Amazing Fire Domino - 3000 Matches Chain Reaction!!!!!!
30,919
73
29
https://youtu.be/JrI2jPc3Yf4
Supplies:
Step 1: To Do a Amazing Fire Domino You Need!!!
Today I show you how to make Amazing Fire Domino - 3000 Matches Chain Reaction!!!
I used a wood board, double-sided tape and 3000 matches.
Step 2: This Is My First Experiment to Do Amazing Fire Domino From Matches, It's Very Cool!!!!!
Step 3: It Took Over 3 Hours to Build and 40 Seconds to Destroy!
Step 4: Please Enjoy Artistic Fire Chain Reaction a 3000 Matches.
Good Luck!!!!!!!!!!!!!!
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    29 Discussions
    MiltReynolds
    3 years ago
    A-mazing and mesmerizing. Excellent videography, great choice of soundtrack. Enjoyed it. Well done!
    Gorilla22
    3 years ago
    At first I thought, "This would be way too much work for what it does." Then I saw the video and my whole life was changed...Thank you for sharing. I appreciate all the time you put into this.
    deswiger
    3 years ago
    Of course you know you're playing with fire here............ (TeeeeHeeHeee), yea, pretty cool.
    kayakdiver
    3 years ago
    I think I might have spray shelaqued (sp?) the thing after it cooled down to preserve the "art" it created. Very 'cool'.
    tkjtkj
    3 years ago
    Hey folks! It's called 'ART' , video art , quite beautiful; and art exists for it's own self so we are thankful when we can experience it's beauty.
    Thanks, Morena!!
    TeresaM7tkjtkj
    Reply 3 years ago
    Here, here, tkjtkj! I would definitely do this! It was quite a lovely display to watch.
    KookaiC
    3 years ago
    KJV John 8:7 misquote "Let who that is without the urge to play with fire among you to try and cast the first match"
    Let's up the ante a bit. Spend tons of time building a picture using different color match sticks AND then set fire.
    Cheryl MB
    3 years ago
    Wow! That was almost an art installation! Thank you for that it was mesmerising.
    voorkomen
    3 years ago
    it shows wood having strength on fire
    ms match
    3 years ago
    it took 3 hrs to set up and using a clay base is faster..
    buzzclick
    3 years ago
    Nice. The ones in the outside perimeter burned first since they had access to more oxygen.
    Close up, it looks like the heads of people getting scorchified. :)
    jpharrington
    Reply 3 years ago
    Those would likely be the same people that ignore the warnings on fireworks. Why do it? Because it can be done.
    If this helps someone learn about fire in a way that they may not have had options, then it has done the job it needed to.
    knowlson
    3 years ago
    This seems more of a de-structable than an in-structable :-D
    Great Idea! Nice video!
    Wonder how a spiral would look......
    Jack Rodgers
    3 years ago
    Ah, fire. So mesmerizing.
    Brought to mind what I did and probably many others in my youth. Take the tin foil from a pack of cigarettes or other source. Wrap it around the match and leave an exhaust tube at the end. Now light the match. ROCKET POWER>>>
    I wonder what would happen if you did the same with this idea. Solid booster rocket. Maybe achieve orbit rather than a few feet. Or maybe out it inside a long tube with the match heads at the bottom and then light them through a small hole at the bottom of the tube. Like you can see in movies of ancient cannons in the warships.
    Put a chicken inside and video launching the chicken. Or a pumpkin like the shows where they Chunk the Pumpkin.
    OK, its early AM and I am energetic and wired on coffee...
