Arduino MP3 Alarm Clock
10,075
63
19
A while ago, I stumbled over a component called DFPlayer. It's a tiny component that allows to play mp3 from an micro SD card (for less that 10€!).
http://www.dfrobot.com/wiki/index.php/DFPlayer_Min...
Since I was sick of using my smartphone as an alarm clock just to have music to wake me, I decided to build an alarm clock with it.
Step 1: Required Components
  • 1x DFPlayer (7,80 Euro)
  • 1x Arduino UNI (20 Euro)
  • 1x LCD Display (20x4, ~10 Euro)
  • 4x 10k Resistors
  • 2x 1k Resistors
  • 1x 10k Poti
  • 1x Rotary Encoder (1,50 Euro)
  • 3x Push Buttons
  • 1x Visaton FRS 8 Speaker (10 Euro)
  • Some cables for wiring and circuit board(s)
Additionally you may want an adjusting knob for the rotary encoder, a frame for the display and a case. My father made an oak case for me which looks pretty nice.
Step 2: Arduino Setup
  • Connect the Arduino via USB to your PC.
  • Make sure that you have the Arduino IDE installed.
  • Download the .ino the attached .ino file and the additional 3x zip files
  • The Arduino IDE provides a wizard where can select the zip file to include a new library.(Sketch -> Include Libraries ...): Install all 3x libraries using this wizard
The .ino file should compile now and you can upload it to your arduino.
Step 3: Wire Components
Before soldering everything together, I recommend using a breadboard to prototype everything.
I created a fritzing image to help with that. You should check the correct wiring of the DFPlayer by using the provided link. You can find a description of the DFPlayer's pins there, but assuming the 5V+ pin is in the upper left corner, the wiring should match as shown on the picture.
Step 4: Build Everything Into the Case
The step varies depending on what case you have chosen to use. I've added some pictures here to show the steps I've done to wire everything into my oak case. I decided to build smaller circuits on smaller circuit boards to have checkpoints where I can verify that everything is still working.
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    19 Discussions
    KamilG4mfaust
    Reply 2 years ago
    Thanks for a quick reply, I managed to upload your code, however I'm experiencing another problem. After wiring my lcd according to arduino, all I get on display are 2 rows of blocks (no characters) and no illumination. I checked the specification for my lcd here
    https://www.adafruit.com/datasheets/TC2004A-01.pdf
    And I can tell that the backlight pins are 15 and 16, whereas pin 15 on your diagram goes to arduino and does something else I presume.
    I assume that other pins will be different too.
    I'd appreciate it if you can help me out here, otherwise I'll just give up with this project.
    windhoarfrost
    1 year ago
    This is a simple yet beautiful project. I love it! :3
    Kawajohn
    2 years ago
    anyone can confirm this instructable works?
    building it atm, got the screen working but using some old parts...
    so would be nice if someone can confirm and i have to check parts
    had it working but started up and it was frozen in ouhr menu, now i fried my 10k pot ;-p
    waiting for parts
    P-L
    2 years ago
    Hi, Time.h attached to this tutorial is outdated. The new one can be found here:
    https://github.com/PaulStoffregen/Time
    KamilG4
    2 years ago
    Hi again, Ive been trying to upload your program to my Arduino and it keeps saying
    Arduino: 1.6.8 (Windows 7), Board: "Arduino/Genuino Uno"
    C:\Users\Golomp\Desktop\mephisto_V\mephisto_V.ino:3:19: fatal error: Timer.h: No such file or directory
    #include "Timer.h"
    compilation terminated.
    exit status 1
    I installed some Time library but it hasnt resolved the issue.
    Also I see that you have included a
    #include <DFPlayer_Mini_Mp3.h> Library, where do I get it from?
    Sorry to be a pain, I'm not a programmer so I dont have a clue.
    Thanks!
    mfaust
    3 years ago
    To be honest, I can only guess since I only have some basic skills and I had to play around with rotary encoders a lot before I got a successful combination of code and hardware. My approach would be to connect the rotary encoder to the arduino and play around with the connections. Create a separate sketch for it using this logic:
    * The rotary encoder implementation
    void updateEncoder(){
    int MSB = digitalRead(encoderPin1); //MSB = most significant bit
    int LSB = digitalRead(encoderPin2); //LSB = least significant bit
    int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
    int sum = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
    //if(sum == 13 || sum == 4 || sum == 2 || sum == 11) encoderValue ++;
    if(sum == 2) encoderValue --;//skip updates
    //if(sum == 14 || sum == 7 || sum == 1 || sum == 8 ) encoderValue --;
    if(sum == 1) encoderValue ++;//skip updates
    Use the Serial.print to log the encoderValue and check if it is working as expected (I had to google this code, but can't remember where I got it).
    KamilG4
    3 years ago
    Hi, I'm preparing to make this mp3 player, I have almost all needed parts. I'm just wondering how to connect my encoder as it seems to have a different pinout than yours. Here is the eBay auction number
    181956049541
    Many thanks in advance.
    jalenw215
    3 years ago
    Are these momentary switch buttons or latch switch?
    mfaustjalenw215
    Reply 3 years ago
    Momentary switch buttons, this one:
    http://www.conrad.com/ce/en/Search.html;jsessionid=07DD185D114B945F9143B6859DBF3877.ASTPCEN23?search=2050000219405&searchType=mainSearchBar
    QS27
    3 years ago
    Is it possible to use a potentiometer instead of a rotary encoder?
    mfaustQS27
    Reply 3 years ago
    Technically yes, but I wouldn't recommend it. It is just to complicate to use the position of the potentiometer to calculate the current input value.
    jalenw215
    3 years ago
    Does the microSD go in the back? or do you have to take it apart to put one in. Either way I love this project.
    mfaustjalenw215
    Reply 3 years ago
    There is one photo of the last step where you can see a small opening on the back. This is where you can access the sd card. The dfplayer has a little spring inside the sd slot, so it jumps out.
    A little bit of a hassle though: the mp3 files on the SD card must be numbered, starting with 0001_.., 0002_... etc. I've written a small program that renames the mp3 files I've selected automatically before I copy them on the SD.
    mfausttiunkabouter
    Reply 3 years ago
    Yes, its for dimming the screen. I followed the adafruit tutorial for wiring lcds.
