Advent Calendar Banner Garland
723
9
About: I enjoy making things. My making them is usually based on necessity, the fact that it doesn't exist, and/or buying it pre-done would be way more expensive. I like all kinds of projects and find this site a v...
This is a fun and easy to make advent calendar that can be filled with larger objects and can be customized to your liking.
Step 1: Materials
Ribbon (8 - 12 ft)
Paper holiday treat bags
Scissors
Hole Punch
Tape
Black Marker
Candy, toys, small packaged foods, beauty product samples or any small gift items.
Step 2: Cut the Bags in Half
The bottoms of the bags will be used to hold bigger items. The top remnants will be sealed with tape on one end to create fillable packets.
Step 3: Number the Bags and Packets
Using the marker , number the bags and packets with opening towards the top. I alternated between bag and packet to give the garland uniformity and balance. I was making two garlands, so I swapped the packets to give it a little more pattern.
Alternate version:
Turn the packet and number as a diamond instead of a square.
Step 4: Fill the Bags and Packets
Pretty simple. The tops do not have top sealed with tape, but you can, if you like.
For the alternate version, make sure to seal the tops of the packets, so nothing falls out.
Step 5: Punch Holes and String on Ribbon
Punch the holes at the sides, where there is extra paper and it is reinforced.
Alternate version: Punch the top of the diamond.
String on ribbon in order. Space to your liking and leave excess ribbon at the ends, if so desired.
Step 6: Hang and Enjoy!
Count down to Christmas!!
    • Warm and Fuzzy Contest
    • Paper Contest
      Paper Contest
    • Organization Contest
