Apple Crate Coffee Table
30,912
876
39
About: Why buy when you can DIY? Educated a Mechanical Engineer and trained as a classical cellist I consider myself a bit of a jack-of-all-trades, dabbling in projects from machine design to cooking, ice hockey to...
An apple crate coffee table is a quick and easy, you can finish in a day or two tops, project that can add a lot of character to any room as well as being a good way to up-cycle unused crates. Don't worry though, you can buy crates at a lot of different stores if you don't have any laying around. It's also a very effective storage space, allowing you to fill almost the entire footprint twice, inside and on top.
This is a project my wife saw somewhere and wanted to do. To be honest she did most of the work while I really just helped out, putting it together for the most part, and documented.
Supplies:
Step 1: Materials & Tools
Materials
  • 4x Apple Boxes - If you can upcycle actual apple crates that's a plus but they are also available from most craft/fabric stores.
  • Wood Screws - The necessary size depends on the thickness of the wood in the crates and the actual construction of the crates.
  • Wood Filler
  • Primer - We went with a distressed sort of look so the primer color was important as it shows through.
  • Paint - A semi gloss or glossier paint is recommended as it aids in keeping the table clean.
  • Wood Blocks (Optional) - Depending on the furniture around where the table will be placed you may choose to attach feet to put the table top at a more usable height.
Tools
  • Sandpaper
  • Drill
  • Countersink Bit
  • Paint Brush (Optional) - Used to apply the paint in a non uniform manner for stylistic reasons. Also necessary if you aren't using spray paint.
Step 2: Prep
The first step is to decide on a layout for your table. There are a few ways you can arrange the crates, a couple of which I've drawn above.The layout you'll see in this guide is is the square with the open center. You could also easily make a bigger table with more than four crates.
Before you start building the table it's best to do some fit checks so the table is as level and square as possible. The crates won't be perfect but by taking some time to try various combinations of position and orientation you can minimize these errors and get a mostly flat and square table. Just keep trying the boxes in different positions until you find how they best fit together.
Step 3: Assemble
With the crates configured and fitted, assembly is a simple matter of choosing your hole locations (3-4), punching them (not critical but it helps in tight areas), drilling pilot holes, and driving in the screws. You should try to drive the screw heads just below the surface. The best way to do this is to use a countersink bit on each hole after you've drilled the pilot. If you Don't have a countersink bit you can use the tip of a large drill bit with similar effect.
When you're done putting in all the screws use a wood filler to cover the screw heads and make the holes flush. As per the fillers instructions allow it to dry and then sand it before painting.
Step 4: Paint
When the filler is dried and prepped it's time to paint. My wife wanted a, for lack of a better word, distressed look, where the top layer of paint is sort of worn away exposing what's underneath (the primer, raw wood, another paint color, etc). From what I gather a typical method for doing this is to paint the top layer as usual and then wear it away through various methods, sandpaper, etc. Instead of that method she applied the primer as usual and then hand painted the top coat with a foam brush. This allowed her to get texture in some spots and control the thickness and coverage.
Step 5: Conclusion
There really isn't a lot to say. It looks good and is more functional than our previous table, as it has more 1st order retrievability storage space. There is a lot of ways you can customize this project, from the layout to decorating it, so don't let the way we chose to do it shoehorn you onto a single path. Look at your space and be creative. As always feel free to ask any questions and post pictures if you tackle this project!
Organization Contest
Runner Up in the
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    39 Discussions
    lgraciano1
    2 years ago
    I would love to have the sizes of the boxes, I´m from Brazil so we don´t have the same crates!! I´m planning to built one for my mother!! If you could send me measurement of the crates I would make a happy mom!!!
    bwrusselllgraciano1
    Reply 2 years ago
    I sold the table when we moved but the link below is to the exact crates I used and it shows the dimensions and other info on them. Really though as long as all four are the same they can be whatever size fits your needs and room best!
    http://www.joann.com/wood-crate/8160715.html#close
    bwrusselllgraciano1
    Reply 2 years ago
    Also, if/when you make one be sure to post a comment with a picture!
    SBBLESS
    3 years ago
    Thanks for sharing, I really like this coffee table. My problem is where can I get the apple crates around Joburg?
    patsheldon
    5 years ago on Introduction
    I like the simplistic look but it still does its job. I also liked how you can cut the labor down by not sanding but using a foam brush. ;)
    docmurray
    5 years ago
    gonna give this a shot before I head to Texas, give it to my parents.
    valkgurl
    I saw these crates---or very similar---at WalMart this weekend (1-24-14) for about $8 and change (USD) Didn't get to check the "quality" but at that price you could re-do your whole house storage wise with these.
    IF you add castors tho re-inforce with real wood blocks. And plexiglass on the top would be nice---sold at Lowes and can be cut with fine edged jig saw or similar IF you TAPE the area to be cut. Might be in 'ible on that here somewheres if not on Pinterest. OR Lowes can cut it for you for a small fee.
    bwrussellvalkgurl
    Reply 5 years ago on Introduction
    That's a good price and I'm guessing the quality matches that of the ones at most craft stores.
    Yep, I learned that the hard way on one of my other Instructables.
    Preval
    This is great! We've added it to our collection, "spray paint." Cheers :)
    pmeador
    I just made one of these and stained it with steel wool in vinegar (gorgeous dark aged wood look) and sealed with beeswax and olive oil (no fumes and looks great!). I put mine on a base with casters as well....love mine!
    bwrussellpmeador
    That's great! You should definietely post a pic or two, I'd love to see how it turned out.
    teethlikelions
    5 years ago
    I would also suggest possible considering a spill barrier under the top. a spilled drink will quickly ruin a compartment full of books/games/controllers.
    That is something to consider, haven't had that issue personally yet. Wood sheets on the underside of each compartment or across the entire top would work but kind of ruin the aesthetic. The best solution would be a sheet of glass except the cost could be prohibitive.
