Amazing, Cheap & Easy, Cracked Gems & Marbles. for Fantasy & Crafts.
8,686
165
61
About: I am just a person who loves doing crazy and fun things... I always love to try to innovate when I can, and share any new discoveries I find... That is why I have recently started recording my shenanigans ...
Hello, In this video I am going to show you how to make absolutely stunning Cracked Gems and Marbles for Fantasy Props like for Dungeons and Dragons. Or crafts like Necklaces or Rings. These also can make great Vase fillers, or pseudo gems for kids games so long as they are old enough to play with them safely.
Above, below the video is a few photos that you will show you my results from the method I demonstrate in the video. Thank you for watching!!
If you don't wish to watch the video which I do recommend to get the best explanation and demonstration of this method possible, please continue through the next few pages for a written explanation.
Step 1: Materials and Pre Heating.
What you'll need:
-Transparent Marbles or other Roundish Transparant glass like Vase Gems.
-An Oven.
-Cool water.
-Ice (Optional.)
-Salt (Optional.)
-Heat resistant gloves (Recommended.)
-Or Tweezers/Tongs that the hot Glass can be safely picked up with, and dropped into the cool water.
Hello all It is of course me TrollFaceTheMan, and today I am going to show you how to turn ordinary marbles or Flat Glass Rounds also called Glass Gems into extraordinary mock Precocious Stones. For crafts or otherwise.
This process is extremely simple and will just require some Transparent Glass Marbles or Glass Gems along with a Bowl of Ice Cold Water, and an oven. Heat resistant gloves such as Welders gloves or the humble oven mitt will be a good Idea too, but if you don't have that In the least you'll need some tweezers or tongs to grab the hot Glass.
Basically step 1 is we are going to preheat our over between 250-500f or 121-260c, as a forewarning there is a serious risk of burns here if done unsafely. So any kids that might be reading please do this with a Parent or Guardians supervision.
When it is heated up we can add our Marbles or Flat Glass Rounds into the oven in a heat safe dish. And let them Bake for about 30 minutes.
Step 2: Readying the Bath
While they are cooking you can get a large bowl and fill it with cold water, Ice is a good idea but not 100% necessary for this. But you want to definitely have about 5x the volume of water than the amount of glass you are cooking to ensure it the water stays cool when you put the marbles in it.
If you do add ice, adding a few spoonfuls of salt will help melt the ice and make the bath even cooler, and basically the cooler it gets the better it'll work. Cooking at higher temperatures will also produce better results.
Once the 30 minutes are up, and the cold bath ready we can finally progress, which will be adding the Glass to the Cold bath. But before we do I want to give a warning, there is an extremely small chance that the Glass may pop when in contact with the water. Because of this I recommend safety glasses during this step. I've so far done about 200 of these though and had no issues.
Step 3: Quenching the Marbles
If you have Heat Resistant gloves you may be able to just take the dish of marbles and poor them directly into the Cold Water. Be careful, though they help a lot, most gloves will only give you maybe 10-15 seconds before they start getting too hot to hold at 500F or 260c.
After dropping it in the water let the glass sit in the dish for about 1 minute, by then they should be cool enough to handle and you can pick them up and appreciate the fractures you have generated.
This is a very cool way to turn basic marbles into something more interesting. I'll show you the Gems in a second as they turn out pretty cool too.
But before that if you do not have Heat Resistant Gloves, it's quite simple to still do this, although tedious. You can use tongs or tweezers to transfer the hot marbles one or a few at a time to the cold water. Be extremely careful not to drop them on yourself or your floor as they will burn stuff.
Here is a few shots so you can see the reaction as it's put into the water. Basically what we are doing is exploiting a phenomenon called Thermal Shock, when we put the glass into the oven and heated it, it expanded slightly but because it was done over a long period of time it expanded evenly and thereby stayed intact.
However when we chill it by forcing it into the ice bath the outside of the glass cools rapidly and contracts inward while the center of the glass remains expanded. The amount of pressure the contracting outer layer of glass exerts on the expanded inner layer causes the inner layer to fracture due to extreme stress.
This results in an amazingly unblemished outer layer of marble, yet a comply shattered inner layer.
Step 4: Quenching the Gems
Let's try the glass gems now, It's the same process. And you can see they turn out quite stunning too, maybe even better than the marbles. Now the reason this actually works is because of the semi rounded structure of the marbles and glass gems allow for all the pressure to be pulled inward much like a Ruphert's Drop. If however they were not rounded, then they most likely would just break into pieces on contact with the water.
You can see a few pictures I grabbed and how stunning these can actually look. Now another warning I wish to give is a lot of those colored glass gems are not actually colored glass but a plastic layer on the glass. This of course will not work as it'll burn during the heating process.
You can test this by carefully scratching the surface with a knife and seeing if there is any plastic on it, or breaking a bead in half and seeing if the inside is transparent. The plastic coated ones tends to not feel so cold to the touch either.
Many people use these for faux gems in makeshift jewelry, such as earnings or especially necklaces. Or other crafts. And they really can be quite stunning.
One of my personal applications for this though is going to be stand in physical gems for Dungeons and Dragons games I Dungeon Master for or possibly other table top games.
Step 5: Epilogue
Well anyways guys, thank you for reading this Instructable. And if you haven't already, please watch the video on the main page to see even more cool shots I took of some of the awesome gems I made. And if you like it please hit the Like button, It means a lot to me. Also please share this with at least one other person you know if you would. You guys sharing helps this channel grow.
And drop me a comment if you have any questions or would like to just say hi, I appreciate it! And lastly thank you to my awesome Patreons who's support helped buy the supplies for this project, you guys are awesome.
And if any of you out there are interested in also supporting and getting access to certain videos early and credits after main vids here is a link to my page:
https://www.patreon.com/TrollFaceTheMan
Thanks again for watching. And... Bye!!
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    61 Discussions
    nc_notary
    1 year ago
    Great idea! Gonna try this asap! I call Jalapeños, Ju-lap-e-noes, Burritos are Burro-toes, Muffins are Moofins. I crack myself up even if no one else thinks I'm funny.
    Jane Ward
    1 year ago
    Cool, we are so going to try this
    jeanniel1
    1 year ago
    Faux = pronounced, "foe" - those bad spelling French!
    itsmescotty
    1 year ago
    This was a reminder of a time in my adolescen quest for knowledge when people couldn't answer my questions
    Seem to remember using a propane torch and one marble at a time - results weren't always as pretty as yours and catastrophic at times. That torch was an amazing 'teacher' in my younger years!
    TrollFaceTheManitsmescotty
    Reply 1 year ago
    I was curious as to what a torch might do also. Wonder how the Leidenfrost effect might affect cooling?
    dsegel
    1 year ago
    Cool trick.... But did you say "fox" gems? Faux is a French word, pronounced like "foe".
    TrollFaceTheMandsegel
    Reply 1 year ago
    You are correct on this and though I knew this at the time of recording it slipped my mind.
    I have a habit that I typically pronounce words exactly as they are spelled Like Home Depot or Jalapeno because It tends to bug other people and I find it slightly humorous when they try and correct me thinking that I actually think it is the Home De*Pot, Jal*la*pen*o or such.
    For This though I genuinely just didn't even think about it during recording.
    Not going to lie, I know it is wrong but I do like the sound of the improper pronunciation more XD
    srilykdsegel
    Reply 1 year ago
    I was going to say the same thing :D
    jvandeyacht
    1 year ago
    Omg, people... first off, it is not the writers responsibility to give safety lessons. The isles would be stupid long because there are a lot of dumb people out there.
    How many 10 year olds are doing stuff from ibles without a parent supervision? If your kid does something dumb and gets hurt it is your fault as a parent, NOT THE WRITERS.
    I do horrifically dangerous stuff all the time. I know my limits and my tools. I have videos of making spiral wood legs using a dado tablesaw with out a fence or any safety items including gloves. I wear eye pro only and I cut from the back side of the saw.
    That breaks every rule there is, I share how I do it. This is a learning site where people can showcase their creations and how they made their items.
    This is not a place to cover every safety concern there is.
    Should you ‘choose’ to try my technique, it is your responsibility to know your tools, your responsibility to know your limits and your responsibility to choose what safety equipment you feel that you need.
    If you get hurt doing my technique then it is all on YOU, not me. I don’t care what you use, I’m only showing how I did it.
    Lay off the writers with all of your safety ass comments and appreciate the writers kick butt awesome idea and thank them for the time spent putting this ible together to share with your unappreciative ass.
    Damn, it’s people like you safety hawks who make these cool guys say screw it, if I’m going to get blasted by dumb people, I just won’t share and then this site dies.
    If you don’t like how the writer does it, move on, if you haven’t contributed- shut your pie hole up.
    TrollFaceTheMan .. your the man. This is pretty cool. I’ve done this before but in a much more scary way. It’s fun to make the ‘jewels’ for pirate treasure.
    Thank you for sharing, and ignore these stupid fools with this safety and blowing up crap, I’ve used torches to heat mine one at a time and never had one blow up either, only splatter some water if I didn’t drop them in fast enough.
    TrollFaceTheManjvandeyacht
    Reply 1 year ago
    Jvandeyacht thank you, I am glad you liked the Instructable, and I do appreciate your support. But in all fairness it has only been the one individual that has been making a big deal about anything.
    And honestly I don't mind someone saying "Hey, I think it'd be a good idea to focus a bit more on safety in your videos if you can." What I don't like is people acting very pretentious and condescending about it which I feel has occurred in this situation.
    Anyways thank you again, and if you don't mind liking the video and favoriting the Instructable I'd appreciate it :)
    snowf7
    1 year ago
    Hi TrollFaceTheMan; When moving the marbles quickly from the heat to the ice bath, a kitchen frying spider might help. It is a stainless steel bowl shaped strainer or slotted spoon on a long handle.
    ncdave4life
    1 year ago
    Re: "...a warning, there is an extremely small chance that the Glass may pop when in contact with the water. Because of this I recommend safety glasses during this step."
    "Recommend" is too weak. The hazard is not "extremely small." The risk is substantial, and safety glasses are essential. You should NEVER attempt this process without them!
