A Shutter Release That Will Outlive Your Camera
51,552
399
16
About: I am a British Graphic Designer and Photographer, when I am not working, I spend my time making an array of projects. I used to make a lot of props, but now I spend most my time building crazy cameras and sh...
Even a super expensive nice camera is only rated for up to 250,000 'clicks' or photos. I have used a few shutter releases in the past, some I have been impressed with.
Others failed far quicker than I would have liked. I had recently moved to using a mechanical keyboard, which features independent switches opposed to a membrane. The key switches used in them are rated for several million presses.
So I thought, these would be great for a remote shutter. I was working on a stopmotion video a few weeks back and had quickly wired up a remote using one of the switches. It was a joy to use and you could easily activate the camera with the press of a foot too.
So I decided to make a better version using 3 switches, one to focus, one to shoot and a third locking switch to lock the focus. Using a headphone jack and a 3.5mm to 2.5mm audio cable means this is a pretty simple project.
This project involves some soldering, if you have ever thought ‘I would like to learn to solder’ then this is a great project to get you started. As for learning the basics of soldering, there is a great guide you can download here - http://mightyohm.com/files/soldercomic/FullSolderComic_EN.pdf
Supplies:
Step 1: Parts and Tools
First, lets collect together the parts we need. The key part is the 3.5mm to 2.5mm audio cable. My camera uses the smaller 2.5mm connector for the shutter. If your camera uses a propriety connector, you can get shutter cables that also have the audio connector on the other end. The advantage to using a separate cable is it makes it easy to replace an individual part, instead of the whole unit.
You need three switches, any switches will work. For the focus and the shutter you want to pick out some simple push button switches, push turns it on, release turns it off. For mine I used some mechanical key switches. These ones are made by a company called Cherry. They come with separate key caps, so you can pick and choose what size/colour/shape button to use. Here I have some lower profile square ones, using F or ON for focus, then S or YES to shoot.
Next we need a locking or sliding switch. This is a switch where you set to either on or off and the switch will remain in the desired position. I prefer to use a locking push button switch, when you press it the switch remains depressed, another press will release it up. However a simple toggle switch as pictured works too. Then you need a 3.5mm audio connector and some wire, you can use different colours, you don’t have to, but it can make it easier to see what you are doing.
Then we need the following tools,
  • Soldering Iron
  • Solder
  • Wire Cutters
  • Wire Strippers
Step 2: Find or Make an Enclosure
Finally, you need a case. You can buy all sorts of electronics plastic enclosures that you can easily cut with a
Stanley knife or box-cutter, or you can reuse something else. For mine I used a laser cutter at my local Hackspace to make a custom enclosure. For this tutorial though, I will be using an invisible case so you can see more easily what is going on.
Step 3: Check How Your Camera Connects.
Next we need to find out, or work out which part of the headphone cable does what. On Canon the base of the plug is the ground (this is used to connect a circuit back to the camera), then the middle section is focus and the tip is shoot.
If you are not sure, then you can use a bit of wire to test out which section does what. Most of the time the base of the plug will be the ground. So start with the wire on there and touch it to the other sections and see what it triggers on the camera. Depending on the connector you have to plug the audio cable into, it might not be clear which of those sections relate to which pin. So I recommend plugging it into the connector, then using a wire to work it out.
Step 4: Start Soldering
Now we have all our parts, we know which pin on the audio connector does what, so we can crack on with soldering. These photos are set out nice and clearly for you to follow, no need for circuit diagrams or anything too complicated.
The first bit of wire we want to solder on is the ground wire. Start by soldering this onto the ground pin of your audio connector. You then want to solder it onto one side of every switch. Make sure you insert your switches into the enclosure first if they need to be. These Cherry mechanical keyboard switches DO need to be insert through first.
Step 5: Connect the First Switch
There we go, that wasn’t that hard. If you struggle to hold the items when soldering you can always put them into your enclosure first. Blu-tac is great for holding things in place while soldering too. You can leave the wire covering off this wire if you like. Just make sure to cover the others. I left it on mainly for clarity.
Next you want to solder a wire between your ‘Shoot’ pin on the audio connector and which ever switch you want to use to shoot. For me, its the second switch up.
Step 6: Connect Your Second Switch and the Toggle Switch
The nal wire to put on needs to run from the ‘Focus’ pin connect with the push button you want to use for focus, then connect to the focus locking switch.
Step 7: Circuit Finished
Here you can see the finished example circuit, plus the inside of the original example. You can see there is slight variances just between the parts I used. The wiring can be kept a lot more compact, you can see I left my ground wire un-covered as long as its not touching anything it shouldn’t cause any issues.
The main positive about this project for me, is that if anything ever breaks on the shutter, because I made it from scratch, I am perfectly qualified to fix it. So rather than buying a whole new shutter release, I can put in a new bit of wire or replace a switch.
Step 8: Final Pointers
Also, with making your own, you can tailor it to t your experience perfectly. On mine I used a cable tie to add a hoop onto my shutter, this is great to hang it o the end of my tripod, or to clip it to a belt loop. Coupled with an audio extension cable its really handy when working with a project like stop motion, or with product photography. I can have the camera set up, move a few bits around, then just reach down and quickly fire off the camera before progressing.
Basically make it your own and have fun making it, hopefully learning a few skills along the way too.
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    16 Discussions
    rickyeatough
    4 years ago on Introduction
    Amazing!!
    Great idea, definatly going to make it soon for my canon!
    Would this work with an iPhone? You can use the volume up button on an iPhone to shoot, but can you connect ground then the tip or something?! Not entirely sure?
    imark77rickyeatough
    Reply 3 years ago on Introduction
    you can actually use the iPhone headset, or so-called third-party camera buttons.
    unfortunately it uses the volume buttons which send a coded signal vs. the mute/talk button which is more or less a resistive short.
    seeing how certified headsets are 20$ on up, it might be cheaper to find the third-party thing and Hack it. ( I broke my included headset on another project, and my cheapest option was to scavenge somebody else's set ).
    gmjhowerickyeatough
    Reply 4 years ago on Introduction
    Yes, this is could be possible. The iPhone plug jack has an extra 'band' to it due to having a microphone as well. So you either need to get cables and sockets with those number of bands, or you could just cut off your plug/cable from an old pair of iPhone headphones and solder it on.
    Waldo32487
    4 years ago
    I was really looking forward to making mt own remote, however just so you and others know, for the Nikon d3200 you can't build this type of remote. again, was pretty bummed, but on the d3200 you can't use the audio connection as it's only for microphone and the other must use some sort of signal. I was able to get the focus to work, but won't snap the photo. ?
    dan3008Waldo32487
    for a nikon, you'll need a special wire, but there are adaptors to let you use a 3.5mm conector...
    just nikon being pains
    Khord
    FYI, a camera being rated for 250,000 actuations, in your example, is not related to the membrane button wearing out. It is referring to how many times the actual shutter mechanism in front of the sensor cycles. So technically, shutter release remotes don't help out in the matter that you suggest in the intro because they are still invoking the camera's shutter and adding 1 actuation each time.
    That being said, I really like mechanical keyboards and this idea is great. Looks very utilitarian and attractive. I will just have to find out which pins to use for a mini usb cable instead, because I have a Nikon.
    gmjhoweKhord
    Hi, I never suggested that the remote shutter release would make your camera live longer. I said that the actual shutter release itself was likely to out live the camera.
    gmjhoweSenanD
    I got mine as a lot of 100 off a Mechanical Keyboard forum, but individual switches are often available on eBay and Amazon.
    gmjhowegrayl
    Thanks, they must have changed the URL from when I started writing this tutorial, I have updated it now.
    zxaviusgmjhowe
    Reply 4 years ago
    Stupid question, but how did you mount the switches to your case?
    gmjhowezxavius
    The Cherry switches push fit into the case from the front. Hence why you need to make sure they go in first. Other push button switches are similar.
    K.hall86
    4 years ago
    Fantastic!
