All in One Work Bench
132,113
1,107
71
Built this workbench to maximize my work area in the garage. I wanted lots of tool storage with power built in and a table saw outfeed table. It had to be movable
Step 1: Start With Lumber and a Sketch
I started with a trip to the big orange store.15-2x4
2-4x4
4-1x2 pine strips
2 sheets of cabinet grade 3/4
3" wood screws
Epoxy paint and primer
Wood stain.
I then drew a sketch of what I wanted
Step 2: Practice Your Joints.
I took some scrap wood and practiced the joints I wanted to you. I used half laps so I set my sliding compound saw to the depth I needed and made lots of cuts next to each other
Step 3: Start Cutting Wood
Start cutting your frame work. Make sure you test each joint as you go
Lots of cutting here
Step 4: Assemble
Assemble all the framing components. Make sure everything is square
I used wood glue and 3 inch wood screws here
Step 5: Add Casters
I added caster to make it easier to move around
Step 6: Cleaned Up Joints and Add Power
Next I cleaned up the joints using wood filler and added electrical boxes under the table. I worked the 4 electrical boxes together then wire a cut off extension cord to the last box to plug into the wall.
Step 7: Prime Bench and Stain Top
Next I primed the bench with kills primer and stained the top of the bench.
Step 8: Put in the Sun to Dry
Drying.....
Step 9: Paint
I wanted a strong finish so I used a oil based epoxy paint. 3 coats
Step 10: Add Lower Shelfing
For this is used 2x6 lumber. I cut it all to fit them removed and stained it before screwing it down with pocket holes from the bottom
Step 11: Make Edge Trim
I made edge trim to hide the plywood edges. I but to size, mite red the corners and stained them. I used pocket screws to attach them
Step 12: Lower Shelf
Made the lower shelf the same way, cut, stained , edge trim, then pocket hole to attach
Step 13: Finish With Polyurethane to Protect Finish
Used 3 coats of polyurethane to protect the top surface
Step 14: Load It Up With Tools
Got all my stuff put on it
Wood Contest 2016
Second Prize in the
Wood Contest 2016
Maker Olympics Contest 2016
Third Prize in the
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
71 Discussions
handydave937
4 weeks ago
Great project, I was poking around for ideas and you set me in the right direction. I used those same casters on 2 other projects and I really like them. 2 thumbs up.
AdamH145
10 months ago
I took your design and used what I had to make a similar table. Used 2x6's to make the table as that what I had. It's a beefy table! Now to finish the top.
NeedjahAdamH145
Reply 7 months ago
What are the dimensions of your bench AdamH145? Looks good
Needjah
7 months ago
GREAT bench, but not really an "Instructable"
cb77305
1 year ago
I just finished a potting bench for my wife - nowhere the workmanship that obviously went into this beautiful project. I used nothing but scrap - mostly 2 x 4s - collected over the years, so it looks rough but is square in all the right places - thanks to me DeWalt chopsaw.
KevD44
1 year ago
how long is this? I need half the upper table size
PremaL4
2 years ago
Good design and it is very easy for new woodworkers, and I used different type of plans for my customer, and one of the woodworking forum I download few different plans and I used for my customer and they like it, If anyone looking for different woodworking plans contact at ( lutherking1912@gmail.com )
I can share my plans
attawudh
2 years ago
So strong with usefull
AndrewW197
2 years ago
Well-bethought project, and beautifully executed. Thank you for posting!
JpsManCave
2 years ago
Looks good. Not a big fan of the table saw part cantilevering like that. im sure it is more than fine just little personal preference on my part. how long you think the finish on the top will last?
JetMechanicJpsManCave
Reply 2 years ago
Look at the mass of the rest of the table. Then consider that the center
of the mass over that cantilevered section is only about 12"
from the closest support point, and you'll realize that your concerns
are unnecessary.
nickd561JpsManCave
Reply 2 years ago
You could always place wheels under the table saw but I haven't had a issue yet. The poly should last a few years. You can always sand it with 220 and add another coat to make it look new again
JpsManCavenickd561
Reply 2 years ago
im sure you wont ever have a problem it looks very stout. I was just wondering about the top. me and a buddy are looking into building close to the same thing but have been looking at using Melamine for the top
freementia
2 years ago
I have a tendency to lean on my workbench and i'm afraid that, even with locking casters, the bench will still move when I don't want it to. Do you see any movement when the casters are locked? I was thinking i'd use something like these. (Inspired by the movable stairs at Home Depot)
charlessenf-gm
Reply 2 years ago
The three wheels approach demands a stabilizing mechanism that allows the two legs at the third wheel to be supported. This could be accomplished with a couple of support legs such as used on boat trailers and such where you crank them down to bear the weight once the trailer is disconnected from the towing vehicle. About $20 from Harbor Freight Tools when on sale with a 20%-off coupon!
Note, some of this come with rather large wheels - so you could use one of them for the 3rd wheel and simply retract it when the bench was in the new place and stick a shim under the 'short leg.'
ewsmith
2 years ago
Beautiful bench, great build. How easily does it roll? Do you find yourself moving it around or is it too heavy fully loaded?
Separately, how solid is it once it is in place and the wheels are locked? I see you have other benches but for my space I need to mount a vice and I do a lot of hammering and such. I'm considering a detachable pod I can roll up and clamp tight and flush with the top yet sits on the ground. Other than messing up your great surface, do you see any need for such a thing with your build?
P.S. I do not believe there is any surface within 100 yards of my garage where 6 wheels could touch the ground at one time..
ynnebewsmith
Reply 2 years ago
I wonder if you could attempt a 3 wheel bench to ensure all 3 contact and a more stable surface. Just use the two wheels at the cutting end. (BTW his is 4 wheels)
ewsmithynneb
Reply 2 years ago
Interesting idea on the 3 wheels. I use a 100 year old barn for my garage and I prefer to work outside whenever I can, so I'm thinking I'll need adjustable legs anyway. Still not sure how large I can go and still have it be practical due to weight. Maybe my 3rd wheel should be a motorized dolly ; ).
Yes, I was referring to someone else's comment that it might need 6 wheels (he said it doesn't, thankfully).
PaulB329ewsmith
Reply 2 years ago
maybe three wheels with simple mounts and a fourth one with some up and down adjustability. That way you have support under all the corners.
