Adjustable Power Outlet
53,015
419
57
About: My name is Jason Poel Smith. In my free time, I am an Inventor, Maker, Hacker, Tinker, and all around Mad Genius
There are a lot of electrical devices that only have two settings: ON and OFF. For a many of these, it would be helpful if you could adjust the output with an external circuit.
So in this project, I am going to show you how to make an adjustable power outlet. This circuit acts as an external dimmer and can be used to adjust the power on a variety of appliances such as Lamps, heaters, soldering irons, and hot glue guns.
Safety Note:
The circuit used in this project is designed for simple resistive loads such as heating elements and lights. It is not suitable for inductive loads such as motors or fans. These generally require a different kind of control circuit. Also it should not be used with devices that use AC power adapters or devices that have their own built-in control circuits. These may not function properly when connected to a dimmer.
Step 1: Materials
Here are the materials and tools that you will need for this project:
Materials:
3 Prong Power Cord
Insulated Plastic Housing
Light Dimmer Circuit
15A Outlet
Insulated Twist-On Connectors
Black and White Large Gauge Wire (optional)
Tools:
Wire Strippers
Screw Driver
Knife or Rotary Cutting Tool
Drill
Step 2: Background: How a Dimmer Circuit Works
The AC electricity from an outlet is basically a sine wave. Most modern dimming circuits work by chopping off part of the sine wave. Above is a simple schematic of this kind of dimmer circuit. These circuits use a semiconductor called a TRIAC. A TRIAC conducts electricity only after the voltage at the gate pin has reached a certain threshold. It is often combined with a DIAC to increase this threshold voltage. The DIAC/TRIAC is connected to a resistor and a capacitor. The resistor sets how quickly the capacitor reaches the threshold voltage. By adjusting the resistor, you determine how much of the sine wave gets chopped off.
At the first part of each cycle, the TRIAC is off. The capacitor begins to charge through the variable resistor. When the voltage of the capacitor is high enough the DIAC/TRIAC is activated and it conducts electricity to the lamp. This process happens at the first of both the positive and negative parts of the sine wave.
Step 3: Purchase or Built a Dimmer Circuit
You can purchase a lamp dimmer at most hardware stores for a few dollars. There are a variety of types available. The most common type is a dimmer light switch. This is typically mounted to a wall in place of a standard light switch.
The type that I am using in this project is a "500 Watt Torchier Lamp Dimmer." It is normally used to retrofit a regular lamp to add the dimming feature.
If you would rather build a dimming circuit from scratch, you can find a number of designs online. Here is one example:
Materials:
White and Black Wire
Power Switch
500Kohm Variable Resistor
10Kohm resistor
33ohm Resistor
0.047 µF Capacitor
DIAC
TRIAC (BTA16-600BRG)
Step 4: Cut Holes in the Plastic Housing for Each Component
Open up your plastic housing and decide on the best locations for the dimmer circuit and the outlet. On mine, I decided to mount the outlet to the top surface and dimmer circuit to the front side. This left a convenient place to put the power cord on the left end.
First, you need to mark an outline of the front faces of the outlet. You can do this by holding the outlet upside down on top of the housing and tracing it. You could also use an outlet cover plate to mark the appropriate outlines. Then using a sharp knife or a rotary cutting tool, cut out the two outlines. Then drill a hole between them for the mounting screw. After cutting these holes, mount the outlet in place and secure it with the screw.
Once the outlet is in place, you need to mount the dimmer. Hold it up to the side of the housing and mark where the knob will be located. At this point, drill a hole in the side of the housing that is just bigger than the threads on the dimmer. Then insert the knob of the dimmer and secure it in place with the washer and nut.
On the left side, I drilled a hole that was just bigger than the power cord. Then I inserted the power cord through the hole.
Step 5: Connect the Dimmer to the Power Cord and Outlet
Before you connect anything, it is important to first identify all the wires. The dimmer and the outlet need to be connected in a certain configuration. The color coding system for electrical wires varies from country to country. In the United States, white wires are "neutral", black wires are "hot" and green/bare wires are "ground."
If the wires are not color coded, then it may still be possible to identify them from the prongs on the plug or the texture of the insulation. "Neutral" wires are typically connected to the wide prong on the plug and have ridges on the side of the insulation. "Hot" wires are typically connected to the narrow prong on the plug and have insulation with a sooth side.
After identifying the wires, you are ready to connect all the components. Insert the power cord through the hole in the side of the housing. If you want to make the power cord a little more secure, you can apply glue or a zip tie around it at the wall of the housing. This will help to prevent it from being pulled out and breaking the connections.
Connect the "ground" wire (green or bare wire) from the power cord to the nut on the end of the outlet. Then connect the white wire to the slot on the outlet that is labeled for white wires. Connect the black wire from the power cord to the black input wire on the dimmer. Then connect the black output wire from the dimmer to the slot on the outlet that is labeled for black wires.
If the wires need to be solid in order to be inserted into the outlet, then you may need to add a few small pieces of solid core wires. Connect the solid core wire to the outlet. Then connect them to the corresponding wires with insulated twist-on connectors. After making all the connections, close up the housing. Your adjustable power outlet is complete.
Step 6: Use Your Adjustable Power Outlet
There are a lot of potential applications for an adjustable power outlet.
The simplest application is as an external dimmer for lamps. This can let you adjust the brightness of any incandescent light (and some LED lights). This can make interesting effects with novelty lamps such as lava lamps.
This outlet can adjust the output of any appliance that uses a simple resistive heating element. Examples of this include: soldering irons, hot glue guns, hot wire foam cutters, crock pots, counter top grills and some coffee pots.
As noted in step one, this outlet is not designed to work with inductive loads such as motors or devices that use AC power adapters or devices that have their own built-in control circuits.
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    57 Discussions
    rommac100
    3 years ago
    I think there is an error where you said 33ohm capacitor.
    Yardster
    5 years ago on Introduction
    I'm interested in finding a way to reuse a broken iron as a hotplate for cold smoking meat. The issue is that my husband thinks a dimmer switch isn't appropriate for use with the iron. the iron is reduced to the sole plate with, presumably, an electrical heating coil running through it, and electrical connectors. When intact, it draws 1100 amps, but normal dimmers are rated for less. What are my options? Are there any recommendations for a variable power switch for this use …that cost less than a used iron (my alternative cost).
    Yes, it's missing the temperature controller. That was how it was broken in the first place. I've stripped it down to the sole plate and terminals. It might be cheaper to just go out and buy a used iron at a thrift store if I can't figure out a way to control the power to this one. I thought this would be a cool way to upcycle junk.
    Well, you have two options. You can either find a controller that can handle 1100 watts or you can reduce the wattage of the iron.
    One controller that you might be able to find is a 1100 watt microwave. The power settings will let you adjust the output at various duty cycles.
    To reduce the wattage of the iron, you could wire it in series with another circuit. This will increase its effective resistance and lower the wattage. For instance, putting two irons in series will double the resistance and cut the wattage in half.
    My purpose is to make a hotplate for bringing wood chips to the smoking point, I should find out what the combustion temperature would be. I just thought that the highest setting on my iron can burn my cottons, so it seemed a good bet. Perhaps a second iron in series would be possible, they're easy to find in thrift stores. One drawback with an intact iron is all the plastic housing and the fact that the controller is on the iron and would be difficult to reach while in a (meat) smoker.
    DIY Hacks and How TosALKN
    Reply 5 years ago
    Actually. I work for Make. I am the one that made the project and the video for them. They encourage me to promote our work my submitting it to other websites such as Instructables.
    LesB
    This is the type of fan I used:
    http://www.newark.com/ebm-papst/3606/axial-fan-92mm-115vac/dp/86K9826
    Shaded pole AC fan. Maybe in theory it wouldn't work, but in this real world instance...
    Well, what part of "it worked" do you not understand.
    nerd7473
    5 years ago
    could you add another hot and run it to a switch and make it adjustable at 240v?
    Treknologynerd7473
    Reply 5 years ago on Introduction
    Apart from "No", all the answers on this thread alarm me. If you have 220/240VAC in your home, use the appropriate components to make your dimmer for that voltage. If you think you are going to "create" a 220V outlet by linking two 110V outlets you should not be working with mains electricity.
    tonemeister69nerd7473
    In order to make a 220v outlet out of (2) 110 outlets, you would have to take the hot wire from 2 separate 110 circuits, which usually aren't ran to the same side of the house. I found this out when I was trying to make a 110 to 220 extension cord so I could use my 220v welder all around the house. I hope this is helpful. :-)
