Android Phone Control RGB Strip
5,632
161
5
About: A programer, maker, painter.        FB : https://www.facebook.com/dan59314       Linkedin: https://goo.gl/avBXpR
Videos
RGB Strip
Moon
Andord App
More than 7 control Modes
Constant Color / Random / Rambo / RGB / Blink / User-Define Play sequences / Breathing…..
More Free Tools download
http://www.rasvector.url.tw/hot_91270.html
Supplies:
Step 1: Parts List and Schematics
USB to TTL X1 Connect PC and Pro-Mini for uploading code /
PC control ProMini
Arduino ProMini X1 Control RGB Led in different shining modes
HC-05 Bluetooth X1 Receive command from Android Phone via Bluetooth.
RGB Com-Cathode X1 Indicating RGB light state.
RGB Strip 5050 5M X1 RGB LED strip, 12V, Common Anode.
Resistor X3 220 Ohm.
NPN Mosfet X3 TIP41C NPN, TO220
Power Supply 12V-5A X1 Offer the power to RGB Strip and Arduino Promini.
Step 2: Arduino Source Code
Arduino Source Code
https://www.dropbox.com/s/4tpu4yjltiqeakg/BlueToot...
BlueTooth Test
PWM PIN 3, 5, 6, 9, 10, 11
Daniel Lu : dan59314@gmail.com
http://www.youtube.com/dan59314/playlists
1. D,3,255 ->  Set D3 = 255
2. A,1 ->  Read A3 value
3. C,255,255,255 ->  set R,G,B value to PinR,PinG,PinB
4, M,1  set PlayMode, cListerning, cAuto, cRandom, cRambo ....
5. P,3,5,6 ->   set PinR=3, PinG=5, PinB=6
6. TD,200 -> gDelayMsc = 200 msec
7. TI,30000 -> gIdleMsec = 30000 msec
8. RS/RE -> start/end recording
#include
//#define HardwareDelay;
#define CommonAnode
//#define debug;
#define enableBreath
// Type Define ***********************************************************************************
typedef struct TPinRec {
byte PinNo;
Step 3: All Downloads
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    5 Discussions
    bikecDaniel Lu
    Reply 3 years ago
    I have made it,but it lights up all color and then turn off, then back on.
    Please help
    Daniel Lubikec
    Reply 2 years ago
    Did you solve the problem. Send me your schematic, check if I can get it corrected.
    Daniel Lubikec
    Reply 3 years ago
    The default mode is "Breathing". you need to download the android app, change the mode with app. Watch the video will helps.
    praveenkumar2000
    3 years ago
    can we use this without bluetooth via otg cable cable using serial. If yes please send me the code to my mail
    kumar.bols@gmail.com
    including app.
