Arduino : How to Control Stepper Motor Via Bluetooth (with Smartphone)
46,496
305
9
About: Arduino, Raspberry Pi, esp8266, Tutorials, Projects
This instructable is the written version of my "Arduino : How To Control Stepper Motor via Bluetooth (with Smartphone)"
In this project we will control a Stepper motor with a smartphone via bluetooth.
My YouTube Channel
First, you should see the following Instructable:
How to Control a Stepper Motor With L293D Motor Driver
Supplies:
Step 1: Tutorial
The Stepper motor used here is a rusty old EPOCH (5 wires) stepper motor, which is a unipolar stepper.
Step 2: Parts Required :
Parts Required :
- Bluetooth Module ( for example : HC05 or HC06 )
- Jumper Cables
Step 3: Circuit & Connections
Bluetooth Modul VCC to Arduino 5V
(at the same time if you want, you can use 3V3)
Bluetooth Modul GND to Arduino GND
Bluetooth Modul RX to Arduino TX
Bluetooth Modul TX to Arduino RX
Step 4: Programming
Get the Code and Application
*** When uploading code remove the Bluetooth VCC cable
Step 5: Create Application
I use "App Inventor" for create application
MIT App Inventor
Step 6: If I Was Helpful
First of all, I would like to thank you for reading this guide ! I hope it helps you.
If you want to support me, you can subscribe my channel and watch my videos.
My YouTube Channel
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
9 Discussions
AlmondTech
Question 1 year ago
Could I control multiple stepper motors with this? (For a robotic arm)
Awesome by the way.
TeamR1
Question 1 year ago on Step 3
How to connect with stepper motor ?
Can you give me full circuit diagram ?
Thanks. :)
Jacks how2s
2 years ago
can you use iPhone?
lonel
2 years ago
Mert kardeş tebrik ederim, güzel bir çalışma olmuş. Burada bizlerden birilerinin çalışma yaptığını görmek güzel.
robertbu
2 years ago
Note, I've had problems with some HC-5 and HC-6 modules wired in the configuration you specify. The issue is a 5v Arduino txd signal being received by the HC-x 3.3v rxd pin. A couple of resistors used as a voltage divider to bring the voltage down to 3.3v fixed the problem for me.
ArashS6
2 years ago
This looks great! I'll try to do it tomorrow.
