ALTERNATIVE MIXED MEDIA PAPER BRIQUETTES PART 2
1,952
12
About: Jack-of-all trades, master of some. I would probably be much more modest if it wasn't for these delusions of granduer that I suffer from.
Welcome to Part 2 of Alternative Mixed Media Paper Briquettes.
Due to recent renewed interest in Part one and the Burn test for part one I have decided to publish Part two (The burn test for part two will be published once we have a non rainy day where I can get some decent photos)
You can see part one here
As well as the follow up burn test
The recent comments in part one and the burn test have been really helpful so stay tuned for a part three as soon as I can source the additional medias.
Step 1: Getting Started
Here is a quick refresher course for those that haven't seen Part one already.
Grab a big pile of paper that is ready to be recycled and run it through a shredder to make it more manageable.
Step 2: Now Do the Mash ...
No not the Monster mash.
Using a paint mixer attachment, mix the shredded paper up in a 5 gallon bucket with a generous amount of water until you get a nice slurry of paper pulp.
Step 3: Don't Throw Out Those Used Coffee Grounds Just Yet
I am rather fond of coffee so it doesn't take me long to go through a 30 oz container of coffee grounds.
Rather than just throwing them out I collected the used grounds and set them aside until I had a full container and I was ready to make a new batch of briquettes.
As I was collecting the used grounds I would spread them out on a paper towel and let them dry before adding them to the container, with the exception of the second to last batch. That is why the grounds near the top of the container looked a little fuzzy. Fortunately the rest of the container remained dry and mold free so I scrapped the top bit of grounds into the trash and used the rest.
Step 4: Second Chance Candles
Pro tip: don't store candles in an un-air conditioned attic room during summer months.
I had a set of spherical candles that were a nice decorative accent....
Then they got put away for a few months ....
when it came time to get them back out, they were sadly out of shape. (see the oblong globs of light green wax in the first picture)
I also had a really cool Fu Dragon candle that has seen better days.
Aside from at least half a dozen repaired fractures were it broke into one or more pieces when it was dropped or knocked off of where it sat, it was also missing the tip of its tail.
A few minutes with a cheese grater from the dollar store and I had a shoebox full of wax shreds.
Step 5: Mix, Press, Repeat
Now comes the fun part.
Mix the paper pulp with the alternate media and then press it in the briquette press.
I added the full can of grounds to approx 3 gallons of paper pulp, mixed it well and pressed out 3 batches of briquettes.
After that I filled the coffee container up with wax shreds from the shoebox, and added the wax to another 3 gallon batch of paper pulp to make another 3 batches of briquettes.
To dry the briquettes I put a piece of scrap window screen over cookie sheets and cooling racks from the dollar store. This does 2 things:
1) it lets airflow all around the briquette so i drys more evenly.
2) the screen keeps the mix from oozing down between the bars of the cooling rack while it drys.
The cooling racks from the dollar store are a little flimsy so I put a little piece of scrap wood under the center of the rack to keep it from sagging under the weight of the wet mix.
Step 6: Burn Test Part 2
Stay tuned .. Testing will commence as soon as I can appease the rain gods :)
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    2 Discussions
    Brian M V
    6 months ago
    did you really have to break this up into 3 seperate ´ibles? and if i'm correct even a fourth one is coming?!
    anyway... the candlewax is a smart add! never thought of that! that i will try, but as for all the food-waste trails... let's just say i'm not into 'fuzzy' peanuts! :P
    LorddrakeBrian M V
    Reply 6 months ago
    I am adding new parts as I am able to get enough media to mix with the paper pulp and then make a batch of briquettes.
    In the summer the briquettes will dry out in a few days of good warm sunshine. Unfortunately we have had an unusually wet year where is live (so far we are 27 inches over the annual average ... and right now it is snowing/ wintery mix) So if the bricks don't get brought in before the rain starts ... the drying time basically starts over.
    This has caused large breaks between being able to update with new results.
    I am very hopeful that the briquettes with the wax will be able to maintain a flame on their own. I should have burn test results soon.
    I agree .. the fuzzy peanut shells were kinda gross.
