Add Bluetooth to A/V Receiver Amplifier Within 3 Minutes
54,094
230
33
This is a very simple upgrade that you can do to any amplifier that does not have Bluetooth built in. In my case I will be adding Bluetooth to my Home A/V receiver amplifier. It only takes about 3 minutes and is completely removable should you decide to change your setup in the future.
Supplies:
Step 1: Parts List
1. USB Bluetooth receiver ($3 to $10 Ebay or Amazon (I recommend getting one that has V4.1+EDR its gonna give you better sound quality)
2. USB Charger ($1) Ebay or Amazon
3. RCA to 3.5 mm audio cable ($2) Ebay or Amazon
4. Audio Video stereo receiver amplifier ( or any amplifier with RCA input )
Step 2: Making Connections
Start by finding a unused RCA input on the back of the A/V receiver that you could use for Bluetooth. If all are being used it is possible to use the auxiliary input on the front of the unit, however you will likely need a different cable for that. I choose the CD to use as my Bluetooth input and plugged the RCA cable into it and on the other side connected it to the USB Bluetooth adapter. Next plug the USB Bluetooth adapter into the USB charger and plug it into an outlet. Its a good idea to plug the A/V receiver and USB charger into the same switched surge strip so you can flip power on or off to both at the same time.
Step 3: Pairing
All that's left is the pairing of the Bluetooth adapter with with any streaming device that you prefer. I used my cell phone which happens to be android but even with apple devices the setup is about the same. Simply go into your phone settings and turn on Bluetooth and it will automatically scan for any Bluetooth devices within range. (Bluetooth has a range of around 30 feet) The Model of the Bluetooth adapter should show up under available devices. (mine showed up as EC502) Once your device finds it just click on it and it should move to paired devices and also say connected next to it. If your A/V receiver is on you will hear a pairing sound from the speakers which means your have successfully paired your device to the A/V receiver. Congratulations your all done! enjoy your tunes via Bluetooth on that A/V receiver amplifier.
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    33 Discussions
    pcchimp
    Question 9 months ago on Step 1
    Hi I have a denon avr X1200. I connected to rca in behind the avr. USB Bluetooth to the front to power. Phone is connecting with Bluetooth when I play song on iPhone I can select the Bluetooth device but no sound is coming from my denon speakers. Is there something I’m doing wrong?
    1 answer
    Imran687pcchimp
    Reply 9 months ago
    Just make sure you have the right input selected on the denon ,, for example if the Bluetooth is plugged into aux 1 input
    Make sure it is selected as the input you are using on the denon and it should work ,, other then that make sure volume is up on your cell phone ,, and enjoy
    NeillJ1
    2 years ago
    "I choose the CD to use as my Bluetooth input and plugged the RCA cable
    into it and on the other side connected it to the USB Bluetooth adapter" How to do this?? I have a bluetooth adapter but I've never seen one with a 3.5mm input. Did I miss something???
    Imran687NeillJ1
    Reply 2 years ago
    you have to use a Bluetooth audio receiver module and that will have a 3.5mm jack on it .. there are hundreds to choose from on eBay and Amazon
    redrooster
    2 years ago
    I have a Sansui AU-11000 amplifier built in 1974/75. You would spend thousands of dollars now days to get the same quality of sound.The 1970s and 80s are considered the golden age of sound.Its when they made amplifiers to last.Checkout AudioKarma.org or DIYAudio.com to restore these Museum peices.
    ScottH76redrooster
    Reply 2 years ago
    oh yeah. good ole Sansui. I had friends that came back from Viet Nam with them. They were great. so were the speakers. Side note: they would pack the boxes with "candy" from Nam and Thailand. It was very tasty! :-)
    Imran687redrooster
    Reply 2 years ago
    totally agree with you on that rooster .. they certainly don't make them like they used to.
    redroosterImran687
    Reply 2 years ago
    Thats for sure! I asked for a service manual for a Digitech amplifier I was checking out in an electronics store a while ago. They said they dont have service manuals anymore? If that doesnt say built in obsolesence I dont know what does? I refuse to buy anything that doesnt have a service manual anymore because it would invairiably be plastic junk that fails just after the warranty runs out. lol
    that canadian guyredrooster
    Reply 2 years ago
    I picked up an '87 Nakamichi Stasis SR-4a receiver a few years ago for $125 and it's definitely a favourite of mine, compared to my Denon and Onkyo home theatre receivers. I set up my bluetooth exactly the same as this 'ible and it works great when I want to listen to some "current" music that I don't have on vinyl. Or if I'm too lazy to get up and flip my LP's.
    huntinark16
    2 years ago
    If I had known it was this easy, I would've had Bluetooth long ago. I'm going to Ebay right now to order my parts. Thank you very much, Imran687!
    Imran687huntinark16
    Reply 2 years ago
    Your Welcome and parts are very cheap thanks to eBay!
    Arrowanaguy
    2 years ago
    So the rca plugs into the back of the radio (we can see that), but where does the audio jack end of the rca plugs to? The Bluetooth device? (Thanks)
    Imran687Arrowanaguy
    Reply 2 years ago
    yes the other end (3.5mm plug) goes into the 3.5mm jack on the Bluetooth adapter
    FedeP1
    2 years ago
    Does it work pairing it with windows? more specifically win10.
    Imran687FedeP1
    Reply 2 years ago
    should work as long as your device has a Bluetooth..tablets, smart phones.
    xaenon
    2 years ago
    I did something similar to give new life to an old Magnavox console stereo. I can listen to MP3s and internet radio on something that was built decades before either of those things was even conceived, and it sounds wonderful.
    rafununuxaenon
    Reply 2 years ago
    Are you living in a museum ?
    xaenonrafununu
    Reply 2 years ago
    Some might say I am a museum piece myself. Bear in mind that not everything 'old' is 'junk'. You might be amazed at how good those old consoles sounded, particularly the 'big' names like Magnavox, Zenith, RCA, Motorola, Grundig. These were the premium sound systems of their day, often costing the equivalent of two or even three thousand dollars in today's prices, and it's remarkable how well they hold up. They're elegant and stylish (okay, 'stylish' is subjective, but still) and built like tanks.
    This particular unit belonged to my father, who purchased it new in 1967 or 1968, and sprung for the optional 8-track player as well. I know, records, eight tracks, all obsolete. But that's the beauty of it. It can still play those old things, AND now it can play streaming audio and MP3s too. Museum piece? Maybe. But a WORKING museum piece. My daughter is fascinated by the record player. And another generation learns of Frank Sinatra...
    EnderOxaenon
    Reply 2 years ago
    Xaenon, I congratulate you for a very nice reply to an arrogant Yuppie.
    ....and for a nice project, too.
