Arduino Motor Shield Tutorial
1,095,379
819
181
About: My name is Randy and I am a Community Manager in these here parts. In a previous life I had founded and run the Instructables Design Studio (RIP) @ Autodesk's Pier 9 Technology Center. I'm also the author ...
The Arduino Motor Shield allows you to easily control motor direction and speed using an Arduino. By allowing you to simply address Arduino pins, it makes it very simple to incorporate a motor into your project. It also allows you to be able to power a motor with a separate power supply of up to 12v. Best of all, the shield is very easy to find. For all of these reasons, the Arduino Motor Shield if a cool little to have in your arsenal for rapid prototyping, and general experimenting.
Step 1: Install
The pins of the official Arduino motor shield will only align with Arduino Uno Rev. 3.
In order to make it work with older versions of the Arduino, you will need to trim a few pins off the motor shield. However, this is not, at all, recommended.
Insert the motor shield pins into the socket of the Arduino Uno.
Step 2: Shield Features
The motor shield has 2 channels, which allows for the control of two DC motors, or 1 stepper motor.
It also has 6 headers for the attachment of Tinkerkit inputs, outputs, and communication lines. The use of these pins is somewhat limited, and therefor not covered in this tutorial.
With an external power supply, the motor shield can safely supply up to 12V and 2A per motor channel (or 4A to a single channel).
There are pins on the Arduino that are always in use by the shield. By addressing these pins you can select a motor channel to initiate, specify the motor direction (polarity), set motor speed (PWM), stop and start the motor, and monitor the current absorption of each channel .
The pin breakdown is as follows:
FunctionChannel AChannel B
Direction Digital 12 Digital 13
Speed (PWM) Digital 3 Digital 11
Brake Digital 9 Digital 8
Current Sensing Analog 0 Analog 1
For more information about the technical specs, check out the motor shield's official page on the Arduino site.
Step 3: Program
Plug the Arduino into your computer's USB port and open the Arduino development environment.
In order to get the board to do anything, you need to initialize the motor channel by toggling three parameters:
  1. First you need to set the motor direction (polarity of the power supply) by setting it either HIGH or LOW.
  2. Then you need to disengage the brake pin for the motor channel by setting it to LOW.
  3. Finally, to get the motor to start moving, you need to set the speed by sending a PWM command (analogWrite) to the appropriate pin.
If you do not do all three of these things, the motor will not turn on.
In the following steps are some common examples of common motor setups.
Step 4: One Motor
To control a motor using the Arduino Motor Shield, first plug the motor's positive (red) wire into Channel A's + terminal on the motor shield, and the motor's ground (black) wire into Channel A's - terminal on the shield.
An external power supply is not always necessary, but it drastically improves the motor's performance. It is recommended that you always use one.
To connect your external power supply, connect the positive (red) wire from the power supply to the "Vin" terminal, and the ground (black) wire to the "GND" terminal.
Finally, upload the code to control the Motor Shield to the Arduino.
Here is the code for controlling one motor:
<pre>/*************************************************************
Motor Shield 1-Channel DC Motor Demo
by Randy Sarafan
For more information see:
https://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/
void setup() {
  //Setup Channel A
  pinMode(12, OUTPUT); //Initiates Motor Channel A pin
  pinMode(9, OUTPUT); //Initiates Brake Channel A pin
void loop(){
  //forward @ full speed
  digitalWrite(12, HIGH); //Establishes forward direction of Channel A
  digitalWrite(9, LOW);   //Disengage the Brake for Channel A
  analogWrite(3, 255);   //Spins the motor on Channel A at full speed
  delay(3000);
  digitalWrite(9, HIGH); //Eengage the Brake for Channel A
  delay(1000);
  //backward @ half speed
  digitalWrite(12, LOW); //Establishes backward direction of Channel A
  analogWrite(3, 123);   //Spins the motor on Channel A at half speed
  delay(3000);
  delay(1000);
Step 5: Two Motors
Interfacing with two motors is pretty much the same as interfacing with one motor. Simply plug the motor into Channel B.
The only difference code-wise is that you need to engage a second channel to control the second motor.
Here is code for controlling two motors:
Motor Shield 2-Channel DC Motor Demo
by Randy Sarafan
void setup() {
  //Setup Channel A
  //Setup Channel B
  pinMode(13, OUTPUT); //Initiates Motor Channel A pin
  pinMode(8, OUTPUT);  //Initiates Brake Channel A pin
void loop(){
  //Motor A forward @ full speed
  //Motor B backward @ half speed
  digitalWrite(13, LOW);  //Establishes backward direction of Channel B
  digitalWrite(8, LOW);   //Disengage the Brake for Channel B
  analogWrite(11, 123);    //Spins the motor on Channel B at half speed
  delay(3000);
  digitalWrite(9, HIGH);  //Engage the Brake for Channel A
  digitalWrite(9, HIGH);  //Engage the Brake for Channel B
  delay(1000);
  //Motor B forward @ full speed
  digitalWrite(13, HIGH); //Establishes forward direction of Channel B
  analogWrite(11, 255);   //Spins the motor on Channel B at full speed
  delay(3000);
  delay(1000);
Step 6: Stepper Motor
There are a number of different types of stepper motors, but in this tutorial we will specifically be addressing bipolar stepper motors. Bipolar stepper motors typically have 4 pins, which correspond to two coils. To use a stepper, you need to power these two coils in phase with alternating polarity.
To figure out which two pins make up a single coil, insert an LED into any two pins on its socket and rotate the motor shaft. If the LED lights up, you found one coil. The other two pins should make up the other coil.
To make a bipolar motor spin:
  1. Power the first coil.
  2. Next power the second coil with reverse polarity.
  3. Then power the first coil with reverse polarity.
  4. Finally, power the second coil.
To reverse the motor direction of a bipolar stepper, simply reverse the polarity of the second coil.
Here is code to make the stepper spin in one direction:
Motor Shield Stepper Demo
by Randy Sarafan
int delaylegnth = 30;
void setup() {
  //establish motor direction toggle pins
  pinMode(12, OUTPUT); //CH A -- HIGH = forwards and LOW = backwards???
  pinMode(13, OUTPUT); //CH B -- HIGH = forwards and LOW = backwards???
  //establish motor brake pins
  pinMode(9, OUTPUT); //brake (disable) CH A
  pinMode(8, OUTPUT); //brake (disable) CH B
void loop(){
  digitalWrite(9, LOW);  //ENABLE CH A
  digitalWrite(8, HIGH); //DISABLE CH B
  digitalWrite(12, HIGH);   //Sets direction of CH A
  analogWrite(3, 255);   //Moves CH A
  delay(delaylegnth);
  digitalWrite(9, HIGH);  //DISABLE CH A
  digitalWrite(8, LOW); //ENABLE CH B
  digitalWrite(13, LOW);   //Sets direction of CH B
  analogWrite(11, 255);   //Moves CH B
  delay(delaylegnth);
  digitalWrite(12, LOW);   //Sets direction of CH A
  delay(delaylegnth);
  digitalWrite(13, HIGH);   //Sets direction of CH B
  delay(delaylegnth);
Here is code to make the stepper spin in the opposite direction:
by Randy Sarafan
void setup() {
void loop(){
  delay(delaylegnth);
  delay(delaylegnth);
  delay(delaylegnth);
  delay(delaylegnth);
5 People Made This Project!
  • Big and Small Contest
  • First Time Author
    First Time Author
  • Make it Glow Contest 2018
181 Discussions
egehan531
Question 4 weeks ago on Step 5
Hi, when I check the two engines of a robot, one goes back to the old one. How can I fix?
1 answer
randofoegehan531
Answer 4 weeks ago
I am not sure I understand your question. I think you are asking about motors, but I am not sure what you are describing.
DanielB857
Question 5 months ago on Step 4
How can I set, a time for the DC motor?
For example I want to open a door it take 10sec before the door is complete open, and what the DC motor to stop, wait 5min and the revers it down agin
randofoDanielB857
Answer 5 months ago
They delay function is in milliseconds. That means for every 1000 increments, the program will wait one second. For instance delay(2000); is the same as telling the code to wait for 2 seconds.
You would engage the function to turn on the motor, delay for 10 seconds, engage the stop function on the motor, create a delay for 300 seconds (5 minutes) and then reverse the motor (and then stop it again).
DanielB857randofo
Reply 4 months ago
can you combine with a clock, at 14:00, the engines will start spinning in 30sec, then close.
Manikantas3
Question 5 months ago on Step 6
what is the supply voltage required to run 4 DC motors with motor sheild and max voltage rating??
1 answer
randofoManikantas3
Answer 5 months ago
It depends on the voltage requirements of the motor. Different motors have different voltage ratings.
However, the shield has a maximum voltage rating, and I would not put more than 12V through the shield. Although, your motors might require less voltage than that.
Supplying the right amount of current is important. You would want to make sure that yours motors do not draw more current than the shield is able to handle. I would not exceed more than about 2 amps per channel.
Also, this shield is a dual H-bridge, meaning it can only control 2 motors.
rburgos05
6 months ago
In case of interest to anyone, here is a truth table of the Arduino Motor Shield Rev3, channel A. The first row is the default value before you send anything to the motor shield.
DIRA BRAKEAPWMA PWMA A+A-
LOW LOW 0 1.4V 1.4V
LOW LOW 255 0V VMOT
LOW HIGH 0 1.4V 1.4V
LOW HIGH 255 0V 0V
HIGH LOW 0 1.4V 1.4V
HIGH LOW 255 VMOT 0V
HIGH HIGH 0 1.4V 1.4V
HIGH HIGH 255 VMOT VMOT
SavioR5
Question 8 months ago on Introduction
Hi all, I have a Arduino Mega and a Motor shield controlling a DCC command station for a model railroad. A-,A+,B- and B+ are used to send signals to the track. I need to also control 3 turnouts using 3 micro servors. Can this be done using the existing hardware.
SteveS162
Question 9 months ago
Hi I'm fairly new to this (trying to teach myself after brian probs). Is there a way to set both motors going at the same time? I want to use it for a car, when I set it away there is quite a delay from motor1 starting till motor2 starts. Many thanks for any advice and help.
1 answer
randofoSteveS162
Answer 9 months ago
In the code above they should both engage at the same time, but at different speeds. If one is taking a little while to engage, maybe it is being slightly underpowered? I am not certain what the error is without having more information about your setup.
yamanss01
Question 10 months ago on Step 4
how does the direction of motor will change at runtime of robot . how can we manually control the direction of rotation . by using a 3 way switch then how to connect a 3 way switch to a motor shield.
1 answer
randofoyamanss01
Answer 10 months ago
You would need to connect an input to the Arduino and then monitor the state of the input.
If the state of the input changes, you can use the Arduino to tell the motors to do something else.
I recommend reading the Arduino Class to learn more about Arduino inputs:
https://www.instructables.com/class/Arduino-Class/
randofoMusab Mahmood
This shield does not have bluetooth capability. You would need to get a bluetooth module and connect it to the unused pins on the shield.
You would then interpret the incoming data from the bluetooth module, and conditional statements (such as if > then) to interpret these commands and control the motor.
For instance:
If the bluetooth module sends the command forward, then turn both motors on to spin forward.
Carro33
1 year ago
hi every one.i need an info please.
i have an adafruit motor shield on top of arduino uno.every thing was working untill i connected two 2.7 amp motor on two channels of the motorshield ( adafruit ). one of the two chip smoked lol. the other one is working so i can still use two motor.my question is can i put an arduino motorshield on top of the adafruit motorshield so i will have my two bigger motor back ?thank you for any help and sorry about my english...
ugyeamit
1 year ago
can i get some help with using that shield to connect to communicate with the Bluetooth channels... how should i write the code, im stuck in the middle of my project...
randofougyeamit
Reply 1 year ago
This shield does not have bluetooth. Are you using something bluetooth enabled?
The best thing to do would be to figure out how to use this shield to control motors without bluetooth.
Then, find a tutorial for interfacing with your bluetooth module.
Then write a conditional (if -> then statement) which basically says, if my bluetooth receiver gets a command, then control the motor.
ugyeamitrandofo
Reply 1 year ago
Im using hc 06 with l298N motor driver ic... and i looked up to a similar project and even used his apps and all the connections with the same code , i am able to connect with the Bluetooth module but its not controlling the motor... what could be wrong... thanks for your support..
Kit Lorenz
2 years ago
Can one also put another shield on top of the first one to support 4 dc motors?
