Arduino All-in-One Getting Started Guide
148,560
312
68
About: Maker Coordinator for Maker Faire: NC Life is short: Void the warranty!
An all-in-one tutorial to getting started with the Arduino open-source electronics prototyping platform. This guide is meant for the beginner but should be also be useful to you if you already tinker with electronics but want to get started with the Arduino. I'll cover:
- breadboarding LED outputs from the Arduino
- creating and reading digital inputs to the Arduino
- how to program the Arduino to take the input and act on it to modify the outputs
Our demonstration project will consist of a set of three blinking LED's that blink in sequence. You'll control the speed of the blinks via a pushbutton controller. I've designed this project to be modular in nature: we can create a fairly complex effect, but I've wired and coded everything in a modular fashion to make it easier to follow. Of course, that means that neither the circuits nor the code are necessarily the most efficient way of doing things -- but the emphasis here is on making it clear and understandable.
Acknowledgement: I'd like to thank Lady Ada for her excellent set of tutorials on the Arduino which is where I first learned Arduino basics. I cover a lot of the same ground, but her work has a very different flavor and emphasis including a different set of circuits and programs. I recommend that you pay her tutorials a visit. You can also buy Arduino boards and an wide variety of shields and accessories for the Arduino from her company, Adafruit Industries.
Here's how the finished project behaves:
Step 1: Testing Your Board / Getting Started
If you have already connected an Arduino to your computer and run the basic "blink" example you can skip this step. However, if all you've done is unbox it, here's how to start:
1) Download the software you'll need from the makers: Software Download.
2) Install the software and connect your Arduino to your computer via a USB cable. It draws power directly from the USB port, so you don't need to connect a power supply to it at this point.
3) If you have a newer board you'll see a resistor next to pin 13 and an LED next to that. That LED works just as if it were connected between pin 13 and the ground (GND) pin next to it. If the LED is NOT on your board, just connect an LED between 13 and GND. You don't need to do anything else since a resistor is already built in and limits the current through the LED so you don't put your board at risk of a short circuit. NOTE: This resistor may not be present on really old boards (I just don't know), but I doubt you have one of those.
4) Set your board type and serial port under "Tools" in the software kit. The current version (at the time of writing) does not have an option for the newest Duemilanove boards, but choosing Diecimila works just fine.
5) Open the blink example from the software kit: It's under File | Sketchbook | Examples | Digital. The onboard LED (or the one you added) should blink on and off after you upload the Blink "sketch" (as Arduino projects are called) to the board (File | Upload).
When you write programs for your Arduino, you will normally do much of your debugging in the software development kit by doing a Verify/Compile before uploading, but since we just uploading a pre-built test sketch I skipped that here.
Step 2: Wiring the Blinky Lights
I've broken the circuit down in such a way that we will be wiring up our output (the blinky lights) completely separately from our input (the pushbutton switch). Makes it easier to understand if you're just starting out.
First, a note and word of caution. Newer Arduino boards have an LED right on the board itself or at least a resistor connected to pin 13 so that you can stick an LED right between pin 13 and ground (GND).
This is NOT true for the other pins! If you connect LED's or other circuits on other pins you must be certain to protect your board from excessive currents or full-out short circuits. You can fry your Arduino!
Personally, I recommend that you always use a resistor when experimenting. You don't want to accidentally short to ground, so at least connect a low value resistor to the ground pin. Better safe than sorry.
In this circuit we are using pins 11,12 and 13 as digital outputs (5V) to power the LED's. The negative post of each LED connects across a single shared resistor and then to ground. In my circuit I'm using a 150 ohm resistor (it was just a convenient grab from my parts bin). You can use other values here -- just don't go too extreme so that you don't either (a) keep the LED from lighting or (b) push too much current through your Arduino.
If you run the Arduino "blink" sketch from step one you should now notice that one of your LED's is blinking. If not, you should check back over your wiring and components. A diagram for this very simple circuit is below.
Step 3: Wiring the Pushbutton Switch
To keep things modular, the pushbutton switch also connects to your Arduino, but it's a very separate circuit.
Note that the little pushbutton switches commonly available have four legs. The pins on each side are permanently connected to one another, so the button actually makes a single connection between the two sides. If you're in doubt as to which posts are which, just check it with your multimeter.
In the circuit diagram you're going to notice that we are using two resistors. Again, the exact values aren't really important, but the relative values are. If you aren't familiar with the concept of pull-up/pull-down resistors, please take a minute to really understand this circuit. If you don't, you will likely get flaky results in future projects or -- worse yet -- burn out your Arduino.
When the switch is OPEN, the circuit is simply a connection from the digital input (pin 2 in our case) to ground through a couple of resistors. Since we are connected to ground the value at pin 2 is LOW (approximately zero volts). If we were connected only to the switch the value would be whatever noise the wires were picking up. Maybe it would be close enough to zero to work, but maybe not. We need that ground connection to make sure our reading is right.
When the switch is CLOSED, the 5V source is connected to ground across our 15k resistor. The 150 ohm resistor is negligible by comparison, so it has a minimal effect on the voltage our input pin is reading (5V) and the digital input is HIGH (~5V). The 150 ohm resistor keeps us from creating a short between the power source and the pin so that we don't damage the Arduino.
Again, the exact values of these resistors are not important. Just make sure R1 is MUCH bigger than R2 and that R2 is big enough to limit the current back to the board. My values were simply plucked from my parts bin.
Clarification: The resistor is a pull-DOWN resistor because it connects the digital input to ground. A pull-UP resistor would pull the normal (no button pressed) state of the input to 5V.
Step 4: Programming the Project
Now that we have completed wiring up our project it is time to write some code. I'm including all the code below, but will talk about the theory a little first.
The code I've provided compiles to 1560 bytes in size. The Arduino handles programs up to 14336 bytes in size. This little project takes up over 10% of the Arduino's capacity, but this is REALLY not optimal code. It's a tutorial, so I've tried to be clear rather than efficient. I wouldn't be at all surprised to find it could be rewritten in half the space or less.
Every Arduino "sketch" has two mandatory areas: setup and loop. Setup executes ONCE after the program starts. This allows you to configure the initial state of the board: which pins are inputs, which are outputs, and whether outputs start off HIGH or LOW. The loop is the section of the program executived repeatedly as soon as setup has completed. There is no "end" or "exit" to an Arduino program -- there is nowhere to exit to! If you have experience programming, you'll immediately recognize the language used to program the Arduino is our good old buddy C. If not, you can pick up the basics just by going over my code and the other examples in the development kit. Many great C tutorials are also available on the web.
You can copy and paste the code into your Arduino development environment, then verify and upload it. If everything is right you should get blinky lights and be able to vary the speed by pressing the button.
Now a section-by-section breakdown of the sketch:
1) First we start by defining some variables. Much of this area is for human comprehension and could be skipped for the sake of efficiency. For example, I've defined a variable called "ledPinRed" and set it equal to 13 (I used three colors of LEDs -- the red one is connected to digital pin 13). I could have used "13" directly throughout the program, but that makes it much harder to comprehend. The comments next to the variables note what each is for.
2) Setup. Here I've set the pin to which the pushbutton is attached as an input pin. The Arduino will be looking to receive information (HIGH or LOW signals) there. I've set the LED connections to be outputs where the board will set the voltage as HIGH or LOW (5V or 0V) as appropriate. Finally, I turned on my green LED and made sure the others were turned OFF.
3) getButton: a function (just a container for code for any non-programmers reading this) that can be called from the main loop to find out if we've pressed the button. It keeps track of the current state of the button AND the previous state of the button the last time we looked at it. This allows us to respond only to individual button presses: holding down the button only counts as ONE press. This is important when the lights are changing very rapidly lest it be very tough to control.
4) changeLights: another function. This one gets called whenever we need to move from one LED to the next. The one that's on gets turned off and the next one in sequence gets turned on. It also updates the "currentLED" variable so we can keep track of which LED is currently active.
5) loop: The main loop. Here we first make a call to check on the button. If we find the button wasn't being pressed but now it is, we add to the "currentSpeed" variable. If we're going really fast, we reset currentSpeed back to 1 -- looping around so we can go back to slow speeds. After that...
...well, then we hit an ugly line that determines if it is time to change to the next LED. millis() is a built-in Arduino function that keeps track of how long the board has been running the current program. All we're doing here is finding out if enough time has gone by that we should change to the next light. If so, we call the "changeLights" function to make it happen.
Finally, here is the code (warning: it loses a little formatting when posted here, so it's not as pretty as it could be):
  • Kevin's Arduino Tutorial
// Note that these variables are all GLOBAL in scope, so they'll work inside our function calls
int ledPinRed = 13; // Set up digital outputs for LEDs
int ledPinYellow = 12;
int ledPinGreen = 11;
int switchPin = 2; // Set up to read the switch state from digital input 2
int currentLED = 1; //Green = 1, Yellow = 2, Red = 3
int currentSpeed = 1; // Determines how fast we switch between lights.
int buttonWas = 0; // The state of the switch (pushed = 1, not pushed = 0) last time we looked
int buttonIs = 0; // Current state of the switch
unsigned long timer = 0; // A timer to keep track of where we are.
void setup() // Runs once, when the program ("sketch") starts
pinMode(switchPin, INPUT); // Tells the Arduino to treat the switchPin as INPUT
pinMode(ledPinRed, OUTPUT); // Tells the Arduino that the Red LED pin is for OUTPUT
pinMode(ledPinYellow, OUTPUT);
pinMode(ledPinGreen, OUTPUT);
digitalWrite(ledPinGreen, HIGH); // Green LED is ON at start
digitalWrite(ledPinRed, LOW); // Red LED is OFF at start
digitalWrite(ledPinYellow, LOW); // Yellow LED is OFF at start
void getButton() { // Let's see what the button is doing, shall we?
buttonWas = buttonIs; // Set the old state of the button to be the current state since we're creating a new current state.
buttonIs = digitalRead(switchPin); // Read the button state
void changeLights() { // Turn OFF the currently lit LED and turn ON the next one.
timer=millis(); // reset our timer to the current time
if(currentLED==1) {
digitalWrite(ledPinGreen, LOW);
digitalWrite(ledPinYellow, HIGH);
if(currentLED==2) {
digitalWrite(ledPinRed, HIGH);
if(currentLED==3) {
currentLED++; // Add one to currentLED
if (currentLED==4) { currentLED=1; }
void loop() // This is our "main" loop. Arduino programs don't exit -- nowhere to exit TO!
getButton();
if((buttonIs==1)&&(buttonWas==0)) {
currentSpeed++; // Add one to the current delay because the button was pressed.
if(currentSpeed==15) { currentSpeed = 1; } // Loop around -- this sets us back to a slow rotation.
if (millis()>=timer+(1000/currentSpeed)) { // Time to change the lights!
changeLights();
Step 5: Where to Go From Here
Congratulations! You've made it to the end of my tutorial.
I'll leave you with a couple of hints plus some ideas of what you can do using this circuit as a basis.
My biggest hint is the use of the Arduino software kit's serial monitor. Learn to love it. When the Arduino is running, use the serial monitor to see any information the board is sending to your computer. The command
Serial.begin(9600);
will tell the Arduino to send data to the computer. What data? Anything you want. Just use:
Serial.print("My variable is now: ");
Serial.println(myVariableName);
Notice that those lines are bit different. The first doesn't add a newline on the end while the second does.
Use Serial.print functions LIBERALLY when debugging code. You can delete them once everything is working correctly.
Also, note that the great thing about the Arduino is that you don't have to keep it hooked to your computer once you've uploaded your sketch. However, the board will need power. A 9V DC adapter with a positive tip is what you'll need (I keep an assortment on hand plus a couple of adjustable power supplies). If you don't have a suitable one, Adafruit Industries has them and includes one in their Arduino starter kit.
So now what? You know how to wire output and input to your Arduino and have a working copy of my tutorial project. Here's a couple of ideas for you to try:
1) Add more LED's. Instead of looping from the last LED to the first, just reverse direction. The back and forth should make a decent Cylon effect.
2) Try adding a second button on another input to slow down the rate of blinking. Or maybe create entirely different patterns using your second switch (the first one is speed, the second is mode).
In any case, have fun! The Arduino is a great piece of hardware with virtually unlimited applications. A little practice and a bit of imagination and the sky's the limit!
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    68 Discussions
    The Litan
    2 years ago
    I try to get 2 type output from my one arduino uno. I upload 2 types sketch, but i can't able....so anyone is help me out....from this
    hottroc
    3 years ago on Step 5
    So when you send a message to the computer using Serial.print how do you view it on the computer. I think you need to add this bit in please. Otherwise your instructable is excellent indeed.
    Grimling
    4 years ago on Introduction
    Hi , thansk for the tutorial , it was clear and it works , even i have a Arduino Mega2560 everything is fine. I just dont get the last bit with the serial.print function.
    Could you specify this ? Where do i add the code ? Into the monitor send ?
    mvanderdeen
    6 years ago on Step 4
    this may be a little late (and possibly make me sound like an idiot) but here goes, i was wondering if thats all code or if your instructions are included in the coding above?
    gunnkmvanderdeen
    Reply 6 years ago on Step 4
    Download the file at the end called "KevinsArduinoTutorial.cpp". That's JUST the code and you can use it as-is in the Arduino IDE (the program editor). In the text on this Instructables page, the code starts with the line:
    and ends with the final
    on the page.
    Don't worry about sounding like an idiot! If you aren't tackling new subjects where you don't know anything at all, then you aren't reaching your potential. The smartest people I know are the least afraid of looking like an idiot -- so they fearlessly ask "dumb questions" all the time!
    mvanderdeengunnk
    Thanks for the help, and the motivation great instructable by the way :)
    louwhopleytoelle
     Be careful not to roast your first one! Stick with using USB power until you're pro. Enjoy :)
    yalylouwhopley
    I have an uno that I ordered from fut-electronics.com and because I live in Egypt it was delivered to me for total of 165 egptian pounds that I'm afraid to loss or fry because i think my dad won't let me buy any thing else from that web-site as it was delivered an empty arduino uno box sealed and sealed cable so the i told them on the phone they sent another one with the board inside!!
    toellelouwhopley
    There's really not much that can go wrong with external power supply. Just make sure you've got the right polarity, and that it is no higher than 12VDC and you should be good.
    But don't play with transistors :P .. I roasted 2 pins on my atmega168 by connecting transistors to it the wrong way, but I already ordered some new atmega328's :D
    toellelouwhopley
    i'll try to be careful not to roast my 328's when i get them :)
    Where do you order your chips from?
    Atleast i only roasted 2 pins (so far) on my 168, so I can still use the other pins :)
    louwhopleytoelle
    I ordered my first Arduino from Italy which took too long so now I am ordering parts from the only local store we have in South Africa.
    http://www.netram.co.za
    dastalouwhopley
    awesome!!!! i've been struggling with electronics123 cos they don't have much. now i haz a new place to gets my stuffs!!! thanks
    toellelouwhopley
    Okay I ordered my first arduino from www.coolcomponents.co.uk, but now im ordering my parts from sparkfun.com .. Better prices, and more stuff :)
    JodexReCreate
    I ordered today Getting Started with Arduino kit from Makershed! Can't wait it to come all the way to Finland!!
