Amazing Keychain (with a Bike Chain)
12,276
265
15
About: Electronic+Mechanical Engineering Student at National University of Colombia. Bike Mechanic and Cyclist
Hi! and welcome to my first Instructable.
Searching on internet about bicycle parts I found this keychain in https://www.bikerumor.com/2014/06/06/kickstarter-... the comments on the page made me think ... why not do it yourself?
Tools and Materials
  1. Keys
  2. Bike Chain
  3. Chain Rivet Tool
  4. Pressure/Locking Plier
  5. Cutting Tool (Mototool with carbide disk or Jewerly Saw)
  6. Drill with 7/16" Metal drill bit
  7. Abrasive Paper
Warning: this lifehack is not advisable if the key is subjected to a high torque in the lock
Supplies:
Step 1: First, a Little Explanation
The chain is composed of several parts: Outer plates, Inner Plates, Rivets, Rollers. Generally, the chain has a space between rivet and rivet of 1/2 "and depending on the use can vary the width of it. For bicycles with a single speed the roller is wider than a chain for multiple speeds.
For this tutorial, the goal is to replace the rollers with the keys.
Step 2: Organize the Materials
First, dissasembly the chain preventing the rivet from leaving one of the outer plates and separate the parts, select the keys to build the keychain, Keep in mind that the number of keys it's as the number of rollers.
The chain that I used I took the last change of chain of my bicycle, a KMC X10SL chain
Step 3: The First Hole
For precaution, the top of the key is retained and a 7/16 "hole is opened in the center of the key, with a file the hole is adjusted so that the inner plates fit very well. With the help of inner plate the edges are marked
Step 4: Cut the Keys
With the help of a mototool cuts are made to the key, you can also use a jewelry saw or a soft saw.
Step 5: Finish the "rivet"
Using the same mototool, or using jewelery files, the edges of the new rivet are polished so that their size is not greater than the edge of the outer plate. Using abrasive paper softens the edges
Step 6: Keychain Assembly
This part should be done with care, it is sought to reassemble the chain using the keys instead of the rivets, a way to do it quickly is with the help of a clamp of pressure, taking care that the rivet does not deform the outer plate. With the help of the chain tool you can adjust the rivet so that the key can move in the chain
Step 7: Test the Keychain
If the lock is in good condition, and the assembly has been correctly made, the chain will perfectly withstand the torque of the key. To increase this resistance can be used a thicker chain (this one is 5.6mm, 10 speeds) or fix the key in the chain by tightening the outer plates. When the assembly is not performed correctly or when the lock requires additional effort the chain does not resist and disarms
Step 8: ¿Optimize the Keychain?
Performing the instructable I thought, how close can you leave the chain in the key? Then note that the chain edge can serve as a stop for the key. (As the photos show)
Step 9: Same Steps, in to the Limit
To make the same key at the limit of its length, the key is marked with a straight line (marking the stop of the key) and the outer plate is placed as a reference and the same perforation and the same cuts are made as described from step 3
Step 10: Finish and Test the 2nd Version
There is an advantage when making the key this way, as it is much easier to assemble and occupy less space.
As shown in the second image, the chain serves as the limit for the key to fit correctly
Unusual Uses Challenge 2017
Runner Up in the
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    15 Discussions
    isa_k
    1 year ago
    I love the concept... but I worry about the integrity of the key's strength after being reduced so much... can you vouch for the strength of the keys after reducing it so much and after using it for at least a few months continuously?
    Again, great concept! Doubly great if the keys survive as long as a normal unadulterated version is it does as well.
    Dafedicoisa_k
    Reply 1 year ago
    Hi! If the lock is
    in good condition, and it does not take much force to operate it, the
    bronze with which the key is made can withstand that normal deal, now,
    if the force is excessive, it is more likely to disarm the chain (the rivet release the outerplates) to damage the key
    That's why I warned you at the beginning
    Mortimer Wisa_k
    Reply 1 year ago
    Well keys are essentially just specifically shaped pieces of metal, so as long as you don't cut the key any narrower than its connection to the tab, it should hold together. Because, the tab of a key doesn't offer much strength to the key, it's just for the convenience of the user.
    lbrewer42
    1 year ago
    This is a great idea for just a few keys. I really like it, and I like the looks of it. But I used to have a ring of 10 or so. I can imagine how long that would be.
    CJ_ADAM
    1 year ago
    Very cool. Voted.
    deluges
    1 year ago
    Very nice, thanks for sharing. I'll make one soon
    You got my vote!
    Jedi_zombie85
    1 year ago
    brilliant and very creative nice work
    papashanty
    1 year ago
    oooohhhh i want to do this!
    mrsmerwin
    1 year ago
    I love this. Very clever!
    Swansong
    1 year ago
    That's an awesome keychain! My nephew would love this :)
