Anti-Skid Chair Feet From Recycled Inner Tube
3,801
83
15
About: I MAKE in my sleep. I MAKE for keeps. I MAKE I MAKE I MAKE creative me.
We have beautiful hardwood floors in our house and I want to be sure they stay scratch free for years to come. I knew there was a reason why I saved my old Inner Tubes, I'm not crazy after all. I'm going to make protective feet for our furniture to prevent future scuffs.
Tools Needed:
  • Scissors
  • Pen
  • Glue
Items Needed:
  • Bicycle Inner Tube
  • Chair
Time Needed:
  • About a half hour
Skill Needed:
  • Beginner - this a pretty easy fix.
Supplies:
Step 1: Cutting and Gluing the Inner Tube
  1. Find the offending piece(s) of furniture you wish to protect. I am using a stool as my example.
  2. Cut a section of Inner Tube that will cover all 4 feet.
  3. Place the stool over the Inner Tube on the ground.
  4. Using a pen, trace around the stool leg. Be efficient, we have a ton more uses for the remaining Inner Tube.
  5. Cut your pattern, just inside of your pen mark, using your scissors.
  6. Flip your stool over and place your pieces on the feet making sure each one fits to your specifications.
  7. Trim as needed.
  8. Glue each piece of Inner Tube to each stool foot. I used E-6000 glue in this step.
  9. Flip the stool over onto a solid surface. You may want to set it on paper towel pieces just in case there is the possibility of glue seeping out. The idea here is to protect your flooring. Haha.
  10. Place a heavy object on the stool top to help the glue adhere to the legs.
  11. Let sit for at least an hour for the glue to set.
There you go, easy Non-Skid, No-Scratch feet for your furniture. It's that easy.
After completing this project, I thought, how cool would it be to use an actual bicycle tire for this project? I'll leave that project for another day. Check back, I may do that in the future.
Spring Cleaning Challenge
Runner Up in the
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    15 Discussions
    moen-the-grass
    3 years ago
    Get to your area bike shop ask for punctured inner tubes or tires, these shops will be recycling them, &may give them to you free. Lots of uses
    tinaciousz
    4 years ago on Introduction
    I like this for the Spring Cleaning Challenge... Avoid those scuffs on hardwood. You should enter! www.instructables.com/contest/springcleaningchallenge/
    Tater Zoidtinaciousz
    Reply 4 years ago on Introduction
    Hi tinaciousz, I entered as you prompted and am now a finalist in the Spring Cleaning contest. Thank you for urging me.
    AnnaLA
    3 years ago on Introduction
    Hi there, just wondering if this would leave black scuff marks on the floors if used on chairs or barstools. We use felt pads right now, but have to redo about every 2 years with wear and tear.
    tinkglobally
    Nice!
    If anybody is worried about getting marker on the table legs, trace them to paper first, then use that template to cut out all your feet
    Coincidentally, I just applied these to a friend's table & chairs a couple weeks ago. It seems you were posting your 'ible while I was making the same thing - great minds, and what-not. Glad you thought to post, as they really do help with scuffs, and in our case, keep the chairs from sliding too much on tiles
    I used contact cement to adhere them, which seems to be working well (a thin coat on the rubber and separately on the leg bottom, left to dry for 15min before pressing them together, ensures that no goop smushes out the side onto the floors you're trying to protect)
    tomatoskins
    As I was reading I was thinking to myself, "why not use the actual tire?" then you addressed that. Thanks for sharing!
    Tater Zoidtomatoskins
    I do think using the actual bicycle tire would be much cooler but I don't have one laying around. I think I'll hit up my local bike shop and see if they have one or more, I have several chairs that still need "feet". Thank you for your comment.
