Arduino Heart Rate Monitor
16,442
100
15
This simple and inexpensive project is based around the MAX30100 sensor breakout board and utilizes a small 0.91" OLED display to report the heart rate and oxygenation level.
Both the devices used have an I2C two-wire interface and therefore keeps the wiring down to a minimum.
Parts used
Step 1: The Wiring
Both the OLED display and the MAX30100 breakout board need need 4 wires connected to the Arduino board:
  • Ground
  • VCC
  • SDA
  • SCL
The data lines for the I2C interface will depend on the specific version of the Arduino board being used. In this case I am using A4 for SDA and A5 for SCL, as these are the hardware dedicated pins for the Uno and Nano.
Step 2: The Firmware
Once the three devices (Arduino, OLED display and MAX30100 sensor board) are connected it is time to upload the code to the Arduino board.
Firmware Repository
I have shared the code for my implementation at my GitHub repository, it's not the best code and a bit messy, but it works.
Step 3: Description
At start up, the display prompts the user to place their finger on the sensor. when it detects a heartbeat, it updates the heart symbol on the display to show that and starts recording the readings.
In my implementation I filter any measurement that is outside of a threshold and then calculate an average for both the heart rate and the SpO2 values and finally display that on the OLED. As long as the finger remains on the sensor and the sensor is detecting a heartbeat, the display keeps showing the result. If the sensor does not detect a heartbeat for 10 seconds, it restarts the process and prompts the user for another reading.
Step 4: Final Comments & Video
The Video
I recorded the following video to demonstrate the project.
Conclusion
As you can see this is a really simple implementation on how to use this sensor and the purpose is more educational than anything else. With the right amount of effort a fairly robust device can be built and I hope this guide inspires someone to take this to the next level.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    15 Discussions
    JessicaN21
    2 months ago
    I can get my sensor to read over serial but it just says "place finger on sensor" and doesn't measure with my LCD sketch. Any pointers? Using the exact same equipment you are!
    KevinV152
    8 months ago
    necesito ayuda con el proyecto logro hacer que muestre el mensaje pero a la hora de poner el dedo en el sensor no pasa nada
    PranviS
    Question 1 year ago
    The code is unable to trigger the MAX30100. I have no idea where i am going wrong. I used used your second code from github without the lcd display. Can you please help?
    9mot
    1 year ago
    Do The dupont cables need to be M-M, F-M, or F-F
    usear9mot
    Reply 1 year ago
    In my case they were female to female, but it will depend on what you have as the micro controller.
    MobilusC
    1 year ago
    Hello , Great work!
    Could we make it work with MAX30102 or MAX30105 sensor?
    usear
    1 year ago
    Just updated the repository and added a sketch that only does not use or reply on an OLED display and prints to the serial port instead.
    kandalanusear
    Reply 1 year ago
    n you send me the code please
    kandalan@gvsu.edu
    usearkandalan
    Reply 1 year ago
    The code is in the github repository linked in the write up.
    arduinomaster
    2 years ago
    I had to update the "u8g2" library for the font to make it compile and upload in version 1.6.8. Thanks for sharing. Just what I wanted.
