Apple Bandsaw Box
769
14
8
About: I love working with wood. I make bandsaw boxes and just lately ive got a lathe and now enjoy woodturning.
Hi and welcome to my latest instructable. I have added the video for you to view should you not be clear on any of my instructions, and also this shows the process in a lot more detail that can be put into written instructions.
Well lets get to it :-)
I used
Wood to fit template i used 3 inch deep and the back of the box is around an inch thick.
Bandsaw 1/8 inch blade for cutting out box and 1/4 / 1/2 inch blade for cutting back and front of boxes.
1/4 inch wood for tree on the front
Sandpaper 120 - 600 grit
Glue
Fimo clay or similar for handles.
Clay tools
Template (google free bandsaw box template)
Spray lacquer.
Step 1:
Gather the wood you need and glue your template onto the front. I recommend covering the template with clear tape as later you will need to remove the tree shape.
Step 2:
Now we are ready to start cutting the box out.
First cut around the outside of the box.
Next cut outer band of the box.
lastly cut each of the boxes, take your time and if you want more information on this check out the video.
Step 3:
Now we are going to cut the backs and fronts from the boxes.
I free hand draw a line around 1/2 an inch from front of the box and around 1/4 inch for the back of the box. I then cut front and back off on bandsaw.
With the front and back of box out of the way i mark the inner box ready to cut this is also done on the bandsaw.
The drawers are now ready to be glued.
Step 4:
Once ive glued the drawers im ready to start sanding them i mainly use a drum sander which i put in my pillar drill.
I then peel the paper from the tree on the front of the box and cut the branches and stick onto the 1/4 thick wood ready to cut on bandsaw.
Once cut, i sand all pieces and get them ready to clue them to the front of the box.
Step 5:
Now its time to glue the back on the box.
Glue the tree on the front. (make sure the tree shape fits perfect and does not overlap or the drawers wont go in and out without catching) i used a dremel to sand these parts
Sand everything to 400/600 and use 2 coats of sand sealer sanding 400 between coats.
Lastly i use spray lacquer to finish.
Step 6:
Now lastly lets make the handles.
Roll out the the red clay into a ball.
Using a pointed plastic clay tool push in a short way see photos or video.
Roll a thin sting like bit with brown clay, cut and place in hole to look like stork of apple.
Using the green clay roll to a thin layer and cut a diamond shape.
Shape to look like a leaf and make marks like a leaf vain before placing on the apple.
Bake as instructions on your packet.
Once cool use 2 part epoxy to glue onto the draw.
Step 7:
All done.
I hope you enjoyed.
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    8 Discussions
    baergnat
    1 year ago
    For what it's worth, this design is copied from one of my parent's original designs. Martha and Phil Baerreis (my folks) have been making a living with their original designs since 1972. People have been copying their work since they started, but I thought it'd be nice to offer some credit to them. I'll add a couple of images of their original pieces so you can see the similarity. You can find their work at www.gallery26.org (that's our family's gallery- we're all artists).
    Please note: I'm not saying this specific author intentionally copied our design- he may have gotten the design elsewhere and we 100% support the movement of "people making things." I'm happy that folks like it enough to copy it, but I would encourage any woodworker to endeavor to create something new, rather than repeating someone else's design. Also, we call this the "Mythic Tree."
    baergnatbaergnat
    Reply 1 year ago
    Edit: SHE may have got the design elsewhere. I reread it and saw that she googled "free bandsaw box template" so clearly someone else took it first.
    Highlandboxes.baergnat
    Reply 1 year ago
    As said this was a free image from google and lumberjocks.
    baergnatHighlandboxes.
    Reply 1 year ago
    I see that, and as I said the design is my parents', and no one was ever given permission to copy it, they just took it. We've been making that style box since the 90s. It is their original design. I don't blame you for using it but I'm sad to see yet another one of their designs being used with zero attribution. Looks like you do nice work though!
    Denver395
    1 year ago
    Very nice design. The clever part that is unique, the handles they are not only different but they fit the tree design very nicely. When making band saw cabinets, another nifty touch is to flock the inside of the drawers. Flocking comes in a variety of colors and you can also mix the dust to create your own approach to the flocking technique. To make the tree a different color, one technique is to place a thin layer of a different color on the bottom of the block so that, when you cut out the tree shape, an identical tree will be cut at the same time. It uses more wood but saves time and the tree would be in one piece. I do like the many pieces, it creates a warm and fuzzy feel to the entire project. Well done. Keep up the good work.
    Member of NWWT (North West Wood Turning, Portland Oregon, USA)
    PetrN18
    1 year ago
    Moc mi líbí, hezké. :-)
    nwaskow
    1 year ago
    Really neat design! I'd really like to give one of these a try myself.
    simplewriter
    1 year ago
    I really like your design! Do you sell these on etsy? I'm sure you'd have buyers.
