A Reliable Plasma Speaker
225,021
481
343
About: Physicist
I've seen multiple designs for a plasma speaker online, and quite frankly most of them suck. Some problems I noticed were constantly blowing up MOSFETs, distorted audio, excessive heating of the MOSFET(s) etc.
So, In this instructable I'll show you how to build the speaker that's on my website. Properly heat-sinked it'll be able to run continuously; I have run mine for a length of about 6 hours with no problems.
Supplies:
Step 1: Gather the Parts
You'll need some parts for this speaker, not too many but some.
You'll need:
Components:
4x  UF4007 diodes
4x 12 volt zener diodes
2x  IRFP250 mosfets. You can also use some better fets, the lower the Rds On the better. Just make sure they can handle at least 200V, flybacks make some nasty back EMF.
1x  SG3525 IC
1x LM7812
2x  22 ohm resistors
1x 2.2k resistor
1x 10k pot
2x 0.1uF (104) capacitors
1x 3.3nF (332) capacitor
1x 1uF (105) MKP capacitor
1x 2.2uF electrolytic capacitor
2x 10,000uF electrolytic capacitors If you use 40v 8000uF caps instead you can apply 36V and make the arc even bigger and louder. Just make sure to replace the 7812 with a 7815 or a 7818.
Other components:
A flyback transformer. You can get these out of old computer monitors, TVs etc.
A ferrite toroid. These may be inside computer monitors, but if you can't find one get it here.
Some 18ga wire.
Some 24 ga wire, the wire from inside of a telephone cable works great.
2 heat sinks, you can get them from a computer monitor. You'll need to use your scavenging abilities here.  If you use 1 heat sink make sure you use some insulating pads.
Thermal goop.
Step 2: Making the GDT
The gate drive transformer is a part you'll need to make yourself. It consists of 3 strands of wire wrapped >14 times around a ferrite core. It's not much of an exact science, just wrap it all nice and neat.  Use the 22ga wire for this.
Step 3: The Circuit
I know that some of you people aren't very electrically minded, so I decided to make a circuit diagram that is very easy to follow.  For those that do understand schematics, here's one.
Step 4: Breadboards
Building something for the first time is called prototyping. This is usually done on a device called a breadboard. I could bore you with a wall of text, but instead I'm going to link to a video that shows you how to breadboard.
Breadboards are relatively cheap, and it's a great investment. Breadboards have one flaw though; some parts have either pins that are too big to fit in the holes or they must be attached to a heat sink. To use these parts I recommend just soldering wires to them. Soldering isn't hard, but it's the best way to connect things.  There are plenty of soldering guides on the interwebs.
Make sure you put  a pin on the ends of the wires so they can plug into the breadboard. Also make sue you use heat sink goop (and insulators if 2 fets share a sink).
Step 5: Prototyping the Circuit
Just hook it all together! It doesn't need to look nice, it just has to work.
There's an important note on the next step regarding the gate transformer.
Step 6: Phasing the GDT
You must make sure the GDT is properly phased. Phasing is the direction of the transformer's windings. You must make sure that one output winding is reversed; this reverses the signal that it puts out. The purpose of the GDT is to isolate the mosfets from the chip.
The mosfets are supposed to "flip flop" --one turns on as the other turns off. This means the gate signals of the fets are supposed to be opposite. If both the signals are the same, both the mosfets will turn on at the same time and they short circuit or possibly explode.
You want one signal inverted and to do that you reverse a winding; that inverts the signal.
A picture will better explain what I'm talking about.  Also, make sure the wire in the middle is the one that's connected to the IC.
Step 7: Initial Tests
For the initial test I recommend using a power supply that can't supply over 9000 amps. Unless you are confident that you have everything hooked up correctly I'd use a computer power supply to test it initially. Computer power supplies are current limited, and that means if you f*ck up and both of your mosfets turn on at the same time the PSU will detect a short circuit and turn off, saving your $2 FETS.
There are many guides on modifying computer power supplies to be used as bench supplies, and here's one of them.
Test your circuit by taping a drinking straw to the high voltage wire on your flyback. Then apply the power to the circuit and hope nothing blows up.  If everything is OK use that straw to move the high voltage wire to the pins on the bottom of the flyback.  You should be able to arc to at least one of the pins. If nothing happens you did something wrong.
Make a note about which pin the electricity arcs to best. This is your ground pin.
Since this is only 12 volts and limited amps don't expect anything impressive. You're just making sure thing work.
Step 8: Apply the Juice!
Alright now it's time for the big guns: Lead acid batteries. These things can supply over 9000 amps and they have no electrical noise whatsoever. They are usually 12 volts so you're going to need 2 of them.
You can either use car batteries or AGM batteries. I prefer the AGM ones because they are smaller and you can't spill them. A 12V 8Ah AGM battery usually sells on eGay for about 10 to 15 dollars. Lead acid battery chargers can be bought cheap on eGay too. Although batteries are not too cheap, they will become one of your most used "tools" if you start playing with circuits.
Put them in series to get 24V.
When you apply the juice to your circuit the arcs will be hotter and longer. Apply music to the circuit. You'll need a "clean" music source; an ipod makes tons of electrical noise. I used the sound card from my computer,  some mp3 players may work too. Turn the volume all the way down and then up a little because too loud a signal can kill the IC. Plasma speakers aren't too loud so you'll need a quiet room to hear it.
Turn the pot until distortion of the music is at its lowest.
Step 9: Make It Last
To make the thing last you'll want to put it on a perfboard. These are pretty much blank circuit boards with plenty of holes. Buy perfboard, not vero or strip board. Strip/vero board is a PITA to use.
Once again, perfboarding has been covered by others.
Have fun!
Second Prize in the
Epilog Challenge
3 People Made This Project!
  • Party Challenge
    Party Challenge
  • Gardening Contest
    Gardening Contest
  • Classroom Science Contest
343 Discussions
John Snavely
3 months ago
what mosfet do you recommend I enjoyed making this plasma speaker but my mosfets keep burning out
John Snavely
3 months ago
my mosfets burnt out I guess because I put too much current through them
robot797grenadier
i am gonna speak against you
you can make a plasma speaker out of a plasma globe
you seek the mofsfet inside the plasma globe
remove it and replace it with something better
and dont conect the base
the base is fed from this circut (or any old 555)
and also what you should do is make a ground conection between this circut and the circut of the plasma globe
when you are done the plasma globe circut gets the high voltage
and this circut (555) does the tuning
if you have done it right you will have a modulated plasma globe
surbarusrobot797
Reply 4 months ago
much obliged......sorry for the late reply. was takin a whee dump
LastOfTheGamers.
1 year ago
Hello, I attempted to make this circuit but I'm not even getting an arc. I looked over the diagram several times but I couldn't figure out the problem. The MOSFETS are stone cold so I think it could be my gate drive Transformer but I'm not sure.
Thanks,
JohnSmith-Workshop
2 years ago
Can i use 12 v dc power supply with out LM 7812 ?
rah187
2 years ago
Also, one other thing... You mentioned that it had to be a "clean" music source... I am very hesitant to plug my ipod into this thing, let alone my phone (which is where I have all of my music, anyway). Can I use one of those $5.00 bluetooth modules so I don't jack up my two only music sources?
rah187
2 years ago
This project sounds great! I have all of tthe parts for it, but I do not have a car battery, let alone two... and I don't have a lot of money for purchasing batteries. Is it possible to use some electrical transformers? I know there will not be as much amperage, but I can buy (oor salvage) two 12v electrical transformers, no problem.
dansassin
2 years ago
What would be the required current supply for this? I'm not sure if my power supply is beefy enough.
dansassin
2 years ago
dansassin
2 years ago
RobbyD9
2 years ago
what are the applications of plasma speakers..???
mtns1
3 years ago
Hello!
I managed to make this circuit to work,but with a problem. without any audio
input i have a clean 1cm arc at 24V 0.7A using a regulated power supply.
My SG3525AN is generating a little heat,don't know if this is good.
I have trouble finding a clean audio source,since everytime i plug a
phone,ipod,mp3,PC the arc is distorted and i can't make it clean even if i use
the 10k potentiometer. Does someone have an idea what i have done wrong? it's
like something is wrong with my IC and the audio inpuit.
Used 0.65mm diameter copper magnetic wire on a 2,5cm diameter ferrite toroid
with 14 turns,wired it just like in the image, insulating pads on the mosfets
and 7012. I also tried 2 different flybacks,with 4,then 6,then 10 turns on
primary ,the same result. Used 4x UF4007.
If I short the audio pins I have a hiss-like sound from it. If I connect an audio
source,even with the audio muted again I have hiss sound.
I appreciate all the help I get,many people on the comments have the same
hiss problem like me.
Thanks and nice project!
wlivingston1
3 years ago
Hey I was wondering what would need to be modified to make this wall powered??
becker990wlivingston1
Reply 3 years ago
just make/buy a simple power supply, use a linear one (with a heavy transformer inside) and not the switching ones (cellphone chargers like)
becker990
3 years ago
excellente circuitry! are u an eeng?
