ATX Power Supply
5,728
137
10
About: They Call me Wallace.
Well   This is my Second Go at this Particular Build.
Get a Used Power supply in Working Order.
open it.  Get all the wires in Groups. All the Backs, Reds,Orange,Yellow.
Keep  the Brown Together with the Orange,
The Green Goes to Switch along with a Ground Wire
The Grey Wire to and LED Along with a GND Wire and a 330R
The Purple To an LED Along With a GND Wire And A 330 R
I Have 3 Sets of Gnd Wires Too many to Put on one Banana Plug.
The Yellow ones to one Female Banana Plug .
The Orange and 1 Brown to One Female Banana Plug.
The Blue,White Not Need it. Just put Heat Shrink on them.
You Need a Resistor 10 OHMS 10 W  Between The Ground Wires and the Red Wires.
See Pictures. MAke sure to Heat Shrink All your  Connections. Be careful   Disconnect Power Supply If checking Wires Etc.
My Build Did Work Fine . Till Today. It was not Turning ON.
So I Open it And Was checking Cables Etc.
And Got A SHOCK!!!!!!!!   and Killed The Power Supply.
So i Have Learned ...  PULL THE PLUG.... DOUBLE CHECK THAT POWER IS NOT ON. PULL THE PLUG.
I Got Careless  Distracted,  just be Careful.
Now Go and Build Something.
By they Way This was My Very 1st Shock..........
Supplies:
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Classroom Science Contest
    10 Discussions
    stevenarango
    2 years ago
    Hey mspencer8. You can do another 5v post see picture.
    2016, 7:15 AM.jpg
    mspencer8
    2 years ago
    Hey i just wanna ask i can add another post for a 5volt with a 4amp or 5amp current? Because im gonna use that to charge 18650 batteries..
    Is there a possibility to do that?
    And also all of 3.3, 5 and 12 volts are all 16 amps, where should solder the brown wire?
    My psu is Delta Electronics DPS-220U B-5 A if you wanna check it out..
    I really need you held right now man..
    stevenarangomspencer8
    Reply 2 years ago
    may be if you find another power supply. this one has only one 5v post.....
    its an old one.. and its dead now. check you tube and you may find what your looking for.... all t he wires you see in a power supply have different Voltages. to run Various computer components .
    stevenarango
    5 years ago on Introduction
    the reason the resistor is there .. is to fool the power supply by creating some resistance 5V and Ground, so it thinks that is connected to a Computer. other wise it will not power up.
    amiirstevenarango
    Reply 3 years ago on Introduction
    this is for old PSU.
    new power supply just need connect Green wire too GND for turning ON!
    amiirtobias.sobkowiak
    that wires are 12V and GND of 4PIN Connector.
    just cut them off.
    you have 12V on solid yellow wires.
    kermit.t
    5 years ago
    I learned after many builds and many installations, a good multi meter is my best friend!! test, test and test again. better cautious than fried.
    jmwells
    5 years ago
    I'm a professional electrician. There's an old saying amongst electricians. A good electrician might get his fingers tingled now and again, bad electricians die. A little shock now and then insures our respect for power. No respect, you die.
    stevenarangojmwells
    Reply 5 years ago
    i hear ya brother... i will be extra careful......
