I think you should keep inventing and writing Instructables, we need more good clear thinkers. :)
    Kathys Smokin just remember that emotionally loaded keywords in a subject will get automatic, reflexive, responses from people who have low information. But we can all be glad they are here on Instructables and learning, there's hope! One time at a farmers market I was agreeing with a person about the germ fighting benefits of raw garlic but I made the mistake of giving some additional new research, to help educate them. Next thing you know, I'm being accused of arguing... and my reputation suffers due to a person who refused to admit they couldn't understand what I said.
    The world is a funny (weird, not funny ha-ha) place.
    Now got out and grow some vegetables and enjoy them! :)
    Okay! (I'm laughing now.) I'm familiar with that kind of situation, thanks for assisting my perspective. Build, grow, share, repeat, let no one discourage me.
    That is some very good advice for life in general, my friend. Thank you.
    buck2217Kathys Smokin
    I've worked in Govt Orgs for my whole working life (RN / RNZN) so I'm used to banging my head against a wall! I don't get discouraged by nay-sayers etc, in fact if someone tells me it can't or shouldn't be done it just makes me want to go out and do it more ( hence all the scars!!)
    Kathys Smokinbuck2217
    Ha, ha, ha! I'm that kind of stubborn, too! I do get discouraged when I spend time explaining, explaining, clarifying…. and it makes no difference. I'm new here, getting the lay of the land…. reading all of this one made me think twice about ever posting a I'ble. I'll accept your example, though, my friend, and go back to being open to posting one in the future, maybe this winter when I have time to spare. I've posted cook threads and they take hours to create.
    buck2217DIY-Guy
    Thanks for the comment, I am probably on the other side of the fence Vaccine wise, Although there are some issues with vaccines, overall I believe they prevent FAR more than they injure. But it's a free world and TBH the population is far too high!
    jvandeyacht
    3 years ago
    Forget the raised bed, look at that awesome view. If i had the visa, i would move there just for the view. I love my raised beds, used pressure treated wood w no liner. I trust the science too. On top of that, i work for local government and one of the privelages is i have access to things like the university. I have given sample plants from my beds to the graduate students to run tests on as part of their graduate studies to identify potentially dangerous chemicals. They only ever found that i use 7. A pesticide. Never anything else. Top it off, they found i dont use enough. To be effective i need to either respray or strengthen a little. Screw the pressure treated naysayers. No grad student ever found harmful substance in my plants that I didnt put there intentionally.
    I love the authors complex raised bed and plan to emulate it at my house.
