Arduino Bike Speedometer
368,446
341
158
About: I'm a Research Engineer at Adobe. Previously, I was a grad student at the Center for Bits and Atoms at MIT Media Lab. Before that, I worked at Instructables, writing code for the website and iOS apps and m...
Monitor your road speed using the Arduino. This project uses a magnetic switch (also called a reed switch) to measure the speed of one of the bike's wheels.  The Arduino calculates the mph, and send this information out to the LCD screen on the handlebars as you ride.  It is compatible with any kind of bike/wheel, simply enter the radius of the wheel in the firmware to calibrate the device for your setup.
Parts List:
(1x) Arduino Uno REV 3 Radioshack 276-128
(1x) Switch-Magnetic Reed Radioshack 55050593
(1x) 10K Ohm 1/4-Watt Carbon Film Resistor Radioshack #271-1335
(1x) 9V Alkaline Battery Radioshack #23-866
(1x) Heavy-Duty 9V Snap Connectors Radioshack #270-324
(1x) PC Board with Copper Radioshack #276-147
(1x) Parallax 27977-RT Serial Backlit LCD Radioshack 276-120
(x2) SPST PC-Mountable Submini Toggle Switch Radioshack #275-645
(2x) Male Header Pins Jameco 103393
(1x) Female Pin Sockets Jameco 308567
Additional Materials:
22 Gauge Wire Radioshack #278-1224
Solder Radioshack #64-013
sand paper
plywood
wood glue
hot glue
screws
zip ties
sugru
Download Arduino IDE
Step 1: Schematic
The schematic for this project is shown above.
It consists of three switches:
-one to connect to a 9V power supply
-one to switch the backlight of the LCD on and off
-a magnetic switch (called a reed switch) which closes each time the wheel completes one full rotation.
The Parallex LCD is designed to connect to the arduino using only three pins (ignore the labels and the other pins int his schematic).  One to 5V, one to ground, and a third to serial out (TX)- on the arduino, serial out is digital pin 1.
10kOhm resistors are connected to the reed and backlight switches to prevent excess current between 5V and ground (you should never directly connect 5V and ground on the arduino!)
Step 2: Protoboard
Solder three rows of header pins on the protoboard so that the arduino will snap to it as shown in the images above.
Step 3: Reed Switch
The reed switch is comprised of two pieces, a switch and a magnet. The switch has two wires extending out from it, when a magnet comes near the switch it causes a small mechanical piece to move and close the switch momentarily.
Solder a 10kOhm (current limiting) resistor between A0 and ground on the protoboard. Connect long pieces of stranded wire to A0 and 5V- these wires will wrap around the bike and attach to the reed switch.
Step 4: Mount Reed Switch on Wheel
Secure both the magnet and reed switch to your bike wheel with electrical tape (either wheel is fine).  As shown in the images above, the magnet connects to one of the tire spokes and the reed switch connects to the frame of the bike.  This way, each time the bike wheel turns the magnet moves past the switch. Connect the leads form the reed switch to the long wires from your protoboard (orientation does not matter here- it's just a switch)
Use the code below to test your reed switch. When the magnet on the wheel moves past the switch, the arduino should print ~1023, otherwise it will print ~0. Open the serial monitor (Tools>>Serial Monitor) in Arduino IDE to test for your own setup.  If the magnet does not seem to be affecting the reed switch, try repositioning it or even adding a stronger magnet if you have one.
Step 5: Test Switch
Load the code below onto the Arduino. Turn on the serial monitor. It should output 0.00. Start turning the bike wheel, you should see a print of the current mph each second.
Step 6: LCD
Solder a row of female header sockets on the copper side of the protoboard- three of these will be used to connect to the LCD screen. The LCD should fit nicely on top of the protoboard.
Step 7: Install Parallax LCD Library
Connect Arduino 5V, Ground, and TX (Arduino digital Pin 1) to the LCD socket. Read the labels on the LCD pins to make sure you have everything oriented correctly.
Step 8: Parallax LCD
The underside of the Parallax LCD has two switches and a potentiometer. The pot controls the contrast of the display- you can adjust this to what you like. The switches must be set as they are shown in the image above for proper functioning.
Step 9: Test LCD
Test the following code. For some reason my LCD starts making noise and displaying random characters when I first upload, but works fine once I unplug and reconnect the usb connection. I think this may have something to do will interference from the arduino communicating with the computer via digital pin 1 (TX) during the upload.
The LCD should display "Hello World" when it is turned on.
Step 10: Backlight Switch
Wire a switch as shown in the image above. Connect a 10kOhm resistor and a green wire to one lead, and a red wire to the other.
Connect the red wire to Arduino 5V, the other side of the resistor to ground, and the green wire to D2.
Step 11: Final Speedometer Code
Upload the following code onto the Arduino. Test to make sure the backlight switch works and the speed displays properly.  (Again, you may have to unplug the board after loading the firmware and plug it back in again to get it to work properly.)
Measure the radius of your tire wheel (in inches) and insert it in the line: float radius = ''''';
I used timer interrupts in this piece of code to keep the variable "timer" incrementing at 1kHz.  More info about interrupts and an explanation of how I set it up can be found here.
Step 12: Battery
Wire the battery connector and switch in series as shown in the first image above. Connect the read lead from the switch to Arduino Vin and the black wire from the battery connector to Arduino ground.
Step 13: Enclosure
I cut my project enclosure from 1/4" ply on an epilog 120Watt laser cutter.  The dimensions of the enclosure are 3.5"x4"x2".  I modeled the box in AutoCAD and generated the laser cut files (with finger joints) in Autodesk 123D Make.  Then I added two holes for the switches and a rectangular opening for the LCD screen.  I also added some holes on the bottom of the enclosure to make attaching it to the bike easier.
I glued the project enclosure together with wood glue and sanded the edges down. I finished the enclosure with some clear polycrylic.
Step 14: Install Components in Enclosure
Secure the switches onto the enclosure with nuts. Glue or screw the lcd to the underside of the front panel.
Fit the Arduino and Protoboard as well as the battery into the enclosure and secure with velcro or glue.
Screw or fasten the enclosure shut.
Step 15: Attach to Bike
Wrap the reed switch wires around the bike frame, away from any moving bike parts. I used sugru and some zip ties to attach the speedometer to the handle bars.
Step 16: Take It Out on the Road
You should be ready to hit the road. Don't let the awesomeness of your new bike speedometer distract you from road hazards!
2 People Made This Project!
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
158 Discussions
Ravindran2k
4 weeks ago
hi, I have used bike speedometer cable to read the speed using hall effect sensor, it gets 6 peaks per revolution of my wheel. the voltage gradually increases from 0 to 4.9 and reduce to 0.0 and again to 4.9, repeat for 6 peak value like a sine wave for a single revolution. what modification to be done in this program to calculate the speed. please help out. ASAP
Yasith Silva
Question 11 months ago
Anyone I NEED HELP. It works perfect but when magnet is in front of the reed with no rotation, it gives some 40.38 like value.
1 answer
mad_bYasith Silva
Answer 4 months ago
You need to write a special code testing also if the magnet is stopped right over the sensor... I found similar situation but decided to rewrite nearly all the code though using the same approaches.
mad_b
4 months ago
Hi! I tried your speedometer code based on the 1KHz timer, but I don't use the serial port; I display the information on another user Interface and the signal is read from a hall sensor conditioned to TTL by a voltage comparator. The speedometer full exemple that you wrote here seems not to be working correctly, however the general interrupt/polling idea was great and I could made a code myself. I changed it to 10 KHz for better precisionm and as I plan to use it on a motorcycle I added a section and pin input for RPM count inside the ISR. Thanks for the usefull information.
UthayakumarR
Question 6 months ago on Step 5
If suppose my bike wheel is standstill and magnet is facing on the Reed switch then it close the circuit and speed is in high level. Is there any logic will include to when wheel is standstill speed is zero while magnet facing on switch?
FANTOME0
7 months ago
what its the max speed ?
Erion
Why does your timer variable only reachs 2001?
1 answer
Yasith SilvaErion
Answer 11 months ago
check weather you've connected a resistor to the voltage supply of reed instead of connecting to the ground. 5V = 1023 in analog in I guess
puljiun
1 year ago
My reed switch test has a lot of noise. Is it because I haven't soldered the switch into the board?
SivaM20puljiun
Reply 1 year ago
You should add a resistor to ground in the connection of reed switch to Arduino
hobbyman
1 year ago
very nice project.
kilimanjaro1029
1 year ago
I connected the Arduino to a 16x2 LCD, but its not powering on. Will any 16x2 LCD turn on by just connecting those 3 pins mentioned?
amandaghassaei
2 years ago
For those asking about the mph calc:
mph = (56.8*float(circumference))/float(timer);
"circumference" is measured in inches
time per revolution of the wheel ("timer") is measured in milliseconds (0.001s)
miles/hr = 1/(inches per mile) * (miliseconds per hr) * (circumference / timer)
there are 63360 inches in a mile and 1000*60*60 = 3,600,000 ms in an hr:
mph = 1/63360*3600000*circumference/timer
mph = 56.8*circumference/timer
to do this in km/hr:
km/hr = 1/(inches per km) * (miliseconds per hr) * (circumference / timer)
km/hr = 1/39370*3600000*circumference/timer
km/hr = 91.4*circumference/timer
PhremCamandaghassaei
Reply 1 year ago
hi amanda , may i know which library u use for the coding .
yerrasandeepPhremC
Reply 1 year ago
Hi amanda,same request like PhremC "Which library u use for the coding"
it will help me.
ahunkeri
1 year ago
Hey. i'm doing an shoulder wheel rotation count project. In this total count of wheel rotation by patient is sent to doctor by text message. For this I need little help regarding How to count rotations. also i want to check whether patient is exactly how much hand is moving or rotating.eg. 90degree, 180degree,270 degree and 360/0degree.
arduinolife
1 year ago
hi, I'm having trouble displaying the speed on the lcd. what code did you use?
Lucaszech
1 year ago
How do I test the LCD?
