Adjustable Rope Mat Weaving Loom
53,023
492
21
I wanted to make a rope mat so i googled how to make one. There were plenty of templates to draw to show where the rope cross and such, and using nails on a board to hold it in place while you get it started.  I decided to make a peg board loom that would allow for making different sizes of mats with various numbers of Leads and Bights.  The pegs are glued in place on the left and top side. The bottom and right side are left open to allow for free placement of the pegs to set the desired size.
Here is the main link I looked at to figure out how this works and gave me the inspiration for the peg board.
Supplies:
Step 1: Draw the Grid
I used a 2x4 foot piece of pegboard for this project.
Using a sharpie I drew a diamond grid that teh rope will follow while creating a mat.
In order to fit larger size rope as well as small I made the diamond grid 3 holes on each side.
I drew a border around the outside to remind myself to leave room for screws and such.
Step 2: Draw the Cross Overs
Draw thick rectangles at alternating 45 degree angles at each cross section of the diamond grid.
This shows where the rope will either cross over itself or under itself as the weave is created.
Step 3: Mark Moveable Peg Lines
When creating smaller sized mats the moveable pegs will be placed along the lines as shown in respect to the fixed pegs.
Step 4: Board Backing.
Use a solid piece of board for the backing to keep pegs from falling through, use some of the outside holes to bolt on the backing board.
Step 5: Glue the Pegs
I made the pegs by cutting 1/4" dowel rods into 32 - 2" pegs.
16 of those pegs will be glued and 16 will be loose.
Glue the pegs on the left and top side at the apex of each diamond.
The other 16 pegs can be stored in the holes along the top when not in use.
Thats pretty much it for the loom. You are now ready to start playing.
Step 6: Testing Your Size
Not all combinations af Bights to Leads will work. Sometime the rope will come back around to the start without rounding all of the pegs.  I suppose you could make it work in all case if you did not follow the gris lines, I haven't tries that yet. :-)
In this pic you can see a quick set up for a 4 Bight by 6 Lead Mat.
Step 7: Creating Your Mat
I decided to  go for the biggest size first... I used 100' of 1/4" glow in the dark rope. (Because if you can use glow in the dark rope, why wouldn't you?) :-)
I started at one corner and followed the gridlines all the way around until I got back to the start, making sure to go over or under the line as the board was showing.
Once I got a complete path i looped the rope around for a second pass.
By the time I got the second pass run I was out of rope. It is at this time that you can remove the loose pegs, lift the ends off of the fixed pegs and start to tighten the mat.
As the mat gets tighter there will be more rope at the end to work with and weave your third pass, forth pass, and so on depending on how much rope you have and how big you want our mat.  From reading on line generally 3-5 passes is good for most mats.
Once you are satisfied with your mat run the ends underneath and secure them together. You can do this by melting them, glueing them, taping them, or sewing them with an awl.
Thats about it... This is my first rope mat... now I can play around a lot easier with ideas since the pegs are so easy to use!
Enjoy!!
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    21 Discussions
    hohum
    2 years ago
    THIS MAT IS JUST COOL, a suggestion for you, instead of calling the incorrect loop in the corner a mistake, consider calling it a 'chop' or a signature, a way that you 'sign' your work. maybe the next mat, add something specifically to the corner to 'sign' your work.. -extra loops- your very good at this, you'll figure something out, such that when people see your mats, they will know that kevgrn114 made this mat..
    kevgrn114hohum
    Reply 1 year ago
    Thanks!! to a bad idea.. :-)
    ecardinal
    5 years ago on Introduction
    Very nice! I have a thick dowel (a section of staircase handrail) with headless nails for doing turk's head knots, but you have given me some great ideas for improving it. Thanks!
    Jayefuu
    Oh this is perfect! I was just thinking about making a rope mat, I made one before with a retired rope I had but the prospect of doing it again was daunting. This makes it look much easier!
    kevgrn114Jayefuu
    Reply 5 years ago on Introduction
    Thanks, It is much easier with this board. The initial first pass layout is the hard part which is what this helps with most. Everything else is following the first pass and tightening it up.
    This is so fancy! I'd love to know the finished size too! Would this work on a larger scale? Or would it make more sense to make a bunch this size and attach them together?
    Thank you! This finished size is 8"x18" . The finished size depends on the size of rope you use, and how many passes you make.
    Jayefuukevgrn114
    What diameter was the glow in the dark rope you used? I have a 50 mm long 8 mm thick climbing rope that can't be used for climbing anymore.
    kevgrn114Jayefuu
    The glow in the dark rope is 1/4" The nice thing about this board is you can scale it down to work with almost any length of rope you have. At the very least you could make a coaster. :-)
    A lot of people are using old climbing rope for these types of projects.
    Alderin
    Very cool! Makes me think I might be able to make my logo into a jewelry piece.
    The 'tightening' process is what stopped me before, metal isn't quite as forgiving of being worked around corners as is rope. :-)
    arghcAlderin
    If you're anywhere near where he's touring, try to sign up for a class with Loren Damewood (http://www.golden-knots.com/). If you're not anywhere near, you can order a DVD and a jig. He is mostly about tying knots in precious metal wire. I highly recommend his classes and your logo looks like it would be fairly straightforward to do...
    GracieLea
    This would make a great, durable rug for my front porch on a little larger scale! Can't wait to try it! Thanks for the instructions and pics!
    kevgrn114GracieLea
    It looks like if you use 1/2" line with 4 passes and do the full board you will get a pretty big mat. 3 passes should be about a welcome mat size.
    crazyndhed03
    Great idea! I have tried some of the Turks Head knots, and failed miserably (mostly trying to tie them in hand). This great because it keeps you on track visually too.
    kevgrn114
    This is the next one I did, 4 bight by 6 lead using 1/2" rope, 4 passes. About 15x8"
    This thing certainly makes it easy to get going!
