Acrylic Pour Painting - on a Budget
9,941
117
20
About: Self-taught part-time artist who paints, draws and doodles.
Is your drawing deplorable? Is your painting pathetic?
Well, acrylic pour painting is just the thing for you!
It needs no drawing or painting abilities and lets you act like a five-year-old by getting paint all over your hands. Yaayyy!
This Instructible will focus on acrylic pour painting, but on a budget. Most of the things can be bought from dollar/pound shops.
Here's what you'll need:
  • PVA glue
  • Water
Those will make up your pouring medium. You can get 500ml bottles of glue from dollar/pound shops.
  • Acrylic paint
You can get these cheap from dollar/pound shops, but I'd recommend getting some decent student/artist quality stuff from Amazon. Acrylic paint is pretty cheap. Get big tubes of the stuff as you'll use lots of it. For white, get a big 500ml tub as it's the most commonly used colour.
  • Something to pour paint over
  • Gesso (optional)
You can buy cheap box canvases (a wooden square/rectangle with canvas stretched over it) or you can use bits of wood. If you use wood you'll need to get Gesso. It's like undercoat, but a bit rougher. Hell, try cheap undercoat, it might work. Box canvases come pre-primed with Gesso.
  • plastic cups (various sizes)
  • lollipop sticks
  • latex gloves (optional)
  • plastic sheet (for minimising mess - optional)
You'll mix paint in the plastic cups, and stir it with the lollipop sticks. Buy different sizes of cups such as 7 or 8oz and even some little shot cups. You'll need over half of an 8oz cup to cover about an A4 sized canvas. Gloves are for sissies. Get your hands dirty dammit!
  • treadmill silicone
Silicone is the secret ingredient that makes the paint go all funky. You only need about 3 drops of this in some cups to give that cell look to paintings. You need to get 100% silicone. Some cheap dollar/pound shops do 3-in-1 or WD40, but most aren't 100% silicone. You'll probably need to get this from Amazon/eBay.
  • butane blow torch
These are the butane-filled ones that are used in kitchens. You can get them on Amazon for about £10-15. You'll need this to activate the silicone and pop bubbles. If cells aren't your thing then you don't need this.
Step 1: Step 1 : Pouring Medium
So, we need to make a pouring medium that we add to the paint to make it more runny. Here's what I do...
Take the squeezy bottle of PVA glue and take 1/3rd out of the bottle. Obviously, keep that as you can still use it. Now, top the squeezy bottle up to its original level with water.
Give it a good shake to get the glue and water mixed.
Done!
That's now your pouring medium.
Water down that 1/3rd that you took out at the start and use that too.
Remember: whatever you have in glue, add half of that in water to get pouring medium.
Step 2: Step 2 : Mixing Paint
Now we need to get the paint ready to put on the canvas.
Take a cup and add a single colour of paint to it. Let's say it's a nice blue colour. Not too much paint (maybe 5mm deep) as we'll be adding about the same in pouring medium.
Squish some pouring medium into the cup (which has the paint) and stir with a lollipop stick.
You want to get the paint to the same consistency as warm honey. When you scoop some paint onto the lollipop stick and let it run off it should run off in a continuous thread, but not like water. That's too runny.
So, do that for each colour you want to use. Choose the three primary colours (red, blue, and yellow) and some white. You'll now have four cups. Each with some runny paint.
TIP: try and use more colours and less white. I find that white makes the painting go all pale and dull looking.
Looking at the four cups. Do you think if you poured them all into one cup you'll have enough to over half-fill it? If so, good. If not, mix more paint.
Lastly, add the magic sauce: about three drops of silicone to some of the cups. Which cups? That's up to you. There's no exact science to this. Try adding it to the colours. Not the white. It's all trial and (lots of) error.
Step 3: Step 3 : You Dirty, Dirty, Cup
We'll do what's called 'a dirty cup' flip.
Put out four new cups upside down. This is to put your canvas/board on when the paint is running off it. Some people use push-pins to lift the canvas/board.
Take a new cup and start pouring in some of the paint. Try a bit of white. Some red (just a little), some blue, some yellow. Maybe a bit more red? Some more white? Sure, why not. Keep pouring them into the cup until you've got over half of an 8oz cup.
Take a lollipop stick, put it in the cup, and draw a number 8. That's it. Nothing more. It's just to get the colours moved about in the cup.
Take your canvas/board and put it upside down over the cup.
Hold the cup and the back of the canvas/board and flip the whole thing upside down. Put it on your four upturned cups. These act as legs and let any paint drip and run off the sides.
Wait a few seconds for the paint to run down inside the cup. Maybe give it a few gentle taps on the butt to help it?
TIP: you can spray some WD40 inside the cup (and spread it around) before adding the paint. This will stop the paint sticking to the cup and get all that painty goodness out.
Step 4: Step 4 : the Big Reveal! Kinda...
OK... here's where the fun starts. You want to lift the cup at a bit of an angle as you effectively want to break any seal that might happen between the cup and the canvas/board.
Whoom! The paint will form a big circle in the middle of the canvas/board.
Get your heat source and quickly run it over the paint to pop any bubbles and get the silicone doing its magic.
We need to help the paint here by tilting the canvas/board to spread the paint.
Golden rule: don't keep moving the paint about as you'll start mixing it and getting dirty colours.
Tilt the canvas/board to one corner letting a little bit of paint run off the sides. Use your finger to scoop up some of the dripped paint and dab it on the corners and along the sides. Let the paint run back to the centre of the canvas/board before tilting to another corner and repeating the scoop and dab thing.
You don't want to let too much run off the canvas/board or you won't have enough left to reach all four corners.
TIP: if you do run out of paint, and you have a bare corner of canvas/board, just scoop some out of what's left on the cup and slap that in the empty space. Get creative.
So, you've covered the canvas/board. Put it back on the cups and give it a final torching.
Step 5: Step 5 : the Final Reveal
So, you're done. But wait! There's more!
Let the canvas/board sit for a few minutes. It still has things going on in there. Over a short space of time, you'll see some paint colours will rise, some will fall. More cells will appear, some will get bigger.
It's chaos in action!
All of these things depend on the type/colour of paint used. The amount of silicone used. Which colours you did/didn't put it in etc etc.
Step 6: Step 6 : There's More!
The dirty flip cup is just one of many things you can do to put paint on the canvas/board. Here are a few more:
  • Dirty pour: you make a dirty cup as before put pour it onto the canvas/board
  • Rings: gently wobble a pouring cup (see above) in one spot to create rings. You'll need some paint left in the cup to cover the corners. You don't want to move the canvas/board too much otherwise you can lose the ring effect.
  • Slide: cover the entire canvas/board in paint (with pouring medium of course) then do a dirty flip cup (but without flipping the canvas - here you need to flip the cup only! Nerves of steel!). Don't lift the cup this time. Here you slide it over the canvas/board.
  • Open dirty cup: Place a cup upside down (bottom cut out) on the canvas/board and put paint in it like a dirty cup. You can drag or lift the open cup.
  • Several dirty/flip cups: get creative and use 3 or 4 shot cups with different colours in each and put them on the canvas
  • Swipe: use a dirty cup, or a dirty pour to get paint on the canvas then use a spatula or paper towel to swipe the paint across the canvas/board
Be adventurous with it. Try different cups or things to get some weird and wacky effects. Pour through a sink strainer? Sure, why not. Collander? Yeah.
Step 7: Step 7 : Ooh! Shiny!
Once your canvas/board has been sitting for a few days and is completely dry you should put a couple of coats of varnish on it to protect it, and to pop those colours.
Varnishing is optional as acrylic paints are waterproof once dry.
Step 8: Step 8 : Disclaimer
Remember: this is acrylic pour painting on a budget.
Possibly the paints, and or the PVA glue, will not be archival. By that I mean the colours may fade/tint over time.
Artists quality paints will not discolour over time, but they are more expensive.
The PVA glue may tint over time. The only way around that is to get proper bookbinders glue, but (again) it's expensive stuff.
So how long will it take for it to fade/tint? No idea. More importantly: who says they definitely will fade/tint? Not me!
Just enjoy getting messy. Give some as gifts. Hang some in your home to make it all funky looking.
Enjoy!
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    20 Discussions
    DLHN123
    6 months ago
    Great instructions but you forgot to add the part about it becoming an addiction. I was warned and didn't believe it; ten paintings later and I'm still doing it. Before you varnish or seal your painting you need to remove any silicone on it. A paper towel with some alcohol works for me. You can also add 91% alcohol to add to a pour to create cells although I've never done it. If you don't like your painting remove the silicone and redo it in any colors you want. I used the paint leftover from my living room and dining room to make pictures for those rooms. You can buy Oops! acrylic paint from big box hardware stores too. I bought a pint of bright red for 50 cents. It's so much fun that you'll start watching craft store sales so you can buy paint or canvases cheap. You've been warned...
    ronnietuckerDLHN123
    Reply 6 months ago
    Don't blame me. I'm just the dealer giving the first one free. :D
    cryogeniusDLHN123
    Reply 6 months ago
    But there are support groups online to deal with the addiction. They help you to manage your life by making the dependence even more affordable. There are also other directions this habit can go - search "Colander Pour" and "lazy Susan pour" and "dirty pour with string art" and "dirty pour swipe with wet paper towel." These activities provide a lifetime supply of dopamine - on the cheap!
    brynn.delorimier
    6 months ago on Step 8
    I've seen kits in stores that sell this all-in-one for a pretty penny. Neat idea that you've found a DIY method! I'm renovating my house and was going to do a similar technique on the floors, but doing a test "patch" first of all the ancient laminate counter-tops, which were going to get junked anyway. Was going to add iridescent medium to some of the paints - I've used that before on my motorcycle and it came out *awesome* at sunset hours, as well as all the nail polish bottles I own, because, well, I'm renovating a house and my hands sure show it! I plan on covering the thing, once dry, with a few layers of resin (and maybe a few more coats of paint/resin/paint for some 3D!) to see how well it'll self-level. I think my color wheel is going to be mostly hues of yellow/gold/dull orange/bright orange/black (black as a separate layer toward the bottom so we don't wind up with an unfortunate yellow & brown scheme) and little punctuations of the nail polish colors here and there so it's not too monochrome. I hope this will pass for a kitchen suitable for someone well past the age of 20 and also not look like McDonalds on LSD. :)
    ronnietuckerbrynn.delorimier
    Reply 6 months ago
    For a worktop I'd say check your local pound/dollar store for two-part resin. My local pound shop (in the UK) does a two-part resin in what looks like two syringes stuck together. You cut the tips off and squeeze out an equal amount of each side. Mix, pour, let it set, and it goes rock solid and clear.
    atomickitties
    Question 6 months ago on Step 8
    Have you ever tried this on a cement paver? If so, what kind of finish would you apply to enable one to walk on it and how long should it dry before doing so? Thanks!! This is great!
    wla26atomickitties
    Answer 6 months ago
    hello for protect your artwork use epoxy resin
    brynn.delorimierwla26
    Reply 6 months ago
    Agree epoxy resin is the way to go (see my own comment) but that turns a relatively cheap project into a $$$$$ project; that stuff ain't cheap, especially if you're covering large surfaces. depending on the paver and how deep its grooves run you'd probably get a very different effect. I'd opt for the smoothest-surface paver, personally, or maybe a thicker mixture... perhaps the OP will have some thoughts on that. Even if it yellows a bit from sun exposure over time you can sand down and re-do the top layer. Tho to get the same look on concrete pavers , polishing and doing an acid wash would probably serve you better. If you Google image search polished concrete you get mundane results to start, but keep scrolling for some awesome & creative & colorful floors just like this style. I had some in my last place and loved them. We're also doing a strange alleyway walkway leading to our backyard patio using the polished concrete acid wash style, with seaglass in-between squares, uplit with LED lights from beneath. Also a Big Experimental Thing. :)
    ronnietuckeratomickitties
    Answer 6 months ago
    I haven't tried it on cement, but as long as it's relatively level then it should work. Acrylic is basically plastic paint so when dry you could walk on it OK, but would wear it out. I'd have to think you'd need to use some sort of varnish to make it hard wearing.
    Auroris
    6 months ago
    Such a beautiful technique. Thanks for step by step instructable.
    The best help when your painting is in crisis))
    Gadisha
    6 months ago
    Fun technique to incorporate into my pathetic paintings (like painter like paintings I guess) ;)
    But seriously, I'd like to try this.
    gcai_fwb
    6 months ago
    this looks like fun - will have to try with my nieces :)
    4
    cryogenius
    6 months ago
    I do this on wood or MDF (medium density fiberboard), and instead of using gesso I just start with a coat of latex house paint and let it dry. Also, I use a heat gun instead of the butane torch - I have a torch but the electric heat gun is more convenient and seems to be just as effective. The Golden Rule you state is right on. I have a good success rate, but my failures are generally from moving the paint around too much after the pour.
    ronnietuckercryogenius
    Reply 6 months ago
    I love that one. That's some nice colours!
    My failures result in either:
    * some colours rising/sinking causing it to look different when it's dry, from when it was wet.
    * I choose crap colours and it looks crap.
    AlyStrick
    6 months ago
    Good instructions. It is fun and addictive to make these!. Thank you for sharing.
    ps... we see your clear gloves you sissy, you! ;)
    ronnietuckerAlyStrick
    Reply 6 months ago
    In my defence: I was juggling paint and my phone (camera) at the same time. Hence, the sissy glove. :)
    AlyStrick
    Tip 6 months ago on Step 7
    ...better to wait at least a couple of weeks, preferably three, before varnishing to ensure that paint is completely dry so that the varnish won't change the painting. I've had it happen, but I live in a humid area.
    Ninzerbean
    6 months ago
    I loved reading your comments and sound effects on the photos. Very funny and well done!
    seamster
    6 months ago
    I like this! It seems like a great, fun way to make a funky item to hang on the wall. Thank you!
