Altoids Tin Mini Garden
55,940
422
71
About: I like to play with electronics and other fun stuff, modify things to make them more useful or just more funny, putting things together that seem not to fit to make funny stuff. Sharing ideas make the world ...
You dont have an own garden, but like to live in a green environment? Why dont you make an Altoids Tin Mini Garden for your desktop? Use an empty Altoids tin. Put in a piece of tissue, add garden cress seeds and water and wait 3 days. Dont forget to keep your seeds wet.
Supplies:
Share Your Garden Photo Contest
Third Prize in the
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    71 Discussions
    mischkaThe Locksmith
    Cool, thanks for sharing! Please post pictures when something grows. Which herbs do you grow there?
    mischkaCoral May
    Reply 3 years ago
    unfortunally it does. You can use foil or similar to prevent it from rust.
    DiyGal123
    3 years ago
    Very good idea. Wooh im gonna need more tins!
    ilikecake3
    5 years ago
    Oh, I have been keeping mine wet by spraying it. I grow wheatgrass for juice, and you don't need to replant it
    ilikecake3
    5 years ago
    How did you keep them wet? With a spray bottle?
    Jacky P
    6 years ago on Introduction
    I think you have a great idea. Have you considered growing mint I. The mint tin?
    Cooldude638JKPieGuy
    I am in the process of growing grass in one of my tins, and if you decide to, this is my advise to you: Water it frequently.
    Aira.vj
    How much sunlight do these need? My apartment has almost no sunlight (basement flat). I've had a small cactus survive for a year so far, but it hasn't grown any bigger or flowered.
    The LocksmithAira.vj
    Make a tiny usb grow light like I did! Just solder an led to the red and black wires on a usb cable, and mount it in a small hole in the lid of the tin. Prop the lid at a 45 degree angle with a toothpick.
    askjerryThe Locksmith
    Most LEDs are 2.1 to 2.3 volts... the USB port is usually 5 volts. Unless you use a 5 volt LED, you will likely need a 150 ohm resistor to keep from burning out the LED.
    Jerry
    oandersonaskjerry
    You don't really need a resistor, from experience, my desk is covered with old USB stuff, some working, some not. But 5 volts is fine for a normal LED!
    -Oscar
    The Locksmithaskjerry
    Good observation! I used an LED capable of handling the voltage without a resistor, but most LEDs can't. Thanks for warning people, I forgot to put that in there myself :)
    There is another way... if you have two LEDs that are each rated 2.1 volts... and you connect them in SERIES... then the combined voltage is 4.2 volts which likely is close enough... but you could install a 40 ohm resistor if in doubt. (Presuming they are 20mA as most are.)
    (Supply - LED Voltage) / current = resistor needed.
    So (5v - 2.2v) = 2.8v... and if the datasheet said 20mA (0.020 amps)
    2.8v / 0.20A = 140 ohms... I rounded it up to 150 in my example.
    Hope that helps.
    Jerry
